eriksonalex1307 Samba Member
Posted: Tue May 13, 2025 3:01 pm Post subject: Re: Beetle 1962 | The Correct Tail Light Position |
| Well ... the one i need is for 1962 |
my3bugs Samba Member
Joined: June 18, 2003 Posts: 969 Location: Moreno Valley
Posted: Tue May 13, 2025 1:02 pm Post subject: Re: Beetle 1962 | The Correct Tail Light Position |
sorry no help here BUT maybe you know someone with a good fender ???
this is such a common question not just for your year but for all year bugs . after market fenders rarely have the holes in the right place ...... for a split and oval bugs i have made paper templates to send to friends for there projects .... im suprised no parts venders have these simple to make templates available for the different years .
here is a HEART tail light template and a copy of it i made for a friend
Posted: Tue May 13, 2025 12:56 pm Post subject: Re: Beetle 1962 | The Correct Tail Light Position |
| Thank you for the drawing and explanation. Appreciated it very much. |
rcooled Samba Member
Joined: September 20, 2008 Posts: 2860 Location: Santa Cruz, CA
Posted: Tue May 13, 2025 12:25 pm Post subject: Re: Beetle 1962 | The Correct Tail Light Position |
That dimension marked in your photo is 10.16cm, or exactly 4 inches, measured from the edge of the fender bead to the edge of the tail light gasket.
| eriksonalex1307 wrote: |
| ...it should need 3 holes on each fender. |
Yes, three holes is correct...two 6mm holes to mount the housing and one a bit larger for the wires. The hole for the wires is approximately 46mm up from the lower mounting hole and in line with the other two. _________________ '63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
'62, '63, '65, '69 Bugs (all long gone) |
sportin-wood Samba Member
Joined: September 12, 2010 Posts: 2324 Location: Texas
Posted: Tue May 13, 2025 9:48 am Post subject: Re: Beetle 1962 | The Correct Tail Light Position |
From the gallery
_________________ Dave
1966 Bug project
1973 Thing project
"Relax, all right? My old man is a television repairman. He's got this ultimate set of tools. I can fix it." --- Jeff Spicoli |
Posted: Tue May 13, 2025 4:03 am Post subject: Re: Beetle 1962 | The Correct Tail Light Position |
Anybody could help me with details measurement ?? Or Drawing ?? As per my understanding, it should need 3 holes on each fender.
Thank you |
Posted: Tue May 13, 2025 4:00 am Post subject: Beetle 1962 | The Correct Tail Light Position |
Hello All,
I have a 1962 Beetle with no hole for mounting the tail light.
Could anyone help me the correct measurement position for 1962 tail light ?? If we measure it from the fender lips that attach to the rear apron.
I attach a photo to give a clear explanation for my question. The tail light i use would be the same as my photo
Thank you.
Erik
