DCOE Guys, I need your assistance please
oprn
oprn is offline
PostPosted: Wed Sep 17, 2025 8:06 am    Post subject: Re: DCOE Guys, I need your assistance please Reply with quote
That would do it!
slayer61
slayer61 is offline
PostPosted: Wed Sep 17, 2025 6:30 am    Post subject: Re: DCOE Guys, I need your assistance please Reply with quote
Thanks to tech support at Turbosmart and Chip, I discovered, once again, that my exhaust leak at the waste gate was "self inflicted" Embarassed Embarassed Embarassed
I saw the shiny ring in the waste gate box, but the instructions made no mention of it Rolling Eyes Rolling Eyes Rolling Eyes
So the "flame ring", otherwise known as the valve seat has been installed Idea
And the afr sensor has been relocated to the turbo outlet.
Once the rest of the neighborhood wakes up, it'll be testing time again!
Stay tuned
Cusser wrote:
... Most folks are idiots when it deals with electrical !!!
67rustavenger wrote:
3/4 race cam? What's missing, one of the lobes? Shocked
Paul
'68 Manx clone... Sears??
RLR/Strange brakes
2276 built on AS21 case
W-125 w/ GB 1.25:1 rockers
Mahle forged pistons
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
RAD 3071 Turbo
EMPI GTV 2 STG II wedge ports
MSD Box and distributor
Car Craft turbo header
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger Facebook Twitter Instagram Gallery Classifieds Feedback
oprn
oprn is offline
PostPosted: Tue Sep 16, 2025 8:44 pm    Post subject: Re: DCOE Guys, I need your assistance please Reply with quote
There you go! You learned something, now you can have the rest of the day off!
Very Happy
BFB
BFB is offline
PostPosted: Tue Sep 16, 2025 8:30 pm    Post subject: Re: DCOE Guys, I need your assistance please Reply with quote
Ok, so according to the page ( link below ) the corvair did not use a wastegate.
Supposedly boost was limited by design , restriction of exhaust and flow of carburetor. Carb i guess i could see as its been said that carb will limit boost of a supercharger when cruising at part throttle.
https://macsmotorcitygarage.com/turbos-for-the-people-1962-corvair-monza-spyder/
Most experts aren't.
BFB
BFB is offline
PostPosted: Tue Sep 16, 2025 5:57 pm    Post subject: Re: DCOE Guys, I need your assistance please Reply with quote
well that's pretty interesting, can't say ive ever seen it work but that doesn't mean it can't! I would've liked to have rode in it.
I do have some corvair engines and stuff but not any of the factory turbo stuff so in all honesty I can't say that they did or didn't but so far I haven't seen a set up without, again that doesn't mean anything though.
I'll have to do some research on that
oprn
oprn is offline
PostPosted: Tue Sep 16, 2025 3:25 am    Post subject: Re: DCOE Guys, I need your assistance please Reply with quote
It was a Rayjay sized for a 1584 but on a 1737. Reached crossover at 2300 RPM. If I did a flat out run through the gears this is about how it went if my memory serves.
1st 6 psi 5000 RPM, Wheel spin hard to control
2nd 12 psi 5000 RPM
3rd 15 psi 4800 RPM
4th 15 psi 4200 RPM
Stock Rabbit gearing. So if anything it was sized a bit small by most fellow's standards.
That would be pretty poor at the strip I am sure but I don't normally drive that way, it's a street car. To put it in better perspective if driving 60 mph/3500 RPM at no boost and pull out to pass, by the time I am beside the car I'm at 80ish, 4800 RPM, 15 psi and the front tires are starting to drift with the road crown. Time to back off the loud peddle pressure.
As for high RPMs... don't do that, no need to. I have all the power I need at moderate RPMs. That is the beauty of turbo boost! Before the turbo I used to flog that engine up to the 6250 factory red line on a regular basis. No need to now.
Afterthought here, I don't believe the turbo Corvair had a wastegate. Correct me if I am wrong...
BFB
BFB is offline
PostPosted: Mon Sep 15, 2025 5:52 pm    Post subject: Re: DCOE Guys, I need your assistance please Reply with quote
yeh the whole not running a waste gate might work for low boost but not anything else. id definitely overboost my rail. one time I was in a Honda that had an Acura engine swap and boosted too, to my surprise that thing went from 3k rpm to like 7k in a split second , there's no way in hell you could shift fast enough to control boost in that thing, you could barely shift fast enough, period.
in theory I guess you could pick a turbo that'd not flow enough at high rpms but in doing so your running that turbo outside of its efficiency range , and for how long before it "stalls" ( for lack of a better term).
not saying you didn't do it Oprn, or that it wouldn't work, these are just the problems with doing it. thinking more about it, if anything I'd bet your turbo was too big and wasn't spooling up which is why you could do this.... still running outside of its efficiency range either way you go though
slayer61
slayer61 is offline
PostPosted: Mon Sep 15, 2025 7:07 am    Post subject: Re: DCOE Guys, I need your assistance please Reply with quote
oprn wrote:
The need for a waste gate is dependent on how your turbo is sized and your driving style. I didn't have one on mine, I just grabbed the next gear when the boost gauge got high enough. That was on a daily driver not a race car.
