Big Mike Cbad Samba Member
Joined: December 19, 2019 Posts: 75 Location: Carlsbad
Posted: Sun Feb 28, 2021 7:43 pm Post subject: Re: Ghia steering column parts list 1963 |
Thanks for the tip, appreciate it. _________________ 1963 ghia convertible project |
Starbucket Samba Member
Posted: Sun Feb 28, 2021 4:29 pm Post subject: Re: Ghia steering column parts list 1963 |
If you put the bearing in the freezer over night it will drop in if you don't handle it too long as it will start to expand. |
Posted: Sun Feb 28, 2021 12:42 pm Post subject: Re: Ghia steering column parts list 1963 |
Thank you as always. Is there a specific washer or spacer that goes between the nut for the steering wheel and the turn signal indictor above the circlip? The pics I see look like there is. _________________ 1963 ghia convertible project |
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 4114 Location: In Molinya Orbit
Posted: Sun Feb 28, 2021 1:15 am Post subject: Ghia steering column parts list 1963 |
I'm diving into the restoration of my 63 Ghia vert and ran into another issue. I wanted to paint my steering column and steering tube to clean it up. I disconnected the steering column from the linkage under the fuel tank and pulled the tube and column out from the firewall into the car and removed them together. I ended up with my column and tube and tried to separate them, but they wouldn't separate, After yanking it, the bearings exploded and parts flew everywhere including all the ball bearings.
I guess I blew up the bearing that sits in the steer tube, so looking for a clear pic of all of the parts needed for my 63 Ghia from the steering wheel nut down. I believe I'm missing the plastic washer and will need a new bearing and not sure what else if anything.
I looked at the big Ghia parts list book, but couldn't seem to make sense out of it. Will the bearing kit sold on Wolfsburg West or other resellers fit the Ghia? They are listed as bug parts. Looks like that bearing is tapped into the top of the steer tube then the other parts are mounted on the column and dropped into the tube through the bearing.
Is that correct? Any recommendations on the bearing replacement and does anyone have the part number for the plastic washer?
Thanks in advance. _________________ 1963 ghia convertible project |
