bobbyblack  Samba Member
Joined: May 21, 2015 Posts: 4687 Location: United States, Iowa
Posted: Wed Mar 08, 2023 8:10 am Post subject: Re: 132AH LiFePO4 easily fits inside the battery box |
PSA:
My driver side 'house' battery box has no "drains." any moisture that goes down there, at least in my case, stays in there until it evaporates.
If your house battery box is also like mine, consider adding weep holes, or such.
Finding this out, in my case, was NOT FUN AT ALL. Most likely I spilled a flimsy cup of water below my left elbow backwards, and the liquid ended up in the box with nowhere to go. However, I am not 100% sure I actually did that, it is just the only explanation I have for a self-caused inch or so of water down in there. I had also, in the same time frame, driven through some of the worst sloppy wet 7" snow storm I have done in my bus, and there could have been another way for liquid intrusion. It was water, not tea, and those are the only things I drink while driving. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
fxr Samba Member
Joined: December 07, 2014 Posts: 2677 Location: Bay area CA
Posted: Thu Feb 09, 2023 5:08 pm Post subject: Re: 132AH LiFePO4 easily fits inside the battery box |
| loganthecyclist wrote: |
| fxr wrote: |
| If the big thick wire on the left is the battery negative, why is there another wire connected to the same post of the shunt? The battery negative should be the ONLY connection to the shunt input post, so that all current flows through the shunt. |
The thick wire on the left side of the shunt goes to chassis ground. The battery negative is connected to the right side of the shunt. |
Oh yes! A senior moment - I didn't even read the excellent labels...  _________________ Jim Crowther
Vespa GTS 300 |
BrownLoaf Samba Member
Joined: January 21, 2021 Posts: 112 Location: Bellingham, WA
Posted: Wed Feb 08, 2023 7:45 pm Post subject: Re: 132AH LiFePO4 easily fits inside the battery box |
| fxr wrote: |
The thick wire on the left side of the shunt goes to chassis ground. The battery negative is connected to the right side of the shunt. _________________ 83.5 Vanagon Riviera WBX 2.2 "Brown Loaf"
87 Vanagon Syncro Tin Top WBX 2.1 "Bubbles" |
fxr Samba Member
Posted: Wed Feb 08, 2023 9:50 am Post subject: Re: 132AH LiFePO4 easily fits inside the battery box |
If the big thick wire on the left is the battery negative, why is there another wire connected to the same post of the shunt? The battery negative should be the ONLY connection to the shunt input post, so that all current flows through the shunt. _________________ Jim Crowther
Vespa GTS 300 |
Posted: Tue Feb 07, 2023 9:32 pm Post subject: Re: 132AH LiFePO4 easily fits inside the battery box |
This evening I made the new negative cable and installed it.
I'm excited to finally have a proper house battery system in the camper, and one that can be expanded upon!
Cheers,
Logan _________________ 83.5 Vanagon Riviera WBX 2.2 "Brown Loaf"
Posted: Mon Feb 06, 2023 8:46 pm Post subject: Re: 132AH LiFePO4 easily fits inside the battery box |
| 1988M5 wrote: |
Your shunt isn’t hooked up correctly. Easy fix though, remove the most rearward connection to the negative buss bar and attach it to the shunts forward post. Remove the short jumper from that same post. Then add a jumper from the shunts rear post to the negative buss bar. In essence you want any and all electricity to have to flow through the shunt.
BK |
BK, thank you for catching this and for providing the explanation! I now understand that the loads on the negative bus were bypassing the shunt.
Once I make a trip to the local marine store for some more cable lugs, I'll make the new cable and install it between negative bus and 'system minus' side of the shunt.
1988M5 Samba Member
Joined: January 23, 2016 Posts: 848 Location: Tucson, AZ
Posted: Mon Feb 06, 2023 3:57 pm Post subject: Re: 132AH LiFePO4 easily fits inside the battery box |
To quote page 9 of the manual (https://www.victronenergy.com/upload/documents/SmartShunt/9172-Manual_BMV_and_SmartShunt-pdf-en.pdf)
“ Note that there should be no other connections on this side of the shunt or on the negative battery terminal. Any loads or chargers connected here will be excluded from the battery state of charge calculation.”
FYI
BK _________________ 1991 tin top GL
Some BMWs. |
1988M5 Samba Member
Posted: Mon Feb 06, 2023 2:46 pm Post subject: Re: 132AH LiFePO4 easily fits inside the battery box |
Some BMWs. |
Posted: Mon Feb 06, 2023 6:07 am Post subject: Re: 132AH LiFePO4 easily fits inside the battery box |
Here is the Redarc powered on for the first time, engine running.
Getting the full rated 25 amps! After running for a few minutes, the current dropped to 0 amps, as it should for LiFePo4 being brought to full charge.
Posted: Mon Feb 06, 2023 6:02 am Post subject: Re: 132AH LiFePO4 easily fits inside the battery box |
Thanks for the info on your setup Bobby. Looks great!
