busman78 Samba Member
Joined: August 17, 2004 Posts: 4667 Location: Oklahoma City, OK
Posted: Tue Oct 15, 2024 12:35 pm Post subject: Re: 1968 Squareback - The Keep-ening |
| Carb top needs to come off, needle seat stuck open, float stuck, something but the bowl is full and fuel will flow from every possible path available. Check your oil for fuel has no doubt run down the intake and past the rings. |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23577 Location: Kimball, Mi
Posted: Tue Oct 15, 2024 12:03 pm Post subject: Re: 1968 Squareback - The Keep-ening |
Sorry I can't help you on the carb questions as I don't have a single carb on anything but my lawn tractor. You might want to ask the 1500 club guys, as they have more knowledge about those carbs than anyone, as they came stock on the early cars. _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| "Friends are God's way of apologizing for relatives." |
| Tram wrote: |
| People keep confusing "restored" and "restroyed". |
Adoom Samba Member
Joined: November 11, 2004 Posts: 34 Location: Pickering, Ontario, canada
Posted: Mon Oct 14, 2024 2:48 pm Post subject: Re: 1968 Squareback - The Keep-ening |
Ok,
The new fuel pump rod arrived on Friday, unfortunately I was away (in West Virginia) for the weekend, so I just got to tinkering again today.
I'm ready to set this thing alight soon.
So, new fuel pump rod, I know it's pumping gas into the carb.
Still very slow to start. So I think to myself "clean up the carb a bit". Unfortunately I can't get the bottom carb mount nut off, so I cleaned what I could on the car.
1. is it normal for gas to be sitting in the rubber elbow that connects the carb to the oil bath?
2. Is is normal for the carb to shoot gas out this area by the butterfly and essentially drown itself.
I am attaching a video. For the record yes I had a fire extinguisher right beside me. And yes I now smell like a gas station.
I'm pulling my hair out. I have 2 weeks to get this running so that I can drive it an hour to my storage location.
It does gas shower this everytime I start it. _________________ 1968 Squareback |
Posted: Mon Oct 07, 2024 12:50 pm Post subject: Re: 1968 Squareback - The Keep-ening |
| Adoom wrote: |
It's a good thing my hair falls out on its own, otherwise I would be pulling it out.
New day, new parts. Installed a new cap, wires, and condenser. Also a new coil.
Same sh!77y routine. Fires right up.. when cold. Moment it's been running for a bit it has no interest in firing.
I'm really scratching my head here. I've replaced all the "sparky stuff". Adjusted the valves, timing is on point. Changed the oil in the bath.
| Bobnotch wrote: |
| and why I went to a low pressure electric fuel pump. Just a thought. |
I think this might be where I'm headed next. I don't own a fuel pressure gauge, and have no experience switching from mechanical to electric fuel pump.
Here's why I **think** it may be fuel related. I was taking it for a drive today, me and the dog went up some pretty big hills (for around here). The car was really displeased with going up any thing hill related. I thought "huh, seems weaker than usual". But on the way home, going down some big hills, it was acting like we were running out of fuel. At a stop light I had to continuously feather the throttle to stop it from dying, and then shortly after...it sputtered to a stop on the side of the road.
After much feather, cursing, and turning over, it finally caught, and we were on our way...cautiously. We made it home, but I'm really wondering if we have a fuel issue.
If I go with a fuel pump, I found this, would this be the way to go? How did y'all wire it in?
https://www.cip1.ca/c10-41-2010/
https://www.cip1.ca/c26-127-205/
Thanks in advance! |
You can go with the "click clack" pump (cip#c10-41-2010/) or get a Mr.Gasket low pressure pump (the import pump) from your local NAPA (that's what I run in my own car). I only say that as I tend to drive out of state, and I like the idea of being able to get some parts anywhere I might be traveling to. In the USA, the Mr Gasket pump can be had at Advanced Auto, Autozone, O'Reilly's, and NAPA, and most bigger cities have at least one of those places in them.
