Toadranger Samba Member
Joined: June 06, 2007 Posts: 7 Location: Nashville, TN
Posted: Fri Sep 13, 2024 7:48 am Post subject: Re: Wheel size versus maximum speed |
Hi gang-
Upgrading wheels and tires for 1988 tintop 2.1l automatic. She came with 15" Mercedes rims with 205/65 R15 Kumho Solus tires. The Gowesty 16X7.5 Alloy Wheels ET23 just arrived.
I have had recommendations from friends from 205/65R16, 215/60R16 to 215/65R16 and want to be careful not to add too much stress the tranny and stock motor. I have made tweaks here and there but nothing to add much HP.
Just hoping for a better cruising speed/efficiency for level terrain, perhaps not to exceed 27" diameter.
I live in TN with mostly modest hills but will need to cross the Appalachians on occasion.
What have others done/experienced in this scenario? Any particular brands/models with appropriate load ratings?
Thanks for your time and advice...dw
88 tintop Wolfsburg Evangeline |
?Waldo? Samba Member
Joined: February 22, 2006 Posts: 10153 Location: Where?
Posted: Tue Nov 01, 2022 8:05 am Post subject: Re: Wheel size versus maximum speed |
| IdahoDoug wrote: |
| Or, he's using larger than stock tires and reducing his ability to brake? |
Notice that I mentioned I was using 27" diameter tires and was still able to lock them up. 27" are almost as large as you can fit without modifying the trailing arms.
I have only locked up the tires on one panic stop. I was on a 4-lane + center turning lane road going 35. I was in the left lane when someone pulled out of a fuel station into the right lane just ahead of me going the same direction I was going. When they were up to speed, I was just behind their rear driver's side corner. Without any warning or blinker (or looking behind them!), they decided to do a U-turn from the right lane, through my lane, and into the center lane! I literally stood on the brake pedal and applied the maximum force I possibly could to the pedal. In normal brake testing situations I never even attempt to press that hard, illogically enough, because I am afraid of bending/breaking the pedal assembly or bursting a brake line/cylinder. I say 'illogically' because it would be far better to break one of those components during testing than it would be to have them fail in a panic stop. It is very hard to overcome that reluctance to press as hard as you possibly can, though! Intentionally jamming yourself into the seat belt (or sending yourself into the windshield) also isn't any fun.
| dobryan wrote: |
| If you cannot lock up the brakes then the BMW brake booster may give you the extra assist you need. |
I believe the BMW booster would reduce the stress on the pedal assembly and reduce the overall pressure you need to apply to the pedal for a given braking force. However, if there is any air in the lines or if the rear adjusters are not working properly (does your e-brake ever need more than two clicks for full pressure?) then you will bottom out the master cylinder before reaching maximum braking force and will have no hope of locking up the wheels regardless of whether the BMW booster is installed. The van I was driving when I locked up all four wheels did not have the BMW booster installed. |
dobryan  Samba Member
Joined: March 24, 2006 Posts: 17355 Location: Brookeville, MD
Posted: Tue Nov 01, 2022 7:23 am Post subject: Re: Wheel size versus maximum speed |
| chrissev2 wrote: |
| Quote: |
| You've nailed it in terms of experiencing that a larger tire height/diameter/circumference is not a performance enhancement on your particular van given the AAZ and taller 3.27 R&P. |
Very much so.
I found that the AAZ combined with the modified 3spd with 3.27 RP in the vanagon actually results in acceleration and top speed which is acceptable considering the age of the vehicle and the limitations of a non-TDI diesel motor.
Particularly the space between 50km/hr and 90km/hr is quite good with acceleration.
The taller wheel and tire height just completely ruined it. Also as noted above, the pedal position gets very messed up with the automatic "kick down" and the transmission shifts back and forth from second to third in an erratic manner. I did read up on this and apparently this is a problem in general with automatics when you are messing around with wheel and tire height. You change the position of the pedal for "kick down" and upshift, which can make for a very sloppy driving experience. |
Just to beat on this dead horse. Please do not refer to wheel height at all. It is tire height/diameter only that impacts this. I know you that you get it, and old habits die hard.  _________________ Dave O
The Western Syncro build
chrissev2 Samba Member
Posted: Tue Nov 01, 2022 7:05 am Post subject: Re: Wheel size versus maximum speed |
| Quote: |
Very much so.
