Moving circuits from Primary Battery to House Battery
dabaron
dabaron is offline
PostPosted: Fri Jul 07, 2023 6:20 am    Post subject: Re: Moving circuits from Primary Battery to House Battery Reply with quote
not more rust! wrote:
Depends what you want to power - this is a reasonably common mod in the UK to change the 'house' features run by the starter battery:
https://vwt25.blog/2016/05/19/rewiring-stereo-to-leisure-battery/
came to post this, it's a none destructive method and allows to switch back if you have a problem with the house battery and want to jam the tunez or have interior lights
Laughing
1991 Vanagon GL Camper
not more rust!
not more rust! is offline
PostPosted: Fri Jul 07, 2023 5:20 am    Post subject: Re: Moving circuits from Primary Battery to House Battery Reply with quote
danfromsyr
danfromsyr is offline
PostPosted: Fri Jul 07, 2023 4:55 am    Post subject: Re: Moving circuits from Primary Battery to House Battery Reply with quote
just redirect the stereo power input with a new feed from the aux battery
it's done all the time..
nothing else in the main fuse block really needs to be on Aux..
if you are concerned on door lights, switch the bulbs to LEDs
Abscate wrote:
ZsZ
ZsZ is offline
PostPosted: Fri Jul 07, 2023 12:37 am    Post subject: Re: Moving circuits from Primary Battery to House Battery Reply with quote
Unfortunately you have to de-pin or cut and connect wires and make new fuses for the circuits.
The (late) fuse panel has only one battery+ve input and it is distributed by hard traces inside the panel.
In the rare case you have an early syncro with the bullet type fuses then you can route new feed wires for the different fuses.
Zoltan
1.9 MTdi 2wd Multivan (ex Caravelle)
Van since 2006, engine since 2008
torpedo51
torpedo51 is offline
PostPosted: Thu Jul 06, 2023 10:49 pm    Post subject: Moving circuits from Primary Battery to House Battery Reply with quote
Hi,
I have a Syncro Westy.
How can I power some (but not all) of the circuits on the factory fuse panel from the house battery? For example, the fridge is already powered by the house battery on a sub panel, but the stereo is powered by the primary battery on the factory panel.
I'm trying to avoid the process of installing another "sub panel" and physically moving wires from the factory panel to the new panel.
I'm assuming that the factory panel has a single source input (from the primary battery), so I won't be able to provide a second input voltage source in order to pick and choose which circuits are powered from the house battery.
Thanks in advance for some quick opinions or links.
