KGCoupe Samba Member
Joined: July 01, 2005 Posts: 3580 Location: Putting the "ill" and "annoy" in Illinois
Posted: Thu Jun 25, 2020 12:58 pm Post subject: Re: Where can I get a Metal Dash Board??? |
What is your primary goal in having a metal dash?
If you are mostly concerned with having the look of the early style guages (one small guage flanked by two larger ones), then it would probably be easiest to cut out your old one and weld in another from an older donor Ghia.
If your OK with the look of the later style guages (one large guage flanked by two smaller ones) but really want the look of the clean painted metal surface across the face of the dash, then perhaps it may be easier to remove the plastic facia and have all the "extra" small holes/openings in your current dash welded shut and paint it. |
Marcdeb Samba Member
Posted: Thu Jun 25, 2020 2:39 am Post subject: Re: Where can I get a Metal Dash Board??? |
Can you post pictures of your dash from the front and from the trunk side?
It would be easier for people to give you correct advice. Replacing the dash is doable. My car is a 71. The previous owner removed the original dash and installed a 62 dash.
Here's what you have when the dash is removed.
Maybe your 74 still has it's original dash but with modifications? If so, you might be able to return it to original as far as the opening for the glove box. Then close up any holes used for pad installation and paint it to give it the older look. _________________ Marc
71 Karmann Ghia Cabrio
Previously Owned:
2011 VW EOS Hard Top Conv
2008 Saab 9-3 2.0T Conv
2003 Saab 9-3 SE Conv
2001 Saab 9-3 Conv
1998 BMW 3 Series Conv
1997 Saab 900 Conv
1997 Mazda Miata
71 Ghia Vert Restoration: https://www.thesamba.com/vw/forum/viewtopic.php?t=726710&postorder=asc |
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 4115 Location: In Molinya Orbit
Posted: Thu Jun 25, 2020 12:39 am Post subject: Re: Where can I get a Metal Dash Board??? |
The dash board is a single stamping. It is spot welded to the lower window lip, bottom rear of the trunk and the A pillars. Un pick the spot welds and you can remove the currently installed dash. Then you do the same for a dash from a wrecked Ghia, one that has no redeemable prospects. You then spot weld the old dash in place of the old one. It is a significant about of work but it will look fabulous
Nicholas _________________ '66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
paul1223 Samba Member
Posted: Wed Jun 24, 2020 11:33 pm Post subject: Where can I get a Metal Dash Board??? |
I'm looking for a metal old school dash for my 74 ghia. At present it has some sort of metal dash with the castle logo but no glove box. Can you fit an older metal Dashboard into a 1974 that had the plastic dash? Where can you get the metal dashboards? Thanks! |