The taller wheel and tire height just completely ruined it. Also as noted above, the pedal position gets very messed up with the automatic "kick down" and the transmission shifts back and forth from second to third in an erratic manner. I did read up on this and apparently this is a problem in general with automatics when you are messing around with wheel and tire height. You change the position of the pedal for "kick down" and upshift, which can make for a very sloppy driving experience. _________________ 2024 GLI Jetta 6spd manual
2023 VW Atlas 3.6 VR6 Highline
1978 Volkswagen super beetle convertible
1992 Eurovan 2.5 5spd westfalia |
jimf909 Samba Member
Posted: Tue Nov 01, 2022 6:55 am Post subject: Re: Wheel size versus maximum speed |
| chrissev2 wrote: |
| ?Waldo? wrote: |
Why do you keep talking about rim sizes? As others have mentioned, the rim size is irrelevant to the gearing. The tire circumference is what affects the gearing. A larger rim size with a smaller tire circumference (shorter sidewall) can result in shorter overall gearing than a small rim size with a larger tire circumference (larger sidewall). I personally prefer larger rims with shorter sidewall tires as it reduces sway at the expense of a slightly (almost imperceptibly) harsher ride.
For example, one van of mine has 16" rims with 26.5" diameter tires and another has 14" rims with 27" tires. Obviously the 14" rims with 27" tires result in TALLER gearing than the 16" rims with 26.5" tires despite the 14" rims being two inches shorter. |
This is true.
I should be speaking of wheel height I guess.
I tried out 25.3 inches tall as against 22.7. The difference is quite unbelievable. It really effects the gearing. |
Wheel v. Rim v. Tire is a question of semantics and can lead to confusion, much like an engine 'turning over' means different things to different people. 'Wheel' commonly refers to the steel/alloy/composite thing that bolts to the car. The tire is the rubber thing that mounts on the wheel and is a factor in determining engine rpm/wheel rpm ratio that was a factor in your experiential observations. For example, GW, Tirerack, etc. sell 'wheel and tire' packages. Words can be confusing and their definitions can be fluid over time.
GW Wheel and Tire pkg
https://gowesty.com/collections/wheels-tires-accessories/products/16-wheel-tire-package-eurovan
https://unitedtire.com/blog/view/what-s-the-differ...%20wheels.
https://www.google.com/search?q=what%27s+the+diffe...s-wiz-serp
You've nailed it in terms of experiencing that a larger tire height/diameter/circumference is not a performance enhancement on your particular van given the AAZ and taller 3.27 R&P. _________________ - Jim
| Butcher wrote: |
| This is the main fault with DIY'ers, they get together on these forums and pat themselves on their backs spreading bad information. |
Guilty as charged.
DuncanS Samba Member
Posted: Tue Nov 01, 2022 6:14 am Post subject: Re: Wheel size versus maximum speed |
205 65 16s--4% increase in diameter over stock wheels. At the time of the accident, they were stock 14" rims and tires.
Duncan |
Posted: Tue Nov 01, 2022 5:48 am Post subject: Re: Wheel size versus maximum speed |
OK, going out today and will try to lock the brakes. 3400 pound, '91 tarptop (47" x 77" of steel replaced with canvas--only the drivers seat aboard.)
There was one time when in a dire emergency, I stomped as hard as I could. Don't remember any tire squeal and after I had calmed down and got out to look, there were no skid marks on the pavement. New rotors, pads, drums, shoes, brake lines at the time. But before the top came off and I had 1000 pounds of tools and gear aboard. The final stop was abrupt, but because of an earth berm, not the brakes. Abrupt enough that the A/C, without the side supports in place, came down.
Duncan |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10356 Location: N. Idaho
Posted: Mon Oct 31, 2022 10:25 pm Post subject: Re: Wheel size versus maximum speed |
Or, he's using larger than stock tires and reducing his ability to brake? Yes, you should be able to lock the tires on dry pavement of a car you are operating on the public roadway.
It may well be that you are also simply a good driver and can't recall ever having locked the tires because you pay attention, drive wisely, don't get into situations with too much speed, and a Vanagon is a bit of a slug and doesn't encourage sporty driving (!). But if tomorrow you TRIED to lock them, I'd hope you could.
And agree it's nothing to do with rim size - the factor that affects power, braking, and handling is the larger tire diameter. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1993 Toyota LandCruiser, 2002 BMW 325iX, 1982 Toyota Sunrader |
Posted: Mon Oct 31, 2022 10:55 am Post subject: Re: Wheel size versus maximum speed |
| You are the common denominator of those 7 or 8. That doesn't make it impossible, just not something you have been able to do. It could be a matter of reduced foot pressure or a matter of maintenance. |
Posted: Mon Oct 31, 2022 9:52 am Post subject: Re: Wheel size versus maximum speed |
Opps--Posted to the wrong topic. Sorry. Interesting you can lock your brakes. I never have been able to any of my 7 or 8 T3s.
