02Berry Samba Member
Posted: Fri May 30, 2025 10:51 am Post subject: Re: upgrade instrument panel lights |
Piggybacking on this conversation.
I want to check and possibly replace my instrument panel dimmer switch ('02 EVW) Rheostat ranges from Off to Very Dim. Too dim for daytime driving.
Is there a step-by-step guide somewhere I can't find? Or would someone give beginner-level advice?
[If it involves pulling the dash, nevermind.]
Thanks! _________________ Learned to drive in a '67 Splitty.
First car, '72 Squareback.
New to '02 T4 EVW world.
Third generation VW camper household. |
RJ95 Samba Member
Posted: Wed Apr 28, 2021 8:12 am Post subject: Re: upgrade instrument panel lights |
smores wrote: |
Depending on your year, it is very difficult to replace the bulbs. They are mostly built into the different modules. (heater, switches, instrument cluster etc. ) My heater control slider light meant cutting heat-staked parts and removing a tiny bulb from a built-in holder and re-threading.
I believe the little bulbs in the instrument cluster are all individual bulbs with no bases. I forget what they're called. But again, very fiddly.
Not to say don't try, but it isn't a walk in the park.
that's for my '93 |
Thanks-- photos would be great! We also wondered what was meant with cutting the heat-staked parts... how did you reassemble? We are novices, but are willing to attempt small repairs and upgrades. again, all advice is appreciated! |
smores Samba Member
Posted: Wed Apr 28, 2021 8:00 am Post subject: Re: upgrade instrument panel lights |
RJ95 wrote: |
Hello,
We have a 95 EVC and are looking for advice related to this topic-- our issue is the lights behind the heat control panel.
Does anyone have experience changing out these lights on our specific year?
If you do and don't mind- please share your experience-- we are wondering how difficult is it to change these bulbs? what parts are needed? tools? part source?, etc
Advice is appreciated!!
Thank you  |
Hi yes. I did that light on my 93. It’s a pain in the butt. I think I took pictures of the process though. Let me look back and post some at lunchtime. |
RJ95 Samba Member
Posted: Wed Apr 28, 2021 7:49 am Post subject: Re: upgrade instrument panel lights |
Hello,
Thank you  |
Whridlsoncestood Samba Member
Joined: November 25, 2020 Posts: 179 Location: Orange, CT
Posted: Tue Apr 27, 2021 7:09 am Post subject: Re: upgrade instrument panel lights |
Agreed on the later models. The cluster is so deep in the dash that on bright sunny days it’s cast in a shadow void and the gauges are nearly impossible to see. _________________ 2001 EV MV |
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12168 Location: Port Manteau
Posted: Mon Apr 26, 2021 2:04 pm Post subject: Re: upgrade instrument panel lights |
Sometimes you can cycle the rheostat rapidly a number of times to clean up any built up corrosion on the contact faces. This happens to older Mercedes, and I often just solder a bridge across to bypass the resister altogether. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
smores Samba Member
Posted: Fri Apr 23, 2021 8:41 pm Post subject: Re: upgrade instrument panel lights |
Joshwa wrote: |
Later Eurovan owners don't realize the poor dim lighting of the early van gauges. Especially when it's bright out. For a while I had a piece of white paper at the base of the gauges that would reflect natural light up into the gauges.
If you do pull your cluster and twist one of those lights out, could you kindly add a picture or part number for that twist out bulb. I will do the same if I get to it first. |
Interesting, maybe like Zeitgeist 13 said related to the rheostat. Mine is a 93 and instrument lights seem quite bright. Maybe broken rheostats that only go part way up.
Or maybe mine go to 11... |
Joshwa Samba Member
Joined: November 18, 2015 Posts: 833 Location: North Seattle WA
Kozmob Samba Member
Joined: September 20, 2015 Posts: 25 Location: Washington
Posted: Fri Apr 23, 2021 8:24 am Post subject: Re: upgrade instrument panel lights |
I saw this youtube video of removing the cluster and the lights. Overall a pretty complex process, but removing the lightes looked pretty east; just a twist with a pair of pliers. https://www.youtube.com/watch?v=RXM7ZreBuuY
smores wrote: |
that's for my '93 |
Kozmob Samba Member
Posted: Fri Apr 23, 2021 8:21 am Post subject: Re: upgrade instrument panel lights |
Zeitgeist 13 wrote: |
Are you sure the dash light dimmer rheostat is turned fully on? |
Hi bud. Yes, it is. I dial the rheostat when in the dark and the lights respond but not bright enough.
Posted: Thu Apr 22, 2021 10:17 pm Post subject: Re: upgrade instrument panel lights |
Are you sure the dash light dimmer rheostat is turned fully on? _________________ Casey--
y u rune klassik? |
smores Samba Member
Posted: Thu Apr 22, 2021 7:02 pm Post subject: Re: upgrade instrument panel lights |
that's for my '93 |
Kozmob Samba Member
Posted: Wed Apr 21, 2021 8:03 pm Post subject: upgrade instrument panel lights |
I cannot see my instruments at times, especially when in sunny or bright light. I'm thinking of upgrading the bulbs in the instrument panel to boost visibility.
I see several youtube vids explaining how to remove the instrument cluster and lights, so I can handle that part. Any bulbs obviously have to be dimmable.
Has anybody here done this? Happy with the results? What bulbs did you use? |
