Red light and temperature gauge going up [solved]
djkeev
djkeev is offline
PostPosted: Sat Feb 06, 2021 6:46 am    Post subject: Re: Red light and temperature gauge going up [solved] Reply with quote
Good work finding the bad connection!
But as a lesson, light comes on? Stop immediately and verify you have coolant and a fan belt.
After confirming the basics, baby it home.
Dave
Ghia
Vanagon
Beetle
Abscate Premium Member
Abscate is offline
PostPosted: Sat Feb 06, 2021 3:02 am    Post subject: Re: Red light and temperature gauge going up [solved] Reply with quote
If you use that device and a camera phone after a hot run when your Bus is running well, you will have a map of known good temperatures !
Usually, in an overheat, your nose tells the tale. Stinky hot metal followed by coolant
tprosser100
tprosser100 is offline
PostPosted: Fri Feb 05, 2021 9:58 pm    Post subject: Re: Red light and temperature gauge going up Reply with quote
Turns out the vanagon was not overheating after all Very Happy It was a wire that was hanging on by a thread at the temperature sensor. It was throwing a false signal that the vanagon was overheating. I am happy that it was a minor issue. Had me scared for a moment but relief in the end.
Probably a good lesson for myself to just simply check the temperature of the 2 coolant pipes or hoses underneath with a infrared thermometer or just barely touch them with my hand. I felt them with my hand and they were just luke warm. That was my sign that the van was not actually overheating.
1984 Vanagon Westfalia GL
hdenter
hdenter is offline
PostPosted: Fri Feb 05, 2021 5:15 pm    Post subject: Re: Red light and temperature gauge going up Reply with quote
I prefer the Libby bong method. No jacking required.
Hans
'79 triple white convertible bug
'84 sunroof vanagon
'85 weekender
Howesight
Howesight is offline
PostPosted: Fri Feb 05, 2021 3:34 pm    Post subject: Re: Red light and temperature gauge going up Reply with quote
tprosser100 wrote:
Yes, I checked the coolant and it was at the minimum level. So I added coolant and I am still getting the red warning light and temperature gauge going to 3/4. I had the coolant replaced 2 months ago by a VW mechanic so I know he got all the air pockets out. I also know he lifted the front end over 18 inches. I did have the ignition coil replaced yesterday. Now, I have it at the mechanic in Buena Vista, CO. today. I was just surprised that it could really overheat in 20 degree weather.
It's getting so hard to find Vanagon repair technicians who understand how to bleed the Vanagon cooling system. The REAR end of the vehicle needs to be higher than the front end. The Vanagon Rad has an inlet and outlet far lower than the top of the rad. For this reason, to bleed the air that always accumulates in the top half of the rad, you need to open the air bleed at the top of the rad and also ensure that the air bleed valve is LOWER than the Vanagon expansion tank - - unless you are doing this in a location where there is no gravity. (In that case, ignore the above - - you are in space and all bets are off and you need a rocket scientist, not a mechanic)
The mass of the coolant flows, by gravity, from the rest of the cooling system, to occupy the space in the rad and pushes the air out. If no coolant is flowing to the rad, then the air will not be pushed out.
'86 Syncro Westy SVX
4Gears4Tires
4Gears4Tires is offline
PostPosted: Fri Feb 05, 2021 8:05 am    Post subject: Re: Red light and temperature gauge going up Reply with quote
This tank needs to be completely full.
djkeev
djkeev is offline
PostPosted: Fri Feb 05, 2021 7:37 am    Post subject: Re: Red light and temperature gauge going up Reply with quote
Tank terms get muddied easily.
Check the tank in the engine compartment.
Not the one behind the license plate.
Dave
Ghia
Vanagon
Beetle
djkeev
djkeev is offline
PostPosted: Fri Feb 05, 2021 7:33 am    Post subject: Re: Red light and temperature gauge going up Reply with quote
tprosser100 wrote:
Ok, I did check the expansion tank and it is at the correct level. The tank on the left when looking at the engine 😀
The correct level on that tank is absolutely full.
If it is down an inch or two, the level sensor will turn on the dash light.
Dave
Ghia
Vanagon
Beetle
Abscate is offline
PostPosted: Fri Feb 05, 2021 7:27 am    Post subject: Re: Red light and temperature gauge going up Reply with quote
The engine burns at 2000F , and all that heat is localized in very small spots. That heat has to be carried away quickly and efficiently by the coolant system: pump, hoses, coolant,and radiator to dump it into the air.
I would venture that 999/1000 of overheats are not due to ambient temperatures , but to some failure in the coolant system components.
