Oil Cooler bypass issue?
Wildthings
Wildthings is offline
PostPosted: Sun Jul 13, 2025 11:47 am    Post subject: Re: Oil Cooler bypass issue? Reply with quote
Willin wrote:
We hope you meant 32*btdc at @3000 rpm.
Assuming he lives in Denver he could give it another 2° or so of extra advance. 34° BTDC at 3800 rpms with the hoses removed from the vacuum canister and plugged should do him well.
RLFD213
RLFD213 is offline
PostPosted: Sat Jul 12, 2025 7:11 am    Post subject: Re: Oil Cooler bypass issue? Reply with quote
Get a long thermometer and when the engine is at running temp shut it off and put the thermometer in the dipstick hole and get an actual oil temperature. When I put auxiliary coolers in type 4’s I get rid of the OEM cooler and just use the auxiliary with an electric fan and thermostat switch. Try using straight 30 weight oil and see if that makes a difference. Make sure the timing isn’t way out also. This is a good start
RWK
RWK is offline
PostPosted: Sat Jul 12, 2025 5:13 am    Post subject: Re: Oil Cooler bypass issue? Reply with quote
Also check the bore for the oil relief valve, if it has worn or been gouged on the ID it will always be bypassing some oil even when closed. Causes the system to act funny. Also check the other oil pressure valve in the case and the bypass on the filter housing.
73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530
raygreenwood
raygreenwood is offline
PostPosted: Fri Jul 11, 2025 6:08 pm    Post subject: Re: Oil Cooler bypass issue? Reply with quote
Ok......let's clean up a few things here. I have only been paying about half attention to this thread because there are plenty of smart people here answering.
But you have too many "half known" issues here.
1. The twin VDO oil pressure units have notorious issues. Some work great and some don't. They also have more than one switch tolerance available etc.
You can buy a simple $8 water pressure gauge at Home Depot and connect it to the port and put to rest whether your VDO is accurate and what your pressure is at any given rpm and temp.
2. Put a 10/40 oil in it. For now.
I have seen very few stock 1.7, 1.8 or 2.0 that needed 20/50.
And the reason for this as well....
3. What oil pump does this engine have in it? Stock Type 4 or a type 1 pump? If it's a type 1 based pump and it's not one of say...CB performance units made for type 4.....it likely has a 30mm gear set. Way too big. Bigger gears along with thicker oil mean at certain rpms....pressure too high and cooler gets bypassed.
4. What is your engine code? Is this by chance an earlier case with the oil control valve under #1 cylinder? And/or did it have a mechanical fuel pump at one time? Look for a block off plate on the passenger side lower corner.
Ray
lil-jinx
lil-jinx is offline
PostPosted: Fri Jul 11, 2025 3:27 pm    Post subject: Re: Oil Cooler bypass issue? Reply with quote
this may be of interest, credit to Amskeptic
https://www.itinerant-air-cooled.com/viewtopic.php?t=12422
1968 Dune Buggy sold dec 2024
1974 parts bus
Willin
Willin is offline
PostPosted: Fri Jul 11, 2025 12:34 pm    Post subject: Re: Oil Cooler bypass issue? Reply with quote
73 bus. Org. 1700 with dual Weber 40 idfs, bus header with Empi qp muffler, CB magnaspark 2 " ready to run kit".
lil-jinx
lil-jinx is offline
PostPosted: Thu Jul 10, 2025 4:01 pm    Post subject: Re: Oil Cooler bypass issue? Reply with quote
have you load tested the bypass spring,did you put the spacers washers between the cooler and it's mount when you replaced it,doing so gives the seals the correct amount of crush,and there are several styles of seals.
1974 parts bus
captainstick
captainstick is offline
PostPosted: Thu Jul 10, 2025 3:41 pm    Post subject: Re: Oil Cooler bypass issue? Reply with quote
lil-jinx wrote:
if that bypass valve was stuck ,it would need to be stuck in the opened position in order to bypass the cooler,when oil is cold and thick it takes more pressure to force it thru the cooler,so when that happens the pressure opens the bypass and allow the oil to travel tru the engine ,lubicating it.as the oil heats and thins then it will pass thru the cooler,the pressure it takes to force cold thick oil thru the cooler is greater then the force to open the bypass valve,
so with that i would say the spring in the bypass is so weak that the valve is allways open ,hence bypassing the cooler,or there is a restriction in the cooler keeping the resistance high enough to keep the bypass open.
maybe the rings for the cooler mount are crushed causing the restriction or something got into the cooler,or maybe the temp sender is partly blocking the oil gallery,not sure if that's even possible.
I installed the new oil cooler a few weeks ago and didn't use much pressure. I think there might even be a small leak because I was worried about crushing those seals. I blew easily through one hole in the cooler and it came out the other, so I don't think the new cooler was clogged. My temp sender is installed in the taco plate (I used a Porsche taco plate/sender), so it's at the bottom of the sump. I think the valve plunger/piston is open all the time because there is a ridge of aluminum keeping it open in the case. You can kind of see it in the picture, although it's hard to take a picture where the focus is at end of the hole. I just don't think that plunger is making a good seal so it's always bleeding oil at any pressure.
lil-jinx
lil-jinx is offline
PostPosted: Thu Jul 10, 2025 3:15 pm    Post subject: Re: Oil Cooler bypass issue? Reply with quote
1974 parts bus
captainstick
PostPosted: Thu Jul 10, 2025 1:21 pm    Post subject: Re: Oil Cooler bypass issue? Reply with quote
lil-jinx wrote:
it the thermostat controlled flaps hooked up and working correctly, and directing air thru the cooler,is the cooler free of dirt and debris.
