campism Samba Member
Joined: September 07, 2007 Posts: 4711 Location: Richmond VA
Posted: Sun Nov 01, 2020 5:57 am Post subject: Re: Exhaust pipe crack. |
| djkeev wrote: |
| Case in point, the last time I tried I could not locally purchase plastigauge. A staple product in engine rebuilding. |
I've been hitting the FLAPSes for various things during Dodge engine work and some places no longer sell valve lapping compound but one place had it and that's all I needed. _________________ '87 Westy in Wolfram Grey Metallic, tragically crushed by a falling hickory tree in my own driveway and now gone, leaving me Vanagonless and with no plans to replace it, alas. |
HackAl Samba Member
Joined: March 12, 2016 Posts: 343 Location: Bergen County, NJ
Posted: Sat Oct 31, 2020 1:23 pm Post subject: Re: Exhaust pipe crack. |
Dan, gotcha. Makes sense. _________________ 91 Westy.
Ever consider temporarily trading your van? Join the list. |
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10518 Location: Sunshine Coast B.C.
Posted: Sat Oct 31, 2020 12:52 pm Post subject: Re: Exhaust pipe crack. |
"Looking for a bandaid for the trip."
No doubt the metal is thin around that crack but could that crack be brazed?
But....
Cleaning that area to shiny metal might be tough and only serve to expose pin holes or worse.
Brazing a patch over it would bump the cost up I"m sure.
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 5916 Location: Bemidji, MN
Posted: Sat Oct 31, 2020 12:44 pm Post subject: Re: Exhaust pipe crack. |
i've successfully used the "2000 Degree" iron fortified cement in a little screw top vial on thick castings but anything i've tried on the Vanagon header pipes never bonds well. there is such a large thermal expansion coupled with a quite smooth surface that it all seems to flake off. there's quite a bit of flex in the exhaust system too which further stresses a hard compound.
it's a hard location environmentally... the header is red hot just inches beyond where it bolts to the head but the head flange is relatively cool. LOTS of differential expansion. _________________ -dan
www.thefixitworkshop.com |
HackAl Samba Member
Posted: Sat Oct 31, 2020 11:27 am Post subject: Re: Exhaust pipe crack. |
Was my crack not a candidate for an epoxy fix because it was too close to the block? _________________ 91 Westy.
Xevin  Samba Member
Posted: Sat Oct 31, 2020 11:21 am Post subject: Re: Exhaust pipe crack. |
Thanks guys. I was thinking the same as both of you. Going on a road trip next week. Looking for a bandaid for the trip. I’ll do a proper replacement this Winter.
I have a lot of old school muffler shops around me _________________ Keep on Busin'
| 67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
| Clatter wrote: |
Damn that Xevin...  |
| skills@eurocarsplus wrote: |
| SGKent wrote: |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10357 Location: N. Idaho
Posted: Sat Oct 31, 2020 11:13 am Post subject: Re: Exhaust pipe crack. |
Heh - that's a candidate for an epoxy fix. You'll be amazed how long it will last. What vehicle is that on? _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1993 Toyota LandCruiser, 2002 BMW 325iX, 1982 Toyota Sunrader |
?Waldo? Samba Member
Joined: February 22, 2006 Posts: 10131 Location: Where?
Posted: Sat Oct 31, 2020 10:42 am Post subject: Re: Exhaust pipe crack. |
That pipe looks seriously eroded. That crack is where the pipe looks paper thin or rusted out entirely. Likely most of the pipe is similarly thin and trying to even clean the metal enough to get a good weld would cause more holes. It might be possible to do a temporary weld on it but IMO that pipe is at the end of its useful service life. If I'm not mistaken that pipe is not connected to the heads and so it could be removed without the risk of snapping studs and needing to replace heads. _________________ I am a high-functioning autistic into VW diesels and Vanagons along with other things that are unrelated to this site. |
Xevin  Samba Member
Posted: Sat Oct 31, 2020 10:30 am Post subject: Re: Exhaust pipe crack. |
Discovered this yesterday on the 3/4 side
I wonder if a competent old school muffler shop can weld this
| Clatter wrote: |
| SGKent wrote: |
Posted: Sat Oct 31, 2020 6:52 am Post subject: Re: Exhaust pipe crack. |
| djkeev wrote: |
It seems that older cars are vanishing, older trade-ins are shipped to less affluent areas and buyers are encouraged to go new with frightening long finance periods.