Duncan |
Posted: Mon Oct 31, 2022 9:32 am Post subject: Re: Wheel size versus maximum speed |
| DuncanS wrote: |
| If you can lock the wheel at 200, then for the normal guy, that's good enough. Our problem is we can't. |
As I mentioned in my last post, I have locked up all four wheels on dry pavement with stock brakes and 27" tires. |
Posted: Mon Oct 31, 2022 9:25 am Post subject: Re: Wheel size versus maximum speed |
Sorry, hit "submit" instead of "preview".
So, note the difference in size between the discs in the bike. Why is there a bigger one on the front wheel?
The reason for this is to get better braking on the front wheel. If what the guy says in the video is correct, then why do they use a bigger brake?
And this one also from the video. Stock passenger car on top and race car on the bottom.
Scaling off the pics, I measure 23mm for the stock car and 30 for the racing car in terms of distance from the center of the wheel to the point where the brake pads make contact. This is a 30% increase and thus a thirty percent increase in the length of the lever arm. For the sake of argument, let's assume the pressure is identical. But what is different, is the effective ability of the brakes to stop wheel rotation? Say, for example, the torque on the stock brake is 200 foot pounds. For the race car it would be 260 foot pounds. If you can lock the wheel at 200, then for the normal guy, that's good enough. Our problem is we can't. And thus, any way to get more torque on the wheel is necessary. In fact on a Vanagon, it's vital--especially in a loaded Westy or a tin top filled with tools, rocks, or a 400 HP marine diesel engine.
Duncan |
Posted: Mon Oct 31, 2022 9:14 am Post subject: Re: Wheel size versus maximum speed |
Why can't you lock up your brakes? How hard have you actually tried?
In a panic stop I've locked up all four tires on dry pavement with stock brakes, 27" tires and ~1000 pounds of tools in the back. Granted I was literally standing on the brake pedal... |
Posted: Mon Oct 31, 2022 9:05 am Post subject: Re: Wheel size versus maximum speed |
Watched the "Why trigger brakes won't stop you faster" video.
Completely disagree for Vanagons. First of all we can't lock up brakes as there isn't enough pressure to seize the wheel. So this means adhesion to the road surface and the explanation of size of the pad don't mean anything. There are two ways to increase the braking effectivity for Vanagons. One would be to increase the pressure on the brake cylinder so there is greater friction on the disc/drum. The second is to increase the disc diameter--i.e. bigger brakes.
Take a look at these two screen shots taken from the video |
Posted: Mon Oct 31, 2022 8:58 am Post subject: Re: Wheel size versus maximum speed |
| With the automatic trans it might have a more significant effect than with a manual as will not only affect the power for a given speed but will also affect the accelerator position required for a given speed/load, and the accelerator position is used as an input for the trans in determining shift points. |
Posted: Mon Oct 31, 2022 8:27 am Post subject: Re: Wheel size versus maximum speed |
| ?Waldo? wrote: |
This is true.
I tried out 25.3 inches tall as against 22.7. The difference is quite unbelievable. It really effects the gearing. _________________ 2024 GLI Jetta 6spd manual
jlrftype7 Samba Member
Posted: Mon Oct 31, 2022 8:23 am Post subject: Re: Wheel size versus maximum speed |
| do.dah wrote: |
| I think by the mid to late 80's, no vehicle manufacturer was using 14 inch wheels on their trucks/vans besides VW. |
If I'm remembering correctly, BMW used 14" rims pretty often except for special models or like the often hated TRX tire package, which were 390mm rims I think. Going into the early 90's, they moved up to other rim sizes, with 15" being the 'new' small rim. I think the 325ix E-30 used 15" rims versus its regular E-30 cousins with their 14" rims. M3 was probably unique as well.
Someone else can chime in with the way back machine for Rim sizes...  _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
Posted: Mon Oct 31, 2022 7:27 am Post subject: Re: Wheel size versus maximum speed |
Posted: Mon Oct 31, 2022 6:47 am Post subject: Re: Wheel size versus maximum speed |
| do.dah wrote: |
I still remember my old 1979 diesel rabbit with it's 13 inch rims and the 1.5 litre 48hp engine. VW used very small rim sizes on its vehicles. _________________ 2024 GLI Jetta 6spd manual
