Early vs late clutch action
Ted2
Ted2 is offline
PostPosted: Fri Apr 07, 2023 4:34 am    Post subject: Re: Early vs late clutch action Reply with quote
Thanks for the input.
The clutch has been adjusted but I haven't pulled the engine to see what clutch is in the '55.
The operation just feels different than on the '56.
earlywesty
earlywesty is offline
PostPosted: Thu Apr 06, 2023 5:38 pm    Post subject: Re: Early vs late clutch action Reply with quote
Do you what pressure plate is on each? I have found a massive difference in feel between spring vs diaphragm style. I prefer the original spring style.
Erik G
Erik G is offline
PostPosted: Wed Apr 05, 2023 8:38 am    Post subject: Re: Early vs late clutch action Reply with quote
Ted2 wrote:
Question of the day:
There is a marked difference between my 4/55 and 11/55 beetles clutch operates.
Is there a difference in the clutch feel between early and late Ovals?
Thanks
In my opinion you need to look at what your issue is. They do not operate differently. You may have a carbon bearing on one, a roller type on the other, mix matched parts, new vs old, a cable fraying etc.
this is akin to "I have a check engine light on, what could it be" or "How long is a string".
Ted2
Ted2 is offline
PostPosted: Wed Apr 05, 2023 5:01 am    Post subject: Early vs late clutch action Reply with quote
Thanks