The number of auto shops machine shops (I think these are down to zero locally) and even parts distributors has plummeted.
Repair shops pull codes and switch out indicated parts or replace obviously worn parts such as brakes and suspension.
Dave |
that's interesting on the parts distributors... in our town of 12,000 in northern MN, we have 6 of them. all pretty heavily stocked. but then we are the quintessential "less affluent" community where those high mile auction cars end up.
machine shops, uff, we are down from 4 to one very tired one that i hesitate to bring stuff to. there's another one 85 miles away that is so fastidious you essentially enter thru an 'airlock' where you are stopped if your parts are too dirty. that guy tried to get his son interested, no go, and instead of selling his machines for 10 cents on the dollar, decided to keep going thru 'retirement'. he said there is no market for machine equipment. _________________ -dan
HackAl Samba Member
Posted: Sat Oct 31, 2020 6:48 am Post subject: Re: Exhaust pipe crack. |
Dave, agree. The number of mechanics that I trust to work on my van around here are few and far between.
The guy who did the world work was 70 years old. A younger guy in the shop originally looked at it and wanted to charge 475 for basically the same work. I said thanks but no thanks and as they were dropping the van off the left, the older mechanic said, "wait a second." His name was Garfield.
The guy who did the brake job last week was younger but under the tutelage of an older BMW mechanic also in his '70s. That outfit is called Rennsport in Hackensack. Where they lack in Vanagon knowledge, they kind of make up for in work they've done on Porsches and other German makes. But more importantly, they, unlike any other mechanic with whom I've spoken, and I've spoken into dozens, are willing to read these threads on The Samba and look at the YouTube videos I show them. They are wise enough to know what they don't know and willing to learn and consider other points of view.
And I'm finding that that particular skill set is rare. I don't know if it is a generational phenomenon or not. _________________ 91 Westy.
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32988 Location: Reading Pennsylvania
HackAl Samba Member
Posted: Sat Oct 31, 2020 6:08 am Post subject: Re: Exhaust pipe crack. |
Campism, correct.
Posted: Sat Oct 31, 2020 5:31 am Post subject: Re: Exhaust pipe crack. |
| HackAl wrote: |
| They could not weld in place. They cut the exhaust pipe on one side so only two bolts had to come out. They then welded the inside of the area near the flange in addition to the outside but only minimally to avoid blocking the stud for future removal. |
Clarification, please? Sounds like they cut the pipe at some distance from the flange, removed the cracked section from the head, welded the crack and reinstalled that section. Presumably they then welded up the cut they had made in order to remove that section? _________________ '87 Westy in Wolfram Grey Metallic, tragically crushed by a falling hickory tree in my own driveway and now gone, leaving me Vanagonless and with no plans to replace it, alas. |
Posted: Fri Oct 30, 2020 4:14 pm Post subject: Re: Exhaust pipe crack. |
What I like to do is lay a full coat of weld bead over the bend in the pipe, this area gets really thin from the exhaust gases eroding the outside of the bend and in the long run the thin metal makes welding the crack ineffective as the thin metal will just crack again at the edge of the weld. I have had good luck with having a new elbow welded in so the metal if full thickness.
HackAl Samba Member
Posted: Fri Oct 30, 2020 3:08 pm Post subject: Re: Exhaust pipe crack. |
Closing loop: Meineke got this done for 200 bucks. I told them only to proceed if they could free up the pipe without cracking the stud. They could not weld in place. They cut the exhaust pipe on one side so only two bolts had to come out. They then welded the inside of the area near the flange in addition to the outside but only minimally to avoid blocking the stud for future removal. They did a good job as far as I can tell. The rig definitely sounds better now. Considering pipes and shipping would have been 150 alone, I'm happy with this result.