That's not me... I'm gonna need a functional waste gate
Paul
RLR/Strange brakes
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
RAD 3071 Turbo
oprn
oprn is offline
PostPosted: Mon Sep 15, 2025 5:02 am    Post subject: Re: DCOE Guys, I need your assistance please Reply with quote
67rustavenger
67rustavenger is offline
PostPosted: Sun Sep 14, 2025 5:52 pm    Post subject: Re: DCOE Guys, I need your assistance please Reply with quote
Paul,
You're gonna need to disassemble and clean the BOV. They get carboned up and stick slightly open from time to time.
If cleaning it doesn't cure the slightly open issue. You may need to install a stiffer spring.
Do you have vacuum lines controlling the BOV? If so, check for leaking vacuum lines affecting the valve closure.
The draw threw set ups don't use a BOV.
Fair enough. So it's a waste gate. It's still open and allowing fresh air to enter the exhaust system causing, the lean AFR Readings.
I was offering help to remedy the issue of the stuck open valve.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
panel
panel is offline
PostPosted: Sun Sep 14, 2025 5:07 pm    Post subject: Re: DCOE Guys, I need your assistance please Reply with quote
Paul,
My '65 Bus~Subaru EJ20 Megasquirted Turbo conversion
slayer61
slayer61 is offline
PostPosted: Sun Sep 14, 2025 1:29 pm    Post subject: Re: DCOE Guys, I need your assistance please Reply with quote
BFB wrote:
answers your question about a leaking wastegate, id move that AFR sensor post turbo
Yup. The dump pipe will go to the welder Monday or Tuesday. I also have a ticket in to Turbosmart for repairs or replace the waste gate. Thanks for your help
Paul
RLR/Strange brakes
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
RAD 3071 Turbo
BFB
BFB is offline
PostPosted: Sun Sep 14, 2025 12:56 pm    Post subject: Re: DCOE Guys, I need your assistance please Reply with quote
slayer61
slayer61 is offline
PostPosted: Sun Sep 14, 2025 10:28 am    Post subject: Re: DCOE Guys, I need your assistance please Reply with quote
Sunday afternoon update:
The waste gate has been removed Embarassed and a blank plate fitted. That's right, no boost controller. With the provided f8-55 idle jets, and some twisting of the mixture screws I was able to get a solid, stable 1000 rpm idle at 14:1 on the afr.
That's progress, right?
Paul
RLR/Strange brakes
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
RAD 3071 Turbo
slayer61
slayer61 is offline
PostPosted: Sun Sep 14, 2025 9:43 am    Post subject: Re: DCOE Guys, I need your assistance please Reply with quote
The valve moves freely. It comes to a dead, solid stop and just doesn't close Crying or Very sad
Paul
RLR/Strange brakes
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
RAD 3071 Turbo
67rustavenger
PostPosted: Sun Sep 14, 2025 9:17 am    Post subject: Re: DCOE Guys, I need your assistance please Reply with quote
Paul,
Buy Once, Cry Once!
chrisflstf
chrisflstf is offline
PostPosted: Sun Sep 14, 2025 8:46 am    Post subject: Re: DCOE Guys, I need your assistance please Reply with quote
Is that simply a bad wastegate? Do they typically go bad often?
slayer61
slayer61 is offline
PostPosted: Sun Sep 14, 2025 6:46 am    Post subject: Re: DCOE Guys, I need your assistance please Reply with quote
This is really puzzling....
The afr is reading dead lean at idle, and because I'm still pretty old school, I pulled a plug. It's pig rich. I think my lean reading is coming from my waste gate. (I have them mounted directly across from each other)
This morning I removed the waste gate and sure enough, there's a gap between the valve and the seat. It is NEVER all the way closed. Even pushing the diaphragm won't close the valve. Embarassed
Paul
RLR/Strange brakes
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
RAD 3071 Turbo
BFB
BFB is offline
PostPosted: Sat Sep 13, 2025 2:57 pm    Post subject: Re: DCOE Guys, I need your assistance please Reply with quote
slayer61 wrote:
BFB wrote:
I wouldn't worry about what AFR is at idle , worry about what it is through the rpm's and under boost
I'd like to, not worry about it, but I watch the afr gauge go dead lean, right before it dies.
that could be caused by a few different things but open your idles up more just to see what it does. if it helps then you know you probably need bigger idle jets. if not then its probably something else, like you might need to drill a butterfly.
I should mention that the afr sensor is directly opposite of the waste gate. When I installed the waste gate, I noticed that it was cracked open ever so slightly. Does this allow air to be drawn in when not on boost?
I don't know about that but it'd definitely delay boost coming in
also might be what your trying to get it to idle at too? draw throughs ive messed with seem to like to idle no less than 1000 rpm , maybe 900
slayer61
slayer61 is offline
PostPosted: Sat Sep 13, 2025 1:09 pm    Post subject: Re: DCOE Guys, I need your assistance please Reply with quote
Paul
RLR/Strange brakes
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
RAD 3071 Turbo