To keep the battery warmer and more cushioned, I put down a layer of reflective floor underlayment. This, plus the plastic battery enclosure, will act as a thermal break from the cold sheet metal in the wheel well.
I finished this battery phase of my electrical project over the weekend. Well, "finished" for now anyways. I may go back and add a battery heater, and I will likely be adding a portable solar panel connected to the Redarc charger in the future. One step at a time since I'm doing all this for the first time...
Completed layout under the driver's seat:
I've read that the Redarc charger can get hot, so I spaced it off the panel to provide extra airflow.
System overview, all cleaned up before reinstalling the seats. By trimming the upper shell of the Riviera battery enclosure, I was able to get it to fit! The LiFePo battery now lives in an insulated enclosure, and the hinged lid can still close.
Posted: Tue Jan 31, 2023 1:20 pm Post subject: Re: 132AH LiFePO4 easily fits inside the battery box |
Okay, so you didn't ask for it, but I threatened... so here is my "all in" draw, includes CDH heater on full blast, a couple of fans, my inverter powering my router, which is fed through USB tether, and the TV. 8.5 amps! Comfy!
The old girl didn't like -15F this AM very much though.
Posted: Tue Jan 31, 2023 9:12 am Post subject: Re: 132AH LiFePO4 easily fits inside the battery box |
Bobby, you've inspired me to go back to researching battery heaters. Thank you for the information. Is there a Samba thread for yours? |
Logan, not an exclusive one, sorry. However, I did contribute to this thread with the information you might find useful:
PWM's I use in a number of locations:
https://www.amazon.com/dp/B089273KVZ?psc=1&ref=ppx_yo2ov_dt_b_product_details
https://www.amazon.com/gp/product/B00RWI0O4A/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Snap disk:
https://www.amazon.com/gp/product/B0026S6WGK/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
https://www.thesamba.com/vw/forum/viewtopic.php?t=...;start=120
| bobbyblack wrote: |
Its been quite a good weekend. Weather outside was great, but I spent the daylight hours in my garage installing my LiFePO4 house batter system. I had a lot of 'thinky time' so the 14 or so hours I was "Working on it [Honey]" should have been more like 6?
Wires are hard. Fear is REAL. Triple checked everything and when I finally set the breaker, and it didn't pop and did power up the fuse panel and inverter, I was relieved.
Here are a few things I did:
Heater pad under battery location (driver side)
Stowed Victron 5A AC charger under driver seat.
Got frustrated sticking my head in the cupboard and decided to make a easily removable sub panel to mount the inverter and fuse panel.
Used some roofing rubber to make a flappy box to both secure and isolate the cells.
And turned on the Reactor!!
D pillar DC-DC charger / Breaker setup. I couldn't figure out how to use the Orion's 'switch' so I added a relay. I ran a blue/white wire along with my #8 up behind the cabinets, and hooked it to the blue wire on the Westy kitchen relay.
Cheers !!!
-bobby |
Here is what I did for my CDH. I am going to turn it around and put the heat output up to the Westy Stove plate like dobryan and others soon.
https://www.thesamba.com/vw/forum/viewtopic.php?t=...;start=860
https://www.thesamba.com/vw/forum/viewtopic.php?t=...start=1200
i
| dobryan wrote: |
Here is how I routed the silicone wire reinforced tubing in the kitchen unit. My heater is mounted under the floor where the propane tank used to be. I have a 'Y' as soon as it comes thru the floor of the kitchen unit. One goes to the faceplate as shown above. The other exists at the back of the kitchen unit woith a free standing vent cover.
On my syncro project I'll put the heater in the cubby next to the kitchen unit and run the tubing from there.
https://www.thesamba.com/vw/forum/viewtopic.php?p=9354250&highlight=kitchen#9354250 |
More interesting pix, Brandon/Dave, I think
Posted: Tue Jan 31, 2023 7:15 am Post subject: Re: 132AH LiFePO4 easily fits inside the battery box |
Here is a list of my costs on this project.
Cells: $438
BMS: $159
Tools and consumables (will be used for other projects):
Tapes: $45
Variable power supply: $68
Here is what the Overkill Solar BMS phone app looks like while powering a spare headlight bulb. It provides an impressive amount of information and adjustability to the settings.
I have not done a capacity test to see how close to 132ah the cells are. I have a Victron shunt coming which I hope will give me more insight into total capacity while in use.
Bobby, you've inspired me to go back to researching battery heaters. Thank you for the information. Is there a Samba thread for yours? _________________ 83.5 Vanagon Riviera WBX 2.2 "Brown Loaf"
Mateo83 Samba Member
Joined: September 14, 2021 Posts: 647 Location: Lodi, CA
Posted: Mon Jan 30, 2023 4:27 pm Post subject: Re: 132AH LiFePO4 easily fits inside the battery box |
What's the cost for that battery setup? Sorry if it's in the post, I don't have the attention span to read through it all.