I'll try to post a picture later. _________________ 91 Westy.
pdm777 Samba Member
Joined: August 06, 2012 Posts: 348 Location: Clovis, CA
Posted: Thu Oct 29, 2020 8:50 pm Post subject: Re: Exhaust pipe crack. |
Yep, JB Weld is amazing.
I've repaired intercoolers, gas lines, oil pans,
much more than I'd care to admit.
Never tried the exhaust repair JB.
Like you mentioned, if it fails, no welder will touch it
after you've goobered up a manifold pipe.
Seemed like a half ass hillbilly solution at first.
Now I believe !!!!!!!
Now I never leave home without it.
Along with a roll of self healing silicon tape. _________________ 1990 Westy Full Camper |
Posted: Thu Oct 29, 2020 8:41 pm Post subject: Re: Exhaust pipe crack. |
PDM,
I think you missed the point. You took your exhaust manifold off to have it repaired. The "good advice" here is NOT to take it off. Do NOT cut bolt heads off with a Dremel, etc. Get it welded on the car by someone who's worked at an exhaust shop forever and they're out there, for sure.
On JB Weld, you'd think I would be their saleman. But yes there is a "steel" hi temp version who's name escapes me but it works directly on hot exhausts. I have it on the cracked manifold of my '88 Mitsubishi Van and it's lasted 6 years of a 16yo teenage son who's offroaded it, overloaded it, bashed it around, etc. The manifold is a known issue so I have a spare in the garage for when this fix fails. So far, I'm impressed.
Our 97 LandCruiser has been a beneficiary as well. It now has a new exhaust system, but our daughter used it in Michigan for 4 years at college where it remained parked all summer and used all winter. At 287k, the original exhaust succumbed to the Michigan salt baths and the Y pipe cracked. I filled it with this JB Weld product while there for parent's weekend a couple years ago with no tools to properly prep the surfaces, etc. Then the next year the Oxy sensor bung rusted off and the sensor hung by a wire. Again with no time to devote to it, I circled the bung hole with the Epoxy, then simply bedded it down and held the mess in place with masking tape overnight. In the morning I took a fresh container of the Epoxy and smoothed it over further. Lasted nearly 2 years and when I removed the old exhaust both fixes were still fine.
So, never underestimate the stuff. However, don't do this if you're bringing it to a welder. He or she will likely shake their head and turn you down as that stuff will be a nightmare to get out of the way... _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1993 Toyota LandCruiser, 2002 BMW 325iX, 1982 Toyota Sunrader |
pdm777 Samba Member
Posted: Thu Oct 29, 2020 3:58 pm Post subject: Re: Exhaust pipe crack. |
My Tiico had a serious crack -all the way around- the pipe.
Good Advise! I found a small local muffler shop with 70's musclecars
parked in front, and got it welded for only $20 !!!!
And it's a heck of a weld, very thick.
I did take the exhaust manifold off first.
Take it to a specialist for removal, or take your time and
cut off the header nuts with a Dremel, then clean up the threads.
There was no way to weld it properly while it was on the head.
No way JB weld or any 'glue' is going to repair that. _________________ 1990 Westy Full Camper |
Posted: Thu Oct 29, 2020 3:45 pm Post subject: Re: Exhaust pipe crack. |
| MarkWard wrote: |
| When you go to replace that simple exhaust and you snap a stud, you’ll really be wishing you’d have attempted welding it in place. |
Valid point. If you can find a welder who will attempt the repair it is certainly worth a try. Having broken an exhaust stud when replacing the system on my van I can assure you that you do not want that additional hassle. _________________ '87 Westy in Wolfram Grey Metallic, tragically crushed by a falling hickory tree in my own driveway and now gone, leaving me Vanagonless and with no plans to replace it, alas. |
