Rear luggage floor support
bnam
bnam is offline
PostPosted: Sun Jun 01, 2025 9:55 am    Post subject: Re: Rear luggage floor support Reply with quote
So that confirms it. 64 and earlier had 10 rounded profile beads plus a cross brace. 1965 till 67 - 13 beads of more squared profile and no cross brace. Some other change then happens 68-70 and one last time from 71 on - based on part number changes.
Key takeaway for me, I don’t need to add a cross brace to my car. It didn’t come with one.
Thanks for help ing clear that up.
Byas
Click to view image
1952 Citroen TA 11BL
Era Vulgaris
Era Vulgaris is offline
PostPosted: Sun Jun 01, 2025 8:25 am    Post subject: Re: Rear luggage floor support Reply with quote
A pic of my 66 before the engine went in. The beads do have a squared off profile
Currently own:
66 Karmann Ghia, L390 Gulf Blue, under construction, here: www.thesamba.com/vw/forum/viewtopic.php?t=760505&highlight=
99 Mazda MX-5 10AE, Sapphire Blue Mica, 6 speed, LSD
Previously owned:
98 Porsche Boxster, silver, 2.5L -- 67 Karmann Ghia, Black, 1500sp -- 98 BMW Z3, Atlanta Blue Metallic, 2.8L I6 -- 75 Porsche 914, Laguna Blue, 2270cc -- 72 Porsche 914, Signal Orange, 1.7 FI -- 74 Karmann Ghia, Black, 1600dp -- 74 Triumph TR6 with O.D., sapphire blue
bnam
bnam is offline
PostPosted: Sat May 31, 2025 8:42 pm    Post subject: Re: Rear luggage floor support Reply with quote
65 Seems to be the first year without the cross brace as seen in this pic (no my car)
There are also 3 extra beads vs the 64-earlier luggage floors.
The beads on the firewall seem to have a more squared off profile
Click to view image
bnam
bnam is offline
PostPosted: Sat May 31, 2025 8:09 pm    Post subject: Re: Rear luggage floor support Reply with quote
Nicholas,
Wonder if there was some change made to the panel that resulted in it being stronger and not needing the cross brace. Is the profile or depth of the bead different between the two?
To me it seems the profile was a bit more circular in the earlier cars with the later being a bit more squared off. But that difference may just be from the angle/lighting or other photo artifacts.
Here's a pic from a 64 showing the brace and what seems to me like circular profile for the beads.
Thanks,
Byas
Click to view image
sputnick60
sputnick60 is offline
PostPosted: Sat May 31, 2025 7:41 pm    Post subject: Re: Rear luggage floor support Reply with quote
My'66 doesn't have it....
But the donor section that replaced the rear corner, likely a '60 or '61 does.
Nicholas
'66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
bnam
bnam is offline
PostPosted: Sat May 31, 2025 6:37 pm    Post subject: Re: Rear luggage floor support Reply with quote
You're right! And from the battery tray discussion we had, the tray looks like a 63 or older version. So, this is a pre-64 car. Then, was this brace present on all 63 and older cars? I don't see it listed in the parts manual which only has one part number for rear factory floors up to end of MY1967.
Update: I found a pic from the gallery from a 57 lowlight which has this brace:
And a user on FB commented that his 62 has the brace. Wonder when it stopped?
Byas
Click to view image
Era Vulgaris
PostPosted: Sat May 31, 2025 12:38 pm    Post subject: Re: Rear luggage floor support Reply with quote
This photo on page 1 of the thread, based on the dash, would indicate it's a pre-66 car, as 66 didn't have the small radio opening or the in-dash ash tray.
WrennMetallWerks wrote:
Currently own:
Previously owned:
bnam
bnam is offline
PostPosted: Sat May 31, 2025 6:00 am    Post subject: Rear luggage floor support Reply with quote
In this pic I’ve borrowed from WrennMetallWerks, you can see a support brace for the rear luggage floor. When did Ghias get that? My 65 does not have it. The car in the pic seems to be a 66 or later model.
Thanks,
Byas
Click to view image
