VicVan Samba Member
Joined: July 01, 2015 Posts: 1936 Location: Vancouver Island, BC
Posted: Sun Sep 18, 2022 9:50 am Post subject: Re: STOLEN: 1986 Westfalia Camper (Gold) in Alameda, CA **FOUND** |
Microbusdeluxe wrote: |
So sorry to hear about these scumbags punching a hole in your gas tank. |
Likewise
Especially when all you need to do is cut a piece of fuel line that comes out of the tank... _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
dobryan Samba Member
Joined: March 24, 2006 Posts: 17131 Location: Brookeville, MD
eghall Samba Member
Posted: Sat Sep 17, 2022 7:25 pm Post subject: Re: STOLEN: 1986 Westfalia Camper (Gold) in Alameda, CA **FOUND** |
@absacate if it were a rare tank, sure, repair is an option. I am assuming you're referencing to filling the tank with c02 and welding it shut. In this case not worth it with a reasonable replacement for 175 bucks. it would take longer and be more trouble than a simple swap. 210 with seals and such. plus now it has no dents, yet.
If you have a novel solution please describe so i can archive that for road fixes.
BTW, Amy is my fantastic wife who reported it on vanalert. i am Eddie, or e.g.
Thanks! |
vanis13 Samba Member
Joined: August 15, 2010 Posts: 4382 Location: ABQ NM USA.... Except when not
Posted: Sat Sep 17, 2022 4:38 pm Post subject: Re: STOLEN: 1986 Westfalia Camper (Gold) in Alameda, CA **FOUND** |
Abscate wrote: |
A gas tank hole is easy to fix, no replacement needed |
Please describe _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
Abscate  Samba Member
Joined: October 05, 2014 Posts: 23814 Location: NYC/Upstate/ROW
Posted: Sat Sep 17, 2022 12:25 pm Post subject: Re: STOLEN: 1986 Westfalia Camper (Gold) in Alameda, CA **FOUND** |
eghall wrote: |
@microbusdeluxe they drilled a 3/8" hole through the bottom of the gas tank to steal my gas, ruining the tank.
@msTaboo thanks. yes, i had a locking gas cap but they overcame that (was original keyed to the rest of the car), then still decided to drill the tank.
Just got replacement tank from buslab yesterday, so im installing that today. i am on the hunt for another original gas cap i can re-key, if anyone out there has one(nothing on classifieds i could find). |
Amy
A gas tank hole is easy to fix, no replacement needed _________________ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ π π π |
Microbusdeluxe  Samba Member
Joined: July 26, 2003 Posts: 1003 Location: Bellingham, WA
Posted: Sat Sep 17, 2022 12:09 pm Post subject: Re: STOLEN: 1986 Westfalia Camper (Gold) in Alameda, CA **FOUND** |
So sorry to hear about these scumbags punching a hole in your gas tank. _________________ '69 Squareback RIP
'65 21 window deluxe sold before the price spike, damn it.
'70 rhd bay now a taxi in South Sudan
'81 Westy sold
'89 hightop Westy Joker syncro 16" now with Bostig! |
eghall Samba Member
Posted: Sat Sep 17, 2022 9:35 am Post subject: Re: STOLEN: 1986 Westfalia Camper (Gold) in Alameda, CA **FOUND** |
MsTaboo  Samba Member
Joined: June 02, 2006 Posts: 4548 Location: East Kootenay, British Columbia
Posted: Tue Sep 13, 2022 10:47 am Post subject: Re: STOLEN: 1986 Westfalia Camper (Gold) in Alameda, CA **FOUND** |
What does this mean? "of course they drilled the gas tank" Thanks |
Locking gas cap?
To the owner - glad you got your rig back, hopefully not badly damaged.
Good luck to you and bad karma to the scumbags who stole! _________________ Currently:
All that's needed for evil to prevail is for good people to do nothing.
