Front bra? Mask?
Love My Westy
Love My Westy is offline
PostPosted: Sat Jun 15, 2024 6:03 pm    Post subject: Re: Front bra? Mask? Reply with quote
I've been using a bra since new in 1986. Every time I wash the van, I also wash and dry the bra so a clean bra goes on a clean van. My paint looks good, and it's a whole lot better than if I had gathered 37 years of paint chips and the corresponding rust. To each his own.
mike boland
mike boland is offline
PostPosted: Fri Jun 14, 2024 7:43 pm    Post subject: Re: Front bra? Mask? Reply with quote
DanHoug wrote:
bobbyblack wrote:
I've used a bra on several VWs in my day, including my DD '87 Flash Silver Westy. I'd highly advise against putting another one on after you fix your paint.
that was my experience with a Vanagon bra... it was a really expensive, nice fitting one that beat the crap out of the paint if there was ANY edge that fluttered or shifted about. after i peeked under it a few months after putting it on my thought was, "I thought these were supposed to PROTECT the paint!"
thanks for replys..after thinking it over.. I'll just get front resprayed...
maybe next year
Red Ryder
Red Ryder is offline
PostPosted: Tue Jun 11, 2024 3:47 pm    Post subject: Re: Front bra? Mask? Reply with quote
We only install our bra for extended trips. Leaving one on the van full time is asking for heartache…
Since you already have the heartache, you are free to proceed as your wallet dictates.
“Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
“Scarlett” — 1990 Vanagon Carat Wolfsburg Edition (Tornado Red)
“Nigel” — 1999 Jaguar XK8 convertible (Alpine Green Metallic)
vanis13
vanis13 is offline
PostPosted: Tue Jun 11, 2024 11:43 am    Post subject: Re: Front bra? Mask? Reply with quote
Every van I looked at that had a bra had an unfixed front ding/dent.....that's the only reason to keep a F bra on.
DanHoug
DanHoug is offline
PostPosted: Tue Jun 11, 2024 11:36 am    Post subject: Re: Front bra? Mask? Reply with quote
-dan
www.thefixitworkshop.com
Ahwahnee
Ahwahnee is offline
PostPosted: Tue Jun 11, 2024 9:37 am    Post subject: Re: Front bra? Mask? Reply with quote
X3... I just accept that every 20 years or so the front apron will get repainted.
bobbyblack Premium Member
bobbyblack is offline
PostPosted: Tue Jun 11, 2024 9:31 am    Post subject: Re: Front bra? Mask? Reply with quote
I've used a bra on several VWs in my day, including my DD '87 Flash Silver Westy. I'd highly advise against putting another one on after you fix your paint. In my case, every time I put my bra's back on after fixing the paint, it would slowly grind away again until it wore through the paint yet again. They look cool and all, but the grit that gets under them is a disaster and you don't see it until something like you mention (your old one wore to tatters) and you take it off. Just go with multiple layers of your stock or chosen paint and clear (if that is what you do).
-bobby
Red Ryder
PostPosted: Tue Jun 11, 2024 7:48 am    Post subject: Re: Front bra? Mask? Reply with quote
For long-lasting results, sand, prep and paint the front clip. Bedliner on the front will look great for one day…
Corwyn Premium Member
Corwyn is offline
PostPosted: Mon Jun 10, 2024 12:41 pm    Post subject: Re: Front bra? Mask? Reply with quote
connorsvw2 wrote:
2nd on the 3M clear bra. Super tough and no hassles. Love it, but $$.
I recommend NOT using the 3M masking material. Talk to any RV owner you know and they will tell you it yellows in time and is almost impossible to remove. Line-X makes a product that goes on almost smooth and can be painted over.
'90 White Westy ("White Lightning")
FAS Gen V 2.0
The Annual Baja Rally
~ Captain Ron ~
connorsvw2
connorsvw2 is offline
PostPosted: Mon Jun 10, 2024 8:50 am    Post subject: Re: Front bra? Mask? Reply with quote
'85 Westy Wolfsburg camper/2002 2.5 Subaru since 2003.
'85 GTI 1.8L 1-owner 8v-gave up on 9A 2.0L 16v transplant. Keeping her stock!
'99 Passat 1.8T Variant-AKA "The Money Pit". Still limping along...
'09 Subaru Outback XT 5-speed, 245 hp rocket (wife's car)
IdahoDoug
IdahoDoug is offline
PostPosted: Fri Jun 07, 2024 9:45 pm    Post subject: Re: Front bra? Mask? Reply with quote
You haven't lived until you have tried cleaning bugs off a rough surface like bedliner. If you want cosmetic looks, repaint and have a 3M Clear Bra applied. If you are a functional solution type, do the bedliner.
mike boland
PostPosted: Fri Jun 07, 2024 2:31 pm    Post subject: Re: front bra? mask? Reply with quote
dabaron wrote:
you MUST resolve all rust issues before applying a sealing coat that will lock in the moisture and rust. there will be rust where there are chips in the paint from rocks.
I'm aware that, just looking for ideas
I was thinking sanding it, prime mask with new Front Bra, or maybe apply
black or white ( the VW is white) rhino type liner.
every long didstant trip I have taken even with Bra, always get pocket marked by insects etc.
dabaron
dabaron is offline
PostPosted: Fri Jun 07, 2024 12:32 pm    Post subject: Re: front bra? mask? Reply with quote
1991 Vanagon GL Camper
mike boland
PostPosted: Fri Jun 07, 2024 12:06 pm    Post subject: Front bra? Mask? Reply with quote
used have bra on my 1991 Westy with fiberglass bumpers, but over time it got torn up, destroyed.
now lot small rock chips are in entire front...
rather than buy new Bra I was think painting it with like Rhino liner coating.
recall seeing photo of one like that before...any body have photo?
mike
