vamram  Samba Member
Posted: Thu Oct 19, 2023 5:40 am Post subject: Re: Carburetor Rebuild |
Is the throttle sticking open at start up along w/the choke being engaged? Is the accelerator pump cam scraping the alternator housing, possibly causing the throttle to stay open if you're pumping the gas at start up? How about a picture
or video of the carb at start up during one of these high-rev episodes?
You might keep it all together in a single thread too, I see 3 threads from you on your carb/start-up issues. _________________ "Men are qualified for civil liberty in exact proportion to their disposition
Click to view image
Save the Supers!! |
Starbucket Samba Member
Posted: Wed Oct 18, 2023 3:06 pm Post subject: Re: Carburetor Rebuild |
The accelerator pump rod isn't connected to the accelerator pump diaphragm, when you open the throttle does a stream of gas shoot down the carb throat? |
baldessariclan Samba Member
Joined: October 14, 2016 Posts: 2047 Location: Wichita, KS
Posted: Wed Oct 18, 2023 6:33 am Post subject: Re: Carburetor Rebuild |
https://www.volkzbitz.com/ _________________ 1971 Standard Beetle — fairly stock / driver
baldessariclan -- often in error, never in doubt... |
calvinater Samba Member
Joined: September 06, 2014 Posts: 3579 Location: 802 The Pointless Forrest
Posted: Wed Oct 18, 2023 3:36 am Post subject: Re: Carburetor Rebuild |
Tim@ Volkzbits. (sp ?) _________________ "Albatross"! |
Jeff Hauck Samba Member
Joined: April 17, 2009 Posts: 9 Location: Pennsylvania
Posted: Tue Oct 17, 2023 9:52 pm Post subject: Re: Carburetor Rebuild |
I am looking for someone to replace the accelerator bushings in a 34 pict 3 carburetor. Does anyone have any info on who to contact? |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33086 Location: Hot Arizona
Posted: Wed Jun 28, 2023 4:49 pm Post subject: Re: Carburetor Rebuild |
ashman40 wrote: |
If the plate is missing, look around the engine compartment. Often you will find it laying somewhere. |
Or epoxy a dime into the hole.
Before I knew that, I just jammed a rubber stopper into the hole, but the emission guys caught that. So now I run a Solex 30/31PICT on an adapter on my 1600cc DP engine. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 16573 Location: North Florida, USA
Posted: Wed Jun 28, 2023 3:40 pm Post subject: Re: Carburetor Rebuild |
At this point you probably need to pay a video with sound to give a better idea what the sound might be. Did you isolate where the sound is coming from?
I was just thinking, is the round plate peened in place on the rear face of the carb missing? These occasionally fall out leaving a large hole into the carb body, increasing the noise and causing idle problems. Here is a close up pic showing the roundopening left when the plate comes off.
If the plate is missing, look around the engine compartment. Often you will find it laying somewhere. _________________ AshMan40
heimlich  VWNOS.com
Joined: November 20, 2016 Posts: 7502 Location: Houston, Texas
Posted: Wed Jun 28, 2023 1:40 pm Post subject: Re: Carburetor Rebuild |
You might try taking it apart again and checking over everything. Make sure the jets are clear. How many miles do you have on the carburetor? _________________ www.vwnos.com [email protected]
wcfvw69 Samba Purist
Posted: Tue Jun 27, 2023 7:10 pm Post subject: Re: Carburetor Rebuild |
BeetleGuy495 wrote: |
The last couple of days, I decided to undertake a carburetor rebuild on my 1984 Mexican model 34 pict 3 carburetor. Everything went fine, taking it apart, cleaning, and putting it back together, but when I reinstalled it, the problem started. When I tried to start the car, it would fire up but would be very loud and die after maybe 5 or so seconds of it running very loudly. I could kinda keep it alive if I pressed the gas, but again, it would rev up super loud compared to how it normally sounds. Any help on what the next step is would be really appreciated. Thanks in advance. |
There's many things that could cause these symptoms. A vacuum leak from something not hooked back up or tightened up? There's videos on Youtube that walk people through rebuilding those carbs. Maybe review a couple of them to see if you missed something.
If you can't sort it out, [email protected] is your man to go through the carb. _________________ Contact me at [email protected]
The Samba member since 2004.
Xevin  Samba Member
Posted: Tue Jun 27, 2023 6:34 pm Post subject: Re: Carburetor Rebuild |
This is weird that it’s making a strange noise.
Did you remove distributor cap? Or just the wires? If so could they backwards. Did you touch the distributor at all?
What did you use to clean the passages in the carburetor and how did you blow them out? Did you remove the little ball bearing in the bottom of the float bowl? _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin...  |
skills@eurocarsplus wrote: |
SGKent wrote: |
BeetleGuy495 Samba Member
Posted: Tue Jun 27, 2023 2:52 pm Post subject: Re: Carburetor Rebuild |
To answer a few of the questions yes the carb is the only thing I have worked on since driving it, the air flow screws are adjusted how they should be and lastly, the float holder thing is in the correct orientation. I’m not sure what else might be the problem. Thanks in advance for the help. |
Xevin  Samba Member
Posted: Tue Jun 27, 2023 9:30 am Post subject: Re: Carburetor Rebuild |
I always wondered what happens when people install the white bit backwards?
Seems like it would restrict float movement this picture is correct. If you dive back in there, let us know the orientation. I’m not implying this is your issue. I don’t want to send you down a rabbit hole.
Clatter wrote: |
SGKent wrote: |
Posted: Tue Jun 27, 2023 6:49 am Post subject: Re: Carburetor Rebuild |
I decided to undertake a carburetor rebuild on my 1984 Mexican model 34 pict 3 carburetor... When I tried to start the car, it would fire up but would be very loud and die after maybe 5 or so seconds of it running very loudly. |
Was the carb rebuild the ONLY thing you worked on? Did you do any work on the exhaust system or intake manifold? Where is the sound coming from? It can help to use a length of rubber hose or tubing held to your ear to isolate the sound source and move the other end around to listen for where the sound is loudest. Loud noise is often related to exhaust leaks but could be something as simple as the fan rubbing on the inside of the fan shroud.
See if you can isolate where the sound is coming from? _________________ AshMan40
jinx758 Samba Member
Joined: October 04, 2014 Posts: 1027 Location: half a bubble from plumb
Posted: Mon Jun 26, 2023 9:21 pm Post subject: Re: Carburetor Rebuild |
Howdy
Perhaps the needle hasn't seated. I always tap the handle of a screwdriver against the side of the bowl WHILE cranking after a rebuild.
Also the air/fuel screws may be outta whack. Try 2 out on fuel (small) & 4 out on air (large). This from a soft bottoming out.
This assumes you have no vacuum leaks.
Good luck ... stay safe
jinx _________________ " It's not valuable unless you learn something from an experience. " Henry Ford
It's not unlike the same difference ...
My Craigslist rescued 100 footer :
1971 Standard Bug
1776cc dual port
034 distributor
38mm EGAS Carburetor |
Posted: Mon Jun 26, 2023 4:55 pm Post subject: Carburetor Rebuild |