Resist Kleptocratic Oligarchy (and Idiocracy)! |
Posted: Tue Sep 13, 2022 10:43 am Post subject: Re: STOLEN: 1986 Westfalia Camper (Gold) in Alameda, CA **FOUND** |
What does this mean? "of course they drilled the gas tank" Thanks _________________ '69 Squareback RIP
'81 Westy sold
eghall Samba Member
Posted: Mon Sep 12, 2022 7:27 pm Post subject: Re: STOLEN: 1986 Westfalia Camper (Gold) in Alameda, CA **FOUND** |
@cmayna thanks for the kind words. good to have her back, slightly worse for the wear but i'll count myself lucky, i know i am.
@vanis13 that is good info. i have to look into my setup. IIRC i used the ECM interface for the ej22 but am reconsidering for obvious reasons. set it and forget it would have saved my skin last time, i am not keen to repeat this experience again. lesson learned. Not knowing if my hand-built machine its on fire somewhere or being parted out was hard, very hard.
@schnippzle thats a fancy tracker system. thanks for details. i did something more basic, but now have satellite connectivity and backup system.
also for what its worth the fuel pump circuit method is more effective in my experience, since after the scumbags tripped the kill switch and it 'broke down' it had them thinking it was a malfunction, so they added a gallon of oil to the motor, a gallon of trans fluid (auto) and tried to spray start fluid (and disconnect the MAF) into it to no avail, so i am a believer in this approach over the no start circuit, which puts them in your wiring right away. they only got 16 miles on the clock before the twitchy fingers saved my bacon, so hoping for good outcome in terms of mechanicals. of course they drilled the gas tank, so until i get a new one from BL i cant test. this will take time. |
Posted: Tue Sep 06, 2022 3:17 am Post subject: Re: STOLEN: 1986 Westfalia Camper (Gold) in Alameda, CA **FOUND** |
vanis13 wrote: |
fxr wrote: |
You only need one relay for the fuel pump ground switching. Coil is powered from the 'key in' circuit, grounded by a momentary switch to trigger it, but also by the switched contact in the relay, with the NO contact permanently grounded. That switched contact also grounds the fuel pump.
This always arms the kill switch when the key is removed. |
And Disarms it if a key (or maybe a screwdriver?) is inserted? |
If Iβm reading this right, no. Key/object in. Momentary ground toggle required _________________ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ π π π |
Posted: Mon Sep 05, 2022 7:33 pm Post subject: Re: STOLEN: 1986 Westfalia Camper (Gold) in Alameda, CA **FOUND** |
fxr wrote: |
And Disarms it if a key (or maybe a screwdriver?) is inserted? _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
fxr Samba Member
Joined: December 07, 2014 Posts: 2641 Location: Bay area CA
Posted: Mon Sep 05, 2022 6:56 pm Post subject: Re: STOLEN: 1986 Westfalia Camper (Gold) in Alameda, CA **FOUND** |
This always arms the kill switch when the key is removed. _________________ Jim Crowther
Vespa GTS 300 |
Posted: Mon Sep 05, 2022 4:55 pm Post subject: Re: STOLEN: 1986 Westfalia Camper (Gold) in Alameda, CA **FOUND** |
vanis13 wrote: |
Set it up to automatic engage and never forget again! |
I got a PM asking about this. this is the reply I sent:
The recent links in search will have various approaches.
1) simple - put in a relay to disconnect the starter trigger wire unless a "special" button/switch/action sends power to the relay to allow the starter trigger wire to send the start signal. relay is always off (kill switch active) and only on temporarily when "special" button is pressed.
2) more complex (usually for fuel pump but can also be for starter) - there is a 2-relay system that when activated by "special" button keep the relay active until car is shut down. Important on fuel pump kill since it needs to keep running.
I like #1 for simple and van doesn't move unless it starts and no chance of fuel pump turning off due to a bad relay. But it gives the thief time to just rummage through the car where its parked.
I also have VanTracker set up that I get a text EACH time my door is open. so I get notice if someone entered my van (like to steel stuff) even if it doesn't move.
