volksworld Samba Member
Joined: November 26, 2011 Posts: 2575 Location: formerly NY currently NC
Posted: Thu May 22, 2025 10:35 am Post subject: Re: Narrowing Right Rear 1/4" Somehow |
and the dimensions of aftermarket fenders have varied greatly through the years...if you put the drums back on the rear I doubt you would actually notice any difference in braking |
vwuberalles Samba Member
Joined: October 18, 2003 Posts: 1459 Location: Richmond, VA
bsairhead Samba Member
Joined: October 08, 2008 Posts: 4393 Location: viroqua wi.
Posted: Tue May 20, 2025 5:45 am Post subject: Re: Narrowing Right Rear 1/4" Somehow |
I think some don't read "right rear". Try a right to left wheel swap and see if it's the same. Also measure C/L of transaxle to fender lip. |
RangerGhost169 Samba Member
Posted: Tue May 20, 2025 4:22 am Post subject: Re: Narrowing Right Rear 1/4" Somehow |
New tires would be a great solution if there was something out there. Currently running 205/70's in the rear. It's the tallest and narrowest tire I can find, and I like the way they look. Any other tires would either be too short or too wide, I think. |
OldSchoolVW's  Samba Member
Joined: July 03, 2020 Posts: 1330 Location: San Diego
Posted: Mon May 19, 2025 1:05 pm Post subject: Re: Narrowing Right Rear 1/4" Somehow |
Or run a pair of slightly narrower tires in the rear. Certainly a quick and easy solution. Depending on what tires you select, the total cost would probably be comparable to what #2 & 3 would cost (and #1 if you pay a professional to do it or you try and the paint gets messed up). You can use this link to compare the dimensions of your current tires to other sizes so you can select a size that has the same overall diameter but is about a 1/2" narrower.
https://tiresize.com/calculator/ _________________ Tom
"Following distance is proportional to IQ."
"If you don't do it this year, you'll be one year older when you do." Warren Miller
"Research is what I'm doing when I don't know what I'm doing." Wernher von Braun
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 4119 Location: Georgia
Posted: Mon May 19, 2025 12:51 pm Post subject: Re: Narrowing Right Rear 1/4" Somehow |
Number 2 seems to be the easiest.
Sometimes though, things don’t come out right no matter what you do.  _________________ Volkswagen!
(Compression 8.7:1) |
Posted: Mon May 19, 2025 12:17 pm Post subject: Narrowing Right Rear 1/4" Somehow |
So, I finally got the stance on my car perfect. Only problem is my right rear tire rubs the inside of the fender by a minimal amount- about 1/4". My options are-
1. Roll the fender- worried about paint damage.
2. Switch the disc brakes out for zero offset set.
3. Get new wheels. I really like the original Mangles that are currently on it.
Any other thoughts or ideas on how to accomplish this? Appreciate the help. |