The impact of ambient temperature swings is often over estimated
Coolant runs at about 200F , it is simple to design the coolant system to exchange enough heat at 100F ambient, then use a thermostat to control the system at lower temperatures. A 100 F temperature differential is still large and easy to design heat transfer typical of an auto engine
You can even swag the heat generated as approximately equal to the hp in use, as engines are about 40-50%nefficient.
Iโ€™m swagging it because I donโ€™t have access to ray Greenwoodโ€™s nanodots
tprosser100
PostPosted: Fri Feb 05, 2021 7:21 am    Post subject: Re: Red light and temperature gauge going up Reply with quote
djkeev
djkeev is offline
PostPosted: Fri Feb 05, 2021 7:13 am    Post subject: Re: Red light and temperature gauge going up Reply with quote
tprosser100 wrote:
Refill/overflow on the right, behind the license plate, just filled it to the Max line.
No,, that one is for coolant recovery, yes it should be at the line but if it is low, you have an issue.
Open the engine cover, there is another tank, on the left rear, most often plastic but aluminum upgrades are available.
If warm, CAREFULLY open that top, I bet it is low or empty.
This is the tank you need to check.
Let us know.
Dave
Ghia
Vanagon
Beetle
4Gears4Tires
That's not the coolant reservoir. The tank behind the license plate is the coolant expansion tank.
You need to take the engine cover off and look at the coolant reservoir. It will be to the left of the expansion tank. The reservoir has the level sensor and if the red light comes on, it most likely means your tank is empty. You will need to take the hose clamp and hose off the cap, and unscrew the cap to add more coolant.
Edit: You will also need to do a coolant pressure test to find out where you are losing coolant from.
tprosser100
PostPosted: Fri Feb 05, 2021 7:08 am    Post subject: Re: Red light and temperature gauge going up Reply with quote
djkeev
djkeev is offline
PostPosted: Fri Feb 05, 2021 6:49 am    Post subject: Re: Red light and temperature gauge going up Reply with quote
3/4 gauge really isn't over heated.
Why is it higher than normal and why the coolant light is on?
What tank did you check the coolant level in and add to?
Dave
Ghia
Vanagon
Beetle
tprosser100
PostPosted: Fri Feb 05, 2021 6:40 am    Post subject: Re: Red light and temperature gauge going up Reply with quote
danfromsyr
danfromsyr is offline
PostPosted: Fri Feb 05, 2021 5:51 am    Post subject: Re: Red light and temperature gauge going up Reply with quote
How the heck are we supposed to know if it's the coolant level or something else. you are the 1st one on the scene..
open the engine compartment and take a look..
and if you don't know anything about (antique) automobiles.
READ THE DANGED MANUAL
tprosser100 wrote:
Today while driving down the freeway my red light came on and my temperature gauge shot up to 3/4. I quickly slowed down and babied it to my destination. Is it possible that my Vanagon can be overheating in temperatures of 20 degrees? I donโ€™t think so but wanted to confirm. Would you think it was my coolant level? Or something else?
Abscate wrote:
These are the reasons we have words like โ€œwankerโ€
djkeev
djkeev is offline
PostPosted: Fri Feb 05, 2021 5:35 am    Post subject: Re: Red light and temperature gauge going up Reply with quote
Yes, vehicles overheat in sub freezing weather.
On older vehicles when a warning light cones on......
STOP NOW !!!
Not in a half mile, not baby it home, STOP!
Older vehicles warning lights are not like the CEL (check engine light) you grew up with. CEL means very little, keep driving.
On an antique they are shouting that you have possibly serious issues NOW.
Check you coolant, see what you have.
Level low?
See how low and check for leaks.
Running an engine without coolant can be catastrophic.
Dave
Ghia
Vanagon
Beetle
AndyBees
AndyBees is offline
PostPosted: Thu Feb 04, 2021 11:19 pm    Post subject: Re: Red light and temperature gauge going up Reply with quote
Not sure how far you drove once you saw the warnings, but you should have stopped immediately (safely of course).
Mostly likely it was overheating with the light and gauge both warning.
So, did you check the coolant level?
'84 Vanagon Tin-top, ALH TDI, two trips to Alaska, 2014 & 16. 1989 Tin-top unmolested.
1983 Air-cool, 225k miles, 180k miles mine, seven trips to Alaska from 1986 thru 2003. 1975 Bay hopeful.
tprosser100
PostPosted: Thu Feb 04, 2021 10:29 pm    Post subject: Red light and temperature gauge going up [solved] Reply with quote
