Gauge mounting ideas
redhot
redhot is offline
PostPosted: Thu Jul 17, 2025 11:13 am    Post subject: Re: Gauge mounting ideas Reply with quote
Worth a visit; there are other similar videos of using an "analouge" though in reality digital cluster that looks very good and enables a huge amount of customization. I have another video in mind, if I can find it...
boxer74
boxer74 is offline
PostPosted: Thu Jul 17, 2025 10:44 am    Post subject: Re: Gauge mounting ideas Reply with quote
This location works nicely for my 74 super.
74 Super
84 Westy
54bug
54bug is offline
PostPosted: Thu Jul 17, 2025 6:42 am    Post subject: Re: Gauge mounting ideas Reply with quote
Hi All
Lots of interesting Ideas. I managed to fit 914, and standard gauges without cutting the dash. Used an EMPI Accessory pod under the ashtray to hold less important pieces, and put the stereo in a fiberglass glove box.
Did every trick I could think of to make modifications reversable, no dash cuts, and modular so each section could be removed. I did end up cutting the ring for the speedo out of the center. In retrospect the stereo in the dash was a good plan, the car is loud enough that I don't really play the stereo much, but it sounds amazing when the car is parked!
Scott
Schepp
Schepp is online now
PostPosted: Wed Jul 16, 2025 10:52 am    Post subject: Re: Gauge mounting ideas Reply with quote
Maybe I'm a bit biased but the Prototipo in my opinion is the sexiest race car steering wheel out there! The build quality is excellent! Zero flex.
DUNGBTL Premium Member
DUNGBTL is offline
PostPosted: Wed Jul 16, 2025 10:42 am    Post subject: Re: Gauge mounting ideas Reply with quote
J.
OTTO 1303
OTTO 1303 is offline
PostPosted: Wed Jul 16, 2025 10:12 am    Post subject: Re: Gauge mounting ideas Reply with quote
I chose the radio slot for better viewing.
Radio will be moved to center console I am currently fabbing with 2 additional gauges.
Good Luck
74 Super Sun Bug - OTTO
74 Super - DANZIG
74 Super - HERZOG
16 R-Line
DUNGBTL is offline
PostPosted: Wed Jul 16, 2025 9:35 am    Post subject: Re: Gauge mounting ideas Reply with quote
Schepp wrote:
Because race car…
Very Happy Thumbs Up Thumbs Up
Excellent wheel choice btw.
J.
Schepp
PostPosted: Wed Jul 16, 2025 7:26 am    Post subject: Re: Gauge mounting ideas Reply with quote
volky1970
volky1970 is offline
PostPosted: Wed Jul 16, 2025 5:55 am    Post subject: Re: Gauge mounting ideas Reply with quote
Hi,
My car is a 2109cc turbo engine so I decided to have lots of gauges for monitoring when tuning:
-CHT
-AFR
-Oil Temp
-Oil Pressure
-EGT
-Boost
-Voltage
-TACH
1970 Beetle Turbo 2109cc MS II EFI, W/M Injection, Intercooler, FORD Wasted Spark Coilpack, 48lb. Injectors.
johnnyvw164
johnnyvw164 is offline
PostPosted: Wed Jul 16, 2025 1:33 am    Post subject: Re: Gauge mounting ideas Reply with quote
If you simply want to add on a couple of gauges, maybe look into this?
https://www.ebay.com/itm/192427855424
johnnyvw164
PostPosted: Wed Jul 16, 2025 1:29 am    Post subject: Re: Gauge mounting ideas Reply with quote
I did something similar to @Rome on my 69, but not as radical. 914 tach in place of the speedo, 914 speedo in the speaker opening. A little bit of cutting and banging but that's about it. VDO gas guage and LED idiot lights for oil and gen to the right of the tach. In the radio opening oil press+temp and voltmeter, used this ebay purchase for the mount: https://www.ebay.com/itm/296270359220
Meiang
Meiang is offline
PostPosted: Wed Jul 16, 2025 1:12 am    Post subject: Re: Gauge mounting ideas Reply with quote
You could always try modifying the factory Type 1 centre console. I still have about 10 of them.
