danielheff Samba Member
Joined: January 22, 2016 Posts: 178 Location: San Diego, CA
Posted: Sun Nov 03, 2024 8:15 pm Post subject: Re: Shurflo faucet troubleshooting |
No matter which faucet you test, I'd still recommend using a relay to do the switching of the electrical load. Relays can handle millions of cycles, and if one does fail (I bought very cheap ones) a new one takes seconds to plug in. _________________ '70 Squareback 1835cc
'85 Vanagon GL Camper, EJ22, Peloquin Diff, Burley rear disc brakes, SC big front brakes, Espar D2L, 250ah Lifepo4
'85.5 944 NA |
MsTaboo  Samba Member
Joined: June 02, 2006 Posts: 4581 Location: East Kootenay, British Columbia
Posted: Sat Nov 02, 2024 1:34 pm Post subject: Re: Shurflo faucet troubleshooting |
How about this one from Reimo? Anyone tried yet?
https://vanagonwestfaliaparts.com/collections/reimo/products/electric-auto-faucet
My Shurflo has been working fine for the last ten years but always nice to know about other options. _________________ Currently:
Resist Kleptocratic Oligarchy (and Idiocracy)! |
kourt Samba Member
Joined: August 13, 2013 Posts: 2360 Location: Austin, TX
Posted: Sat Nov 02, 2024 11:58 am Post subject: Re: Shurflo faucet troubleshooting |
Timwhy wrote: |
Has anyone tried this German faucet as a replacement to the Shurflo? |
I used that faucet for the first year of my Eurovan conversion. It eventually failed at the slip joint between the valve body and the riser to the faucet head. It was not very strongly built plastic. I am now using a Shurflo in my Eurovan and am very happy with it.
Here's my post retracting my recommendation.
kourt
The failed faucet:
SCM Samba Member
Joined: January 26, 2011 Posts: 3422 Location: Bozeman MT
Posted: Fri Nov 01, 2024 4:17 pm Post subject: Re: Shurflo faucet troubleshooting |
harvgwen wrote: |
I’m very sure that SCM is right about that. |
Quoted for posterity!
I might just print this out and pin it to my refridgerator for the wife to see. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
Timwhy Samba Member
Posted: Thu Oct 31, 2024 9:22 am Post subject: Re: Shurflo faucet troubleshooting |
crazyvwvanman wrote: |
I first replaced a stock Westy faucet with this same model Shurflo over 25 years ago and it still works.
I did it specifically because it let us adjust the water volume down to the least amount needed for a given job.
We often camped for a week or two at a time with no potable water source nearby so conserving it was essential.
Since then I've put them into many of my family's Vanagons and a bunch of my own as well as friend's vans.
Never had any switch problems that I know of, running the pumps straight from the faucet switch.
If they are now weaker I would just add a relay to keep the benefits of the overall design.
How I always do it is better than the standard way.
For the oversize "washer" I drill the faucet hole offset to put the faucet as close as possible to the Wesyt sink bowl.
This allows the faucet to tip down all the way into the bowl and makes room for our compact tea kettle or other such item to live there while the kitchen lid is stowed.
It is a small thing but a useful improvement over centering the faucet.
Mark |
You can always change the aerator to a .5 gallon one. _________________ '15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
http://www.youtube.com/user/TIMWHY2?feature=mhee |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10413 Location: Orbiting San Diego
Posted: Thu Oct 31, 2024 7:57 am Post subject: Re: Shurflo faucet troubleshooting |
Mark |
harvgwen Samba Member
Joined: February 11, 2021 Posts: 300 Location: Okanagan Valley, British Columbia
Posted: Thu Oct 31, 2024 6:58 am Post subject: Re: Shurflo faucet troubleshooting |
I’m very sure that SCM is right about that. I only ever crank the faucet wide open so as not to overload the pump with excess back pressure. Contrary to GoWesty’s claim, I think it’s a poor design to allow the valve to restrict the flow of water from the pump. _________________ 1986 Westfalia Vanagon, 2.2 Subaru
Okanagan Valley, British Columbia |
Bill D Samba Member
Posted: Wed Oct 30, 2024 12:51 pm Post subject: Re: Shurflo faucet troubleshooting |
Hmmm... maybe that's right... the water flow controlled by a water valved inside the faucet... makes more sense... but if so, restricting flow makes the pump work harder and may make it burn out sooner...
Will check this out...
Maybe I was mistaking the different sound of the pump working harder against the restricted valve for it slowing down due to less current... |
SCM Samba Member
Posted: Wed Oct 30, 2024 12:41 pm Post subject: Re: Shurflo faucet troubleshooting |
Bill D wrote: |
From the GoWesty web page for the Shurflo kit:
"Adds flow regulation! You can control the flow volume, which is way better than the original design's "on/off" options." |
Hmmm, after having the hose blow off of my pump while running the faucet at a slow flow rate, I always assumed the switch was a simple on/off with flow regulation provided by a mechanical "choking down" on whatever oriface the water flows through while passing through the faucet.