Also, VMAX 75ah fits fine. _________________ 83 Air-cooled 2.0 Tin Top |
Posted: Mon Jan 30, 2023 1:45 pm Post subject: Re: 132AH LiFePO4 easily fits inside the battery box |
Just wanted to mention that I like to have a rest at my "lunch hour" and that is mainly why I drive my bus (nearly) every day -- at least to work, anyway. On the other days, I drive it just because I LIKE to.
In the build I was (still am?) working on, I did not yet add a compressor fridge to the "cost equation" for the battery I decided on, which back then being aprox. the same physical size as your cells, but 120aH. My intention was to be comfortable in cold weather. The world was bringing together several low cost options for both LFP cells, and CDH heaters. Well, today being -3F and that not being unusual around here in winter, I took a look at my consumption as I got into nap mode at lunch. Hmmm.. the same BMS as OP uses showed my cells sitting at -1.5C, which I don't like. Fortunately, I have my adjustable PWM that offers variable power to the heater mat and I bumped it up from 20 watts to just under 30 watts, and then took a nap. The BMS reported that the temp had gone up to +0.3C in just under an hour. I like that I can control the mat heater to raise the temp of the battery slowly.
My total wattage on the heating system at "idle" is 40 watts, including the battery heater. Total at heater full blast is 60 watts. I didn't turn on my bus router, plug in my cell phone to deliver USB tethering or turn on the TV, so that will have to wait for tomorrow, if anyone wants to hear how much power all that uses if I were throwing all my draws at it I did try out my Starlink with the system when I first got it. That would have provided about 10 hours of entertainment time on one charge of the battery. My use of a USB tethered router makes more sense to me than lugging Dishy around.
At ~60 watts, my BMS reports about 28 hours left, after keeping the bus warm since 7 AM until noon, not that it was at full heat production the whole time, but if it were somehow to get a LOT colder and need to keep going full blast for the rest of the time until I got back into the garage that is what I was seeing. The BMS says 15aH used from 7AM through 12:50 PM. I am so tickled
The 2KW CDH with AfterBurner easily keeps the bus at 68F in this weather.
PS. I do know how to be humble, I just don't show it very often  _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Butcher Samba Member
Joined: December 05, 2015 Posts: 1282 Location: Right Here
Posted: Mon Jan 30, 2023 8:16 am Post subject: Re: 132AH LiFePO4 easily fits inside the battery box |
Did you capacity test the batteries or accepting the sales pitch as fact?
Good to hear that you got your batteries without any hitch. Aliexpress does have a lot of crooks and it appears Aliexpress really does not care. I suspect they do, but with as many as they have, it appears not. |
dobryan  Samba Member
Joined: March 24, 2006 Posts: 17292 Location: Brookeville, MD
Posted: Mon Jan 30, 2023 6:34 am Post subject: Re: 132AH LiFePO4 easily fits inside the battery box |
| MarkWard wrote: |
2 quick questions. How do you access your BMS to monitor? The other question is, does your BMS display all 4 battery voltages?
I did something similar with AGM batteries and within a year, one battery took out the other 3 and my Xantrex charger inverter. I had no way to measure individual batteries or to easily isolate them for testing. Thanks. |
That BMS has a bluetooth interface, the little dongle with the blue light on top of the battery, and all data can be read from an app on your phone as long as you are within Bluetooth range of the battery. _________________ Dave O
The Western Syncro build
MarkWard Samba Member
Joined: February 09, 2005 Posts: 19062 Location: Retired South Florida
Posted: Mon Jan 30, 2023 6:10 am Post subject: Re: 132AH LiFePO4 easily fits inside the battery box |
Posted: Sun Jan 29, 2023 5:48 pm Post subject: Re: 132AH LiFePO4 easily fits inside the battery box |
Just a couple things I went through, so as to add to your growing list.
1: No idea where you might go on your travels, but I go where not many are willing, and those places get cold, really cold. The battery box under the DR seat gets REALLY cold REALLY easy. Just get something under there BEFORE you have to take it all apart again. I got a 250 watt matt used for a 3D printer heater plate, its roughly the same footprint as those cells you have. I use a PWM to limit the wattage going into the heater pad, and I have a "on at 32 (or below) and off at 45F "snap disk" rigged up. Life saver. Or, more directly, while driving into a really bad cold front that dropped about 50F in 2 hours, the PWM shut everything down, so then I had to scramble. It was very uncomfortable. I can't find the exact item online just now, but VERY useful.
2: Compress the cells, or rather, don't let them "bloat". I did not incorporate a compression scheme in my battery box setup, and one of the cells has bloated, and is now the one that the BMS reports to be undervolt vs the other three. Therefor, I am now facing premature degradation. It is extremely difficult to replaced just ONE CELL.
Looks like you are on the right track for your present needs. Faith, love, and duty; you will soon find at least one leg of the tripod gets changed; think forward on when the Fridge needs to get bigger
-bobby _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
JEL91Westy Samba Member
Posted: Sun Jan 29, 2023 5:46 pm Post subject: Re: 132AH LiFePO4 easily fits inside the battery box |
Excellent post. What was your total cost?
Joe _________________ 91 Westy
85 911 |