Some folks like #2 since van starts from fuel in system and then dies so thief thinks it just broke down (partially out of parking lot/middle of the road) and may be likely to abandon the vehicle since it is much more suspicious. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
Schnippzle Samba Member
Joined: February 04, 2021 Posts: 288 Location: Swede in London, UK
Posted: Mon Sep 05, 2022 4:05 pm Post subject: Re: STOLEN: 1986 Westfalia Camper (Gold) in Alameda, CA **FOUND** |
vanis13 wrote: |
cmayna wrote: |
. Now, even at home or at a store, or whereever, it get's flipped. . |
ONLY in you remember to flip it!
Even with auto engage, you can manually disengage it like if you give you van to a shop so they don't need to know your kill switch info. |
These are some of the reasons why I really like the ScorpionTrack system I have installed on both my daily and the motorbike. It requires a specifically programmed fob to start the vehicle. If three starts are attempted without the fob, the police are alerted by ScorpionTrack immediately. Then, if either vehicle starts to move without being switched on, ScorpionTrack will track and relay the vehicle location to the police.
I do have the option to disable this in the app on the phone, for servicing, transportation, etc... _________________ 1988 Caravelle - FB25B - Syncro converted
2016 MB E63 AMG S - The daily driver
2019 Harley Davidson FXFBS Fat Bob - The leisure |
Posted: Mon Sep 05, 2022 3:52 pm Post subject: Re: STOLEN: 1986 Westfalia Camper (Gold) in Alameda, CA **FOUND** |
cmayna wrote: |
Even with auto engage, you can manually disengage it like if you give you van to a shop so they don't need to know your kill switch info. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
cmayna Samba Member
Joined: August 18, 2014 Posts: 1173 Location: SF Bay area, CA
Posted: Mon Sep 05, 2022 3:23 pm Post subject: Re: STOLEN: 1986 Westfalia Camper (Gold) in Alameda, CA **FOUND** |
Aha! So I was right!
When I installed my kill switch, I had to deal with deciding on the switch's location as being convenient or way outa the way, making me too lazy to flip it.
Finally found a good spot. Now, even at home or at a store, or whereever, it get's flipped. And yes, I also have a tracker.
Again, Very glad you folks got yours back. _________________ '90 Westy / automatic.
If I'm not working on the camper or my '50 Chebbie truck, I'm either fishing with the wife or smoking Salmon.
Craig |
eghall Samba Member
Posted: Mon Sep 05, 2022 2:44 pm Post subject: Re: STOLEN: 1986 Westfalia Camper (Gold) in Alameda, CA **FOUND** |
Yes, the vehicle had a kill switch. No i didn't have it killed when i parked last. That's why we didn't say it had one, because they did not overcome it. I typically used it only if i'm in a sketch area or a trailhead, turns out home is now a sketch area. The thieves inadvertently turned it on, as it is similar to some setups on the forums here and easy to turn on if you don't know what it is.
So it worked, kinda, since it didn't move after they did that and likely the reason i found it.
Sorry if it caused confusion, my wife posted to vanalert since i was out of town at the time. Abel, if it helps feel free to update it, or let me know how. |
Posted: Mon Sep 05, 2022 1:47 pm Post subject: Re: STOLEN: 1986 Westfalia Camper (Gold) in Alameda, CA **FOUND** |
Californio wrote: |
when it happens to your city... |
Elected officials make the policy the population votes on.... We have no one other than ourselves to blame.... And the special interest groups have pull because they advocate - even if they are in the actual minority but in perceived majority. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
Californio Samba Member
Posted: Mon Sep 05, 2022 1:28 pm Post subject: Re: STOLEN: 1986 Westfalia Camper (Gold) in Alameda, CA **FOUND** |
Now if we could just do something about the thousands of tweakers and crazies living in the encampments. I'm from Oakland, still own a house there, and dread the idea of going back. Yes, I have a kill switch but of course the cat is just hanging there waiting to be stolen...distressing when it happens to your city... |