In other words, once the faucet turns the pump on, the pump runs at the same speed regardless of the flow out of the faucet. Kind of like kinking a garden hose to reduce the flow rate instead of turning down the water at the spigot.
I could be waaaaay off on that though. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
dabaron Samba Member
Joined: June 21, 2018 Posts: 2736 Location: Philly, mang
Posted: Wed Oct 30, 2024 12:39 pm Post subject: Re: Shurflo faucet troubleshooting |
Bill D wrote: |
Mine had flow regulation before it stopped working, but not now that it's wired to the regulator. Not a big deal. In fact, when it had the flow regulation I was concerned about feeding the pump lower amps than it was designed for. I seem to recall reading somewhere that motors don't like to be under powered and can be harmful to them (like brown-outs for fridge and furnace motors)... but maybe that's for bigger motors than these small pumps? |
flow control is via the ball valve in the faucet. i know this because i jumpered the pump and had the valve closed. as i opened it to different settings, the increased or decreased as a result. _________________ 1991 Vanagon GL Camper
i had no idea i wanted to be a mechanic |
Bill D Samba Member
Posted: Wed Oct 30, 2024 12:27 pm Post subject: Re: Shurflo faucet troubleshooting |
Posted: Wed Oct 30, 2024 12:19 pm Post subject: Re: Shurflo faucet troubleshooting |
Bill, I believe the Shur Flo switch is just on/off, not variable, so the relay makes no difference that way.
And I’ve had the same experience with GoWesty reviews. They make and sell a lot of great products but some of their products are not very good. _________________ 1986 Westfalia Vanagon, 2.2 Subaru
Bill D Samba Member
Posted: Tue Oct 29, 2024 1:13 pm Post subject: Re: Shurflo faucet troubleshooting |
"I installed a new Shurflo in 2011; still running fine to this day... without a relay (*knock on wood*)."
When I pulled mine apart the contacts looked much thinner and less substantial that a previous Samba post photo from several years ago of one torn apart....
Maybe the make the contacts less able to handle the pump amps over the past several years... |
kamzcab86 Samba Moderator
Posted: Tue Oct 29, 2024 11:39 am Post subject: Re: Shurflo faucet troubleshooting |
harvgwen wrote: |
I had a similar experience with mine. It’s just not made to handle the current that the pump needs. |
I installed a new Shurflo in 2011; still running fine to this day... without a relay (*knock on wood*). _________________ ~Kamz
2016 Golf GTI S
Bill D Samba Member
Posted: Tue Oct 29, 2024 10:07 am Post subject: Re: Shurflo faucet troubleshooting |
I think this relay fix, in addition to routing the higher amps thru the relay, also seems to eliminate the variable pump speed/water flow of the original set up? It seems the relay switching is on/off; not variable...
Initial results seem to show that on mine... anyone else? |
Bill D Samba Member
Posted: Tue Oct 29, 2024 9:54 am Post subject: Re: Shurflo faucet troubleshooting |
"In my opinion, the sellers of these faucets should indicate this."
Ha... GoWesty NEVER allows bad reviews to show up on their web site... all the Shurflo reviews are blue sky and perfect happiness...
Geez !!! |
Posted: Tue Oct 29, 2024 6:40 am Post subject: Re: Shurflo faucet troubleshooting |
I had a similar experience with mine. It’s just not made to handle the current that the pump needs. In my opinion, the sellers of these faucets should indicate this. _________________ 1986 Westfalia Vanagon, 2.2 Subaru
Bill D Samba Member
Posted: Mon Oct 28, 2024 8:59 pm Post subject: Re: Shurflo faucet troubleshooting |
Thanks HarvGwen and all for the info.... very helpful !!! And much appreciated...
An interesting note... I forced open the Shurflo switch and could see the contacts, but saw nothing obvious as to why it was not working... no corrosion, not blackened surfaces, all seemed good... Put it back together and it still did not work, hooked it to the relay per instructions here and all of a sudden it works.... strange, but good. |
Posted: Mon Oct 28, 2024 8:30 pm Post subject: Re: Shurflo faucet troubleshooting |
Bill, the reason for the high current draw through 30 to 87 is because it powers the pump. Whatever current the pump draws flows through the relay from 30 to 87. The high current no longer runs through your Shur Flo switch. The low current draw in the 85 to 86 part of the relay is the small amount of current needed to pull the relay switch to the closed position. That small current is what now flows through your Shur Flo switch. The Shur Flo switch isn’t robust enough for the high current that the pump needs. The relay now becomes the switch for the pump. The relay is made to take the higher current.
The wiring diagram provided above is very similar to what I suggested, except that I had the Shur Flo switch on the positive side of the relay. The diagram has it on the negative side. It will work the same. _________________ 1986 Westfalia Vanagon, 2.2 Subaru
Posted: Mon Oct 28, 2024 2:52 pm Post subject: Re: Shurflo faucet troubleshooting |
I don't think that would fit under the Westy sink top. Will it clear the sides enough to allow the top to close?
Reviews say it's pretty flimsy and prone to breaking. _________________ Currently:
