Evil_Fiz Samba Member
Joined: May 06, 2011 Posts: 1111 Location: Jacksonville, FL
Posted: Thu Mar 21, 2024 4:34 pm Post subject: Re: Cleaning original electrical connectors |
I don't know if this tip will help but years ago I saw a documentary where they used Hydrogen Peroxide to remove the yellow oxidation layer from plastic computer parts. It was a "cleans on contact" process. Wherever the peroxide touched the plastic, the white-ish original color would return.
Emil _________________ “…It's not just about what's interesting. It's also about what's helpful, and it's helpful even if it helps just one other guy working on a Ghia.”
kiwighia68
See my build on TheSamba at:
The K_R_A_K_E_N_N : a 70 Ghia Convertible reinterpreted |
jim martin Samba Member
Joined: January 14, 2004 Posts: 341 Location: Vancouver, BC
Posted: Mon Mar 11, 2024 6:59 pm Post subject: Re: Cleaning original electrical connectors |
Thanks guys , will get on it this weekend , engine bay is degreased and washed. Fyi: The link for the company that was making them is outa stk and looks like permanently.
Engine bay need a freshen up it’s had some hard times . Wiring’s getting re wrapped and better located as well as much has changed over the years. Paint has much damage and will re spray as needed , also going to install some led illumination so at evening drags will make inspection a tad easier.
_________________ B.C's fastest street legal vw , June 2006 Hot VW's feature car 9.81 sec at 145.26mph.
Sponsored by :
LUCAS OIL PRODUCTS http://www.lucasoil.com
KROC head porting services
Dialedinperformance.com
Airspeedparts.com topic http://airspeedparts.com/forums/index.php?topic=914.0 |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79466 Location: Sneaking up behind you
Posted: Mon Mar 11, 2024 10:30 am Post subject: Re: Cleaning original electrical connectors |
jim martin wrote: |
Is there a specific process to not damage the plastic covers ect |
A small screwdriver or pick can be used to release the metal connector from the plastic cover. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
MuzzcoVW Samba Member
Joined: February 21, 2018 Posts: 1574 Location: Westfield, MA.
Posted: Mon Mar 11, 2024 10:26 am Post subject: Re: Cleaning original electrical connectors |
Mr. Mike wrote: |
Hey Jim,
You're going to have to pull the wires to clean everything up. The original plastic covers are hardy and pliable. Label and pull spade connectors, wash the plastic cover with soap & water and if it still needs it, soak the plastic cover in vinegar checking every 30min till the internal corrosion is gone, q-tip will help. Dry it all off, clean up the spade connectors with a wire brush or a wire wheel on a dremel/rotary tool, apply some dielectric grease to hamper further corrosion, and plug it all back together.
Cheers!
Mike |
Just a note, us something like NoOx or Penetrox electrical corrosion resistant compound made to conduct, or not impede current... not dielectric grease! NoOx is specifically made for electrical connections, unlike dielectric that is for spark plug boots... to prevent current transfer and is often misused. BTW I soaked all of my terminals etc in Ospho, rinsed and then the compound. The connections on my '75s harness were a mess... but not anymore |
Mr. Mike Samba Member
Joined: January 30, 2015 Posts: 520 Location: Shoreline, WA
Posted: Mon Mar 11, 2024 9:44 am Post subject: Re: Cleaning original electrical connectors |
Hey Jim,
Cheers!
Mike _________________ 1964 Sedan 6 volt |
Posted: Sun Mar 10, 2024 4:55 pm Post subject: Re: Cleaning original electrical connectors |
Yes trying to freshen up the plastic yellowed covers .
Hoping not to have to take out the spade connections.
Thanks for the links .
Is there a specific process to not damage the plastic covers ect _________________ B.C's fastest street legal vw , June 2006 Hot VW's feature car 9.81 sec at 145.26mph.
Sponsored by :
Posted: Sun Mar 10, 2024 12:09 pm Post subject: Re: Cleaning original electrical connectors |
The plastic thing is a terminal connector and you can clean them up in vinegar soak.
Goodspeed Motoring and WW sell new ones
More info here
https://www.thesamba.com/vw/forum/viewtopic.php?t=771886 _________________ 1964 Sedan 6 volt |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 4033 Location: San Diego
Posted: Sun Mar 10, 2024 11:13 am Post subject: Re: Cleaning original electrical connectors |
Are you talking about the plastic covers or the metal connectors? Ive not found the plastic covers anywhere |
Posted: Fri Mar 08, 2024 7:55 pm Post subject: Cleaning original electrical connectors |
What are you doing to clean these up and make them look new
Sponsored by :