Keep in mind that you'll need to mount it up front under the fuel tank, as it's a "pusher" pump. Install a new fuel filter before it too. I normally use zip ties to hold it to the beam, as it has it's own plus and ground wires that need to be connected. Some of us who have gone to electric fuel pumps also wire in an impact switch to turn off the pump in the case of an accident (to stop feeding gas to the engine, or a fire if one breaks out). I hope this helps. _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| Tram wrote: |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 23022 Location: Northwest of Normal
Posted: Mon Oct 07, 2024 11:32 am Post subject: Re: 1968 Squareback - The Keep-ening |
| Adoom wrote: |
Call it mild frustration infused obsession, I pulled the mechanical fuel pump.
When I first tried manipulating it manually it was barely moving, and there was a bunch of crud built up in and around the actuating foot.
I sprayed some carb cleaner in the foot area and some chunks of i dunno what, came out. Then I sprayed some cleaner into the inlet and outlets and tried manipulating it by hand and boom it broke free and shot gas/cleaner a good 3 feet across the yard (uh, whoops). Now it pushes, a lot.
Then I measured the rod, on which the tip has slight mushrooming. It comes in at just 106mm, maybe 106.5mm, which is only 1.5-2mm shorter than it should be...but that is still shorter than I expected.
So I think, maybe, it was thirsty. I'm going to order a new $4 rod and see if that was the issue all along. |
I would not trust the diaphragm in that pump. You don't need it leaking gas into your crankcase if it is crusty and fatigued. _________________ Немає виправдання для війни! Я з Україною.
| Bryan67 wrote: |
| Just my hands. And a little lube. No tools. |
Those who can- do.
Those who can't? Subaru. |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13587 Location: Tejas!
Posted: Mon Oct 07, 2024 9:31 am Post subject: Re: 1968 Squareback - The Keep-ening |
| Make sure your trans ground strap is good and connected the right way too |
Posted: Mon Oct 07, 2024 6:14 am Post subject: Re: 1968 Squareback - The Keep-ening |
A quick test is after running the vehicle and you get home, after about thirty minutes pull the #2 spark plug (easiest to get to), if it is wet and soaked with fuel you are either boiling the fuel in the bowl or the needle valve is not seating completely and the residual pressure in the mechanical pump floods the carb(s), or both. Both scenarios will leave the cylinders charged with excess fuel and starting right off difficult.
Things to try, penolic spacer between the intake and carb, electric fuel pump with cut off so fuel will not flow when not running and idle solenoid shut off valves, any and all will aid in the T3 Carb Cook-off Syndrome.
edit - Another quick test is after the vehicle has been turned off for 20-30 minutes wrap the palm of your hand around the fuel bowl of the carb, a good way to test how hot it has gotten. |
Adoom Samba Member
Posted: Sun Oct 06, 2024 8:38 pm Post subject: Re: 1968 Squareback - The Keep-ening |
So I think, maybe, it was thirsty. I'm going to order a new $4 rod and see if that was the issue all along. _________________ 1968 Squareback |
Adoom Samba Member
Posted: Sun Oct 06, 2024 5:51 pm Post subject: Re: 1968 Squareback - The Keep-ening |
| Zwitterkafer wrote: |
| The fuel tank screen filter is clean beyond suspicion? Sometimes the fuel pump is still OK but can't compensate for reduced flow from the tank. |
Good thinking, I think mine dissolved long ago _________________ 1968 Squareback |
Zwitterkafer Samba Member
Joined: November 17, 2007 Posts: 1023 Location: Lanark County, Ontario, Canada
Posted: Sun Oct 06, 2024 5:04 pm Post subject: Re: 1968 Squareback - The Keep-ening |
The fuel tank screen filter is clean beyond suspicion? Sometimes the fuel pump is still OK but can't compensate for reduced flow from the tank. _________________ "Criticism comes easier than Craftsmanship"
- Zeuxius, 400 BC |
Adoom Samba Member
Posted: Sun Oct 06, 2024 4:13 pm Post subject: Re: 1968 Squareback - The Keep-ening |
| Bobnotch wrote: |
Thanks in advance! _________________ 1968 Squareback |
Posted: Wed Oct 02, 2024 1:17 pm Post subject: Re: 1968 Squareback - The Keep-ening |
Sounds like you've been busy. I've had several condensers fail from sitting. but they've also been non Bosch units. Jim Adney says the older Bosch ones last the longest, and since you're getting bit by the plug wires, I'd say they're working just fine. Maybe you need to replace the plug wire boots at the cap instead. _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| Tram wrote: |
Adoom Samba Member
Posted: Wed Oct 02, 2024 8:51 am Post subject: Re: 1968 Squareback - The Keep-ening |
I hate "throwing parts" for the sake of throwing parts, but a lot of this car is "pre-me" so I don't know the actual age or condition of a lot of it. SO, I just ordered a new cap, wires, condensor, and coil.