The thermostat is long gone, but I have the cooler control flap (took me a few months to round one up) and screwed it down to the square tin air duct thing so it's always forcing air into the cooler. I even replaced the cooler with a new one, so it's definitely not blocked. If I turn on my windshield defrost, there is air moving so I'm sure the fan is moving air.
My best guess is something is not sealing properly with the cooler bypass valve. Like I showed in that picture I posted with my post it looks messy inside the case at the top of where that plunger closes the opening. I'm thinking about getting a milling bit and trying to clean it up. I'm just worried I'll make it worse or ruin the case somehow. The threads for the nut that seal up this contraption are already sketchy. It's a bit of a maze trying to get that back on without stripping it worse than it already is. That's also another clue that some previous owner was messing with this thing trying to get it to work at some point. I should probably just use the external cooler and be happy it works at all.
lil-jinx
lil-jinx is offline
PostPosted: Thu Jul 10, 2025 1:10 pm    Post subject: Re: Oil Cooler bypass issue? Reply with quote
1974 parts bus
captainstick
PostPosted: Thu Jul 10, 2025 11:57 am    Post subject: Re: Oil Cooler bypass issue? Reply with quote
raygreenwood wrote:
Unfortunately, I don't have a mechanical oil pressure gauge. I do have a vdo gauge using the dual sender at the oem port on the top of the case, and it's reading like 40-50 psi cold at idle, and drops to about 10psi when hot.
This alone looks like you are bypassing the cooler due to excess pressure.
How is this external oil cooler plumbed into the system?
Ray
I used an EMPI oil filter sandwich adapter (with the thermal bypass valve) and another amazon adapter to get the empi adapter low enough to have the output hoses clear of the push rod tubes. The hoses from the adapter to the cooler are 10AN. The external oil cooler is mounted under the bus frame about 3 feet forward of the engine tilted a bit to catch more air. For what it's worth, the oil pressure readings are about the same when I disconnect the external cooler (by removing the sandwich adapter).
raygreenwood
PostPosted: Thu Jul 10, 2025 11:25 am    Post subject: Re: Oil Cooler bypass issue? Reply with quote
Ray
captainstick
PostPosted: Thu Jul 10, 2025 9:55 am    Post subject: Re: Oil Cooler bypass issue? Reply with quote
raygreenwood wrote:
captainstick wrote:
raygreenwood wrote:
KTPhil wrote:
I didn't know the grooved plungers were ever used on Type 4 motors.
I have to l99k at the book but I also do not remember the grooved plunger on type 4.
Also, what oil are you using?
Ray
I am currently using Mobil 1 20/50, but I tried 10/40 and it seemed the same in terms of oil temps and pressure.
Ok...if it runs no different with 10/40....then there is no reason for the 20/50 which is what usually causes oil cooler bypass. But before getting into any changes right now, connect q mechanical oil pressure gauge at the port where the oil pressure switch goes and let's see what you have cold and fully warmed up.
Ray
Unfortunately, I don't have a mechanical oil pressure gauge. I do have a vdo gauge using the dual sender at the oem port on the top of the case, and it's reading like 40-50 psi cold at idle, and drops to about 10psi when hot. At 4000 rpm when it's warmed up, it's at about 40psi when using the remote oil cooler. If I'm not using the remote oil cooler, it will drop low enough at idle for the idiot light to turn on when it's very hot. And it's only about 20psi at 4000 rpm.
raygreenwood
PostPosted: Thu Jul 10, 2025 9:44 am    Post subject: Re: Oil Cooler bypass issue? Reply with quote
Ray
Ray
captainstick
PostPosted: Thu Jul 10, 2025 7:21 am    Post subject: Re: Oil Cooler bypass issue? Reply with quote
Ray
raygreenwood
PostPosted: Thu Jul 10, 2025 6:59 am    Post subject: Re: Oil Cooler bypass issue? Reply with quote
Ray
KTPhil Premium Member
KTPhil is online now
PostPosted: Tue Jul 08, 2025 4:08 pm    Post subject: Re: Oil Cooler bypass issue? Reply with quote
Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback
captainstick
PostPosted: Tue Jul 08, 2025 2:52 pm    Post subject: Re: Oil Cooler bypass issue? Reply with quote
Bobs67vwagen wrote:
I have messed with these on type 1s in the past and found some that were stuck in there. My solution was to get it out, clean the piston and spring and then with wet type fine sandpaper and oil and a dowel work the passage until the piston moves freely in there. A lot of do a little and try it type thing. When you are satisfied with the fit flush it out with wd40 and put it back together. Good luck-Bob
That makes sense, thanks. The piston was kinda stuck in there.
Bobs67vwagen
Bobs67vwagen is offline
PostPosted: Tue Jul 08, 2025 1:55 pm    Post subject: Re: Oil Cooler bypass issue? Reply with quote