Range Rover Sport TDV8
Honda Civic Vi Hatch
chinny22
chinny22 is offline
PostPosted: Wed Jul 16, 2025 12:00 am    Post subject: Re: Gauge mounting ideas Reply with quote
I was also trying to avoid mounting under the dash. I failed
When trying to come up with ideas I found this somewhere.
Older cars also have this bracket available
https://www.justkampers.com.au/black-gauge-holders-motormeter-style-vw-beetle-1947-2003.html
I was thinking of something similar but would have to get creative around the ignition barrel plus didn't like that I'd loose bottom of the speedo/ warning lights.
Depending on how much space you have you could maybe create a custom center console to suit your needs. this post has a few examples plus measurements.
https://www.thesamba.com/vw/forum/viewtopic.php?t=...re+console
dennismcd707 Premium Member
dennismcd707 is offline
PostPosted: Sat Jul 12, 2025 4:06 am    Post subject: Re: Gauge mounting ideas Reply with quote
Yes, the gauges are illuminated, but only with the headlights on. And you're right, I have to purposely look down at them to see the needle position. Also, my left leg doesn't block my view, nor does it hit the gauges, but it's possible I have to move my leg a bit to see them. I still like their location, given the limited space involved, but maybe they aren't as "perfectly" located as I thought they were.
1971 Super Beetle, 1776, dual Weber's, roller crank, modified large valve heads on match ported intakes, 9.2 to 1 compression, close ratio trans, lowered suspension, 4 wheel disc brakes, truss bar and other goodies. Car has over 370,000 actual miles, and counting. (RIP 1970 Beetle/Baja, 1986 GTI, 1999 Jetta, 2002 Jetta)
Rome
Rome is offline
PostPosted: Fri Jul 11, 2025 3:16 pm    Post subject: Re: Gauge mounting ideas Reply with quote
dennis, are the gauges illuminated with the ignition on? They are down in a dark area even in daytime. Does your left knee not obstruct the view of the lowest gauge, or is your leg usually out of the way when you're not shifting? IMO that location is out of peripheral vision when looking at the road, so that you have to purposely look downward at them to see the needle position. I'd prefer having them higher up.
PostPosted: Mon Jul 07, 2025 2:11 am    Post subject: Re: Gauge mounting ideas Reply with quote
The previous owner of my ride put the gages in a swell spot. Tucked away on the left, I think it looks great. Thoughts?
Danpa
Danpa is offline
PostPosted: Sun Jul 06, 2025 7:48 pm    Post subject: Re: Gauge mounting ideas Reply with quote
Rome wrote:
The '71 Super Beetle in your gallery has the same original dash layout as my '77 Standard Beetle did. This is what I did many years ago shortly after I bought the car. I cut the original speedometer opening out, moved it slightly to the right, and had it welded back in. Then installed a speedo opening from another standard Beetle (junkyard find) to the left and had it welded in. Placed them far enough apart to position two 2 1/16" gauges. The tachometer is from a 4-cylinder Porsche 914 which fits into the Beetle speedo opening. I made the metal cover plate using thin sheetmetal, painted wrinkle-finish black.
I like it! If my dash was already hacked up, I'd do the same. Maybe on the next one...
Anyway, for gauge cups mounted under the dash, I just used short sections of 2" PVC pipe. I mounted the oil pressure and the AFR gauge under dash above my left knee. They're a little blocked by the wheel, but not terrible.
Dan
67 Beetle (gone)
68 Bay Window Double Cab (gone) sob, sob!
64 Beetle (gone)
77 Scirocco (gone)
73 Squareback (scrapped)
70 Beetle, Finally back on the road after 18 years!
celtune
celtune is offline
PostPosted: Sun Jul 06, 2025 3:06 am    Post subject: Re: Gauge mounting ideas Reply with quote
I use something like this in my 73 super for the radio hole but i dont know if it fits yours.
https://www.amazon.com/s?k=52mm+Universal+Triple+Gauge+Single+Din+Radio+Face+Pod
The gauges are somewhat pointing to the driver.
Cusser
Cusser is offline
PostPosted: Sat Jul 05, 2025 8:44 pm    Post subject: Re: Gauge mounting ideas Reply with quote
Rome
Rome is offline
PostPosted: Sat Jul 05, 2025 6:52 pm    Post subject: Re: Gauge mounting ideas Reply with quote