Coil: the spark is super weak when it IS in the points. I've had this coil for a long time as a spare for my old bus, so I think grabbing a new might be a nice-to-have.
Cap: when I was turning the distributor for timing, I was initially getting mostly shocked by #3 & 4. The cap *looks* ok, but for $15 its peace of mind.
Wires: see photo, also I don't know if the shocks are coming from wires or cap. Actually, now that I think of it, I replaced the wires 4 (ish) years ago with a set from Rock Auto. You'd think they would last longer than this.
Consdensor: the weak spark thing got me wondering. I know there's been a production issue in the past with condensers, AND I know the condenser I have won't seat in the distributor hole properly or securely. I'm willing to try a new one in hopes of getting some blue or white spark instead of orange.
Hoping everything will be in by the weekend (wishful thinking) so I can get this thing running properly.
I will say that when it's running on all 4 and *NOT shorting out, it sounds pretty nice. I put the new fresh air hoses on, changed the oil and adjusted the valves.
Now I just need it to...run properly.
Oh I also upgraded the seat belts. _________________ 1968 Squareback |
Erik G Samba Member
Posted: Tue Oct 01, 2024 11:28 am Post subject: Re: 1968 Squareback - The Keep-ening |
there you go, I thought it was distributor related
I do check my cars in the pitch black every once in a while. |
Adoom Samba Member
Posted: Tue Oct 01, 2024 6:44 am Post subject: Re: 1968 Squareback - The Keep-ening |
I keep getting shocked by this distributor! Which I *think* is a major factor in it's poor running/starting.
When I was 16 I had a '79 rabbit that was misfiring, occasionally, but not always. Drove me nuts. One night my dad suggested spraying a mist of water over the ignition and to look for arcs. My plug leads lit up like Christmas.
So last night I did the same. By ouchy feel cylinder #3 is live to the touch, but by misty eye, cylinder 2 is also arcing.
Posted: Sun Sep 29, 2024 12:37 pm Post subject: Re: 1968 Squareback - The Keep-ening |
| Adoom wrote: |
Turns out is was just beginners luck. This morning I was back to the same old starting routine. Took 4 tries to fire. I will need to address the timing tonight. Then I will need to wait for a cool morning to adjust the valves. (might as well change the oil then too).
Getting there. |
Sounds like the fuel is either vaporizing when sitting over night, or right after shut down, and you're having to crank it over a few times to re-prime the fuel bowl. If you have a low pressure fuel pressure gauge, you might want to check your output pressure of the pump (tee it in the fuel line). You're looking for 3.5 psi fuel pressure. This is similar to my vapor locking the 3 mechanical pumps on my own car, and why I went to a low pressure electric fuel pump. Just a thought. _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| Tram wrote: |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 18052 Location: Eugene, OR
Posted: Sat Sep 28, 2024 11:27 am Post subject: Re: 1968 Squareback - The Keep-ening |
| Adoom wrote: |
Getting there. |
Don't expect 50 year old cars to start instantly like new computer controlled cars!
I prime my 69 FI/AT square 4 times before trying to start it when cold.
Starts instantly if it's warm! _________________ 69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Fri Sep 27, 2024 12:24 pm Post subject: Re: 1968 Squareback - The Keep-ening |
It's amazing how well these engines run with a little attention paid to them. It seems like they just need a little love thrown at them and they'll respond in kind. You're gaining on it, and all it's costing is a little time.  _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| Tram wrote: |
Adoom Samba Member
Posted: Thu Sep 26, 2024 1:02 pm Post subject: Re: 1968 Squareback - The Keep-ening |
Getting there. _________________ 1968 Squareback |
Adoom Samba Member
Posted: Thu Sep 26, 2024 10:03 am Post subject: Re: 1968 Squareback - The Keep-ening |
It's actually not a 009 (thankfully, I did have one of those in my bus for a couple of flat spotactular years), but noted on checking the timing. Looks like I need to dig out my timing light. _________________ 1968 Squareback |
