modok Samba Member
Joined: October 30, 2009 Posts: 27749 Location: Colorado Springs
Posted: Fri May 24, 2024 1:17 pm Post subject: Re: Low rpm woes |
| modok wrote: |
40mm vents.....That's waaay too big for what the intake manifold can flow.
a pair of 36....... whats? |
Ah! 36mm venturis I bet. Sorry.
Yeah that would be a bit better |
jinx758 Samba Member
Joined: October 04, 2014 Posts: 1044 Location: half a bubble from plumb
Posted: Fri May 24, 2024 9:25 am Post subject: Re: Low rpm woes |
Accelerator pump squirt off?
Double check dwell. Nubs, putting, & gap off can cause that symptom.
Hope it's something simple.
Sounds like a fun ride ... stay safe
jinx _________________ " It's not valuable unless you learn something from an experience. " Henry Ford
It's not unlike the same difference ...
My Craigslist rescued 100 footer :
1971 Standard Bug
1776cc dual port
034 distributor
38mm EGAS Carburetor |
modok Samba Member
Posted: Fri May 24, 2024 9:03 am Post subject: Re: Low rpm woes |
patricke1971 Samba Member
Posted: Fri May 24, 2024 5:43 am Post subject: Re: Low rpm woes |
| Right now I have an idf 48 with 40mm vents..I have a pair of 36mm would they work better? |
oprn Samba Member
Joined: November 13, 2016 Posts: 15173 Location: Western Canada
Posted: Fri May 24, 2024 4:37 am Post subject: Re: Low rpm woes |
| patricke1971 wrote: |
| I have no choice.. dual carbs simply won't fit.. it's on a beach buggy |
Lots of us Beach Buggy owners are running dual carbs. Yes, a tight fit but not impossible...
I curse mine every time I need to work on them but absolutely will not go back when I get behind the steering wheel! Dual carbs on a Beetle looks even tighter to me and it's done all the time. _________________ Our cars get old, we get old but driving an old VW never gets old! |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7941 Location: Videbaek Denmark
Posted: Fri May 24, 2024 3:57 am Post subject: Re: Low rpm woes |
Agree on the distrributor. If it has to be an all mechanical, go with a 019 or a Magnaspark or Shockwave.
Header is too large for the power window, so there will be a good deal of overscavenging.
If you run the stock 36 mm venturis they are likely too large. Go 2 mm down and rejet. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
MuzzcoVW Samba Member
Joined: February 21, 2018 Posts: 1574 Location: Westfield, MA.
Posted: Fri May 24, 2024 3:32 am Post subject: Re: Low rpm woes |
| Slow 1200 wrote: |
| let me guess, no heat risers? |
Was thinking the same thing, or possible small vacuum leak |
Slow 1200 Samba Member
Posted: Fri May 24, 2024 1:02 am Post subject: Re: Low rpm woes |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 3421 Location: Hamble, Hampshire, UK
Posted: Thu May 23, 2024 11:05 pm Post subject: Re: Low rpm woes |
Maybe switch to a 123Tune distributor so you can use whatever vaccum you have in the manifold to dial in some extra advance just off idle, or ramp the centrifugal curve a bit faster off idle.
That must suck as even driving with a stock cam 1641 the engine only works above 2000 rpm .. _________________ Ancient vehicles and vessels
Posted: Thu May 23, 2024 6:34 pm Post subject: Re: Low rpm woes |
I have no choice..dual carbs simply won't fit..it's on a beach buggy ..after 2000 rpm the thing is a rocket...
Red light to red light I have raced quite a few different cars and won.
I have 295 50 15s on the back and it will spin the Machine sideways..
Lol it's just under 2000 rpm Is where it's a tad sluggish |
modok Samba Member
Posted: Thu May 23, 2024 6:28 pm Post subject: Re: Low rpm woes |
| replace with CB low profile intake |
jpaull Samba Member
Joined: February 22, 2005 Posts: 3675 Location: Paradise, Ca
Posted: Thu May 23, 2024 5:56 pm Post subject: Re: Low rpm woes |
OMG your running a center mount on that 2 liter!!!!! Your killing it _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth. |
Posted: Thu May 23, 2024 4:09 pm Post subject: Re: Low rpm woes |
Lol I have a redline intake stock dual port end casting
Fk42 camshaft
1 5/8 header
Ported heads |
modok Samba Member
Posted: Thu May 23, 2024 3:55 pm Post subject: Re: Low rpm woes |
The only thing I didn't change is the carburetor..it's an Spanish idf center mount..
So what does the center mount..mount to?
PVC pipe from homeless depo?
CB intake? Bugpack intake? isolated? plenum? steel? fat? skinny?
Does it have a CAMshaft?
How about an exhaust? |
Posted: Thu May 23, 2024 3:22 pm Post subject: Low rpm woes |
I have an ongoing problem..I have a 2332and previous was a 2234 and have the same problem..under or around 2000rpm it seems to miss a bit, idles perfect at 850 rpm.
I have changed distributors played around with timing changed idle jets ...after 2000 it takes off like a rocket..
I currently have 65 idle jets..
And currently running a 010 distributor with petronix.. |
