69 Beetle, Shifting problems
Bobs67vwagen
Bobs67vwagen is offline
PostPosted: Tue Jul 22, 2025 5:43 pm    Post subject: Re: 69 Beetle, Shifting problems Reply with quote
There always seems to be quite a few listed in the samba classifieds in the 68 and newer parts section. Check there.
abicat
abicat is offline
PostPosted: Tue Jul 22, 2025 4:01 pm    Post subject: Re: 69 Beetle, Shifting problems Reply with quote
Can anyone recommend best place to order a replacement shifter for 68 beetle?
RLFD213
RLFD213 is offline
PostPosted: Thu Jul 17, 2025 2:36 pm    Post subject: Re: 69 Beetle, Shifting problems Reply with quote
lol… that coupler is done…. Buy a good coupler. There is a guy in the classifieds that sells good solid shift couplers. Keep the short shift kit and you’ll enjoy the shifting.
olnick
olnick is offline
PostPosted: Thu Jul 17, 2025 1:08 pm    Post subject: Re: 69 Beetle, Shifting problems Reply with quote
Very Happy Don't waste your time with the OEM style shifter bushing! Look up on line for a two piece replacement bushing. Mine was ~ $40.00 well worth the investment!! NO need to remove the shift rod only remove it from the transaxle to allow additional movement. total time for me was about an hour out and in. this included removing the driver seat for better access.
after this was installed the shifter works like a straight into the transmission shifter lever ZERO free play and shifts smooth as silk!!
Olnick
CoastalBug
CoastalBug is offline
PostPosted: Wed Jul 16, 2025 1:41 pm    Post subject: Re: 69 Beetle, Shifting problems Reply with quote
I'm having the same issue. Ground the gears in going into reverse, first, and second all day yesterday. I assume because she's being driven regularly now that I'll have to look into the same things you are.
Chris - 1968 Beetle Sedan, a book, and a lot of determination.
volky1970
volky1970 is offline
PostPosted: Wed Jul 16, 2025 1:00 pm    Post subject: Re: 69 Beetle, Shifting problems Reply with quote
NJ John wrote:
Also, add safety wire through that grub screw. They can eventually loosen.
Yep, recently I had my tranny rebuild and for some reason forgot to put the wire on the grub screw. Long story short, one night around 11:00 pm and raining, I couldn't shift, pulled to the side and started inspecting until I saw the screw loose.
I ride with tools for everything just in case. Tighten it, and the next day used two paper clips.
1970 Beetle Turbo 2109cc MS II EFI, W/M Injection, Intercooler, FORD Wasted Spark Coilpack, 48lb. Injectors.
Cusser
Cusser is offline
PostPosted: Sat Jul 12, 2025 1:47 pm    Post subject: Re: 69 Beetle, Shifting problems Reply with quote
Bobs67vwagen wrote:
While you have it apart you may want to check the shift rod bushing that is a couple of inches behind the shift rod socket that the bottom portion of the shifter sits in.
Absolutely !!!
Bobs67vwagen
PostPosted: Sat Jul 12, 2025 1:22 pm    Post subject: Re: 69 Beetle, Shifting problems Reply with quote
While you have it apart you may want to check the shift rod bushing that is a couple of inches behind the shift rod socket that the bottom portion of the shifter sits in. I just did one on a 74 bug and the bushing had broken and fallen out of its holder. You have to slide the shift rod all the way forward and out of the bushing holder to replace it. Good luck-Bob
Cusser
Cusser is offline
PostPosted: Sat Jul 12, 2025 12:37 pm    Post subject: Re: 69 Beetle, Shifting problems Reply with quote
I hope your new coupler actually fits, mine did not, was too small to fit over shift rod. I transferred the bushings into the old coupler. Why someone cannot copy a part correctly - beyond my understanding !!!!
NJ John
NJ John is offline
PostPosted: Sat Jul 12, 2025 12:02 pm    Post subject: Re: 69 Beetle, Shifting problems Reply with quote
Everyone says those red bushing break and there you go. Also, add safety wire through that grub screw. They can eventually loosen.
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
my3bugs
my3bugs is offline
PostPosted: Sat Jul 12, 2025 11:36 am    Post subject: Re: 69 Beetle, Shifting problems Reply with quote
i remember putting in one of those quick shift kits in my youth , i think i took it back out the same day , didnt like it .
MIDNR
MIDNR is offline
PostPosted: Sat Jul 12, 2025 11:09 am    Post subject: Re: 69 Beetle, Shifting problems Reply with quote
Thanks!
Did a little more investigating, found the problem. New coupler and bushings ordered.
NJ John
NJ John is offline
PostPosted: Sat Jul 12, 2025 10:40 am    Post subject: Re: 69 Beetle, Shifting problems Reply with quote
That extra thickness is a “Quick Shift” that someone added. You can remove it and give it a try. Keep the factory plate. You may have to use shorter bolts. Check the shift rod bushing right there at the shifter. Then the one under the seat.
MIDNR
MIDNR is offline
PostPosted: Sat Jul 12, 2025 10:16 am    Post subject: 69 Beetle, Shifting problems Reply with quote
I have a new to me 69 beetle and I recently started having problems shifting into 1 or 2nd. Issue occurs when moving or when starting from a stop.
I did some research on the forum and started by taking apart my shifter. I noticed that the lockout plate is considerably thicker than others I have seen. Could this be my problem?
Photos for reference
