16CVs Samba Member
Joined: February 22, 2004 Posts: 4308 Location: Redwood City, California
Posted: Wed Dec 10, 2025 1:32 pm Post subject: Re: Modern door panels for Vanagon |
Give it a more modern feel. Possibly keeping them out of the way of the windows. Would need to check on wire length to ensure it would reach.
The down side would be spilling into the switches. But modern cars have that and it seems to work.
I would keep the mirror control in place as that is rarely used. _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
dobryan  Samba Member
Joined: March 24, 2006 Posts: 17353 Location: Brookeville, MD
Tristar Eric Samba Member
Joined: July 25, 2004 Posts: 1267 Location: Portland, Or
Posted: Wed Dec 10, 2025 12:24 pm Post subject: Re: Modern door panels for Vanagon |
| 16CVs wrote: |
| Is there enough area on top of the speaker that you could mount your power window switches using the stock bezel? |
We can definitely make that a possibility. Is there an advantage to having them there? _________________ Vanagon/Transporter flares here: www.terrawagen.com
[email protected] |
E1 Samba Member
Joined: January 21, 2013 Posts: 8835 Location: Westfalia, Earth
Posted: Wed Dec 10, 2025 10:39 am Post subject: Re: Modern door panels for Vanagon |
Looks better…
Right now being all jacked up on coffee and staring at snowy alps, I got to pondering distance from seat side to cubby area… how to maximize space with someone sitting in the seat(s) and knowing available space for a “non-square or flat” cubby design — fitting both a 110 lb. person or 250, forward seat position and all the way back.
Race seat foam… it’s used to fit drivers perfectly… four Hefty bags needed total, two sitters at the two weights, seated both fore and aft… add catalyst, close door, foam expands to fill everything between seat and maybe a flat, Masonite, dummy door panel for the process.
The foam isn’t cheap, but there’s one way to find max size.
What you’d end up with is “plugs” to measure and determine all touch points on a “non-flat” custom-contoured cubby, then back away the cubbies’ closest point maybe a half-inch.
I truly believe there’s no such thing as “too much storage space,” we use stock ones both left and right — and they’re *packed*.
For a flat cubby, of course much easier is just measuring the minimum distance from seat to flat-faced cubby, which I’m sure you did, but it’s still critical to know how much stock seats deflect *per body weights*.
>>> For thoughts of separated “boxed” areas in the cubbies, or just a sample of general uses in one case, or more than likely, utterly-useless drivel…
Left Cubby, from rear:
— Battery load tester
— Multimeter
— Rear: Antique rectangular can: small scissors, jewelers drivers
— Front: Digital tire gauge, tape measure
— Rear: Matched can: Sharpies, pens, small screwdriver
— Front: Leatherman
Right cubby, from rear:
— Eyeglass cleaning kit in Ziploc
— Bug juice in Ziploc
— Three eyeglass cases
— Two Element E100 extinguishers
— Sharpies, pens, markers, crayon to mark tire flips/rotations
There is nothing in the cubbies we don’t regularly use (EDIT: Except the extinguishers! ). I love cubby storage, partly as I’d rather convert the glove box into a humidor.
Keep developing, and still hope that many more throw down here. Many to most are afraid of “offending” in creative cases, which they shouldn’t be with a pro-run deal. So personally (for my own stuff at least), I always encourage honest input as success can depend on it.
The greatest things rarely come from just one head. _________________ If ever twice as rich, we’re gettin’ a double-wide
’84 “Westfailure”/2.1 Digijet/5.43 Ring & Pinion/Peloquin/D-rated BFG KO2s
AI has spoken to further illiteracy, to steal, to cheat, and to replace humans
The caveman’s first question to the headhunter: “Hey, you got any coffee?”
16CVs Samba Member
Posted: Wed Dec 10, 2025 9:26 am Post subject: Re: Modern door panels for Vanagon |
Is there enough area on top of the speaker that you could mount your power window switches using the stock bezel? _________________ 1987 Syncro Westfalia Triple knob (bastard)
Posted: Wed Dec 10, 2025 9:05 am Post subject: Re: Modern door panels for Vanagon |
Great feedback!
It's hard to please everyone I know. This process is in the design phase for a reason, we want to get it right. For me personally a new door panel needs to check a few boxes. Does it look good?, does it fit the period without looking like something else?, does it cure some of the problems that factory door panels lack?.
Here's a few more pics of the direction...
[email protected] |
E1 Samba Member
Posted: Sat Dec 06, 2025 5:02 pm Post subject: Re: Modern door panels for Vanagon |
Man, those look mahvelous.
Taste aside, speaking only of design with the least buyer resistance, the storage space may be a bit too mod strictly for the period — but a gradually-radiused top edge would sure do it.
Have an area for speaker holes if wanted (maybe in stock spot?), with an optional swiveling speaker base/mount to angle the speakers, and an option for hole cutting @ maybe $10-15/hole… and that fits retro, retromod, well-restored, customizable, and usability all at once.
But as I recall, the OP is doing these as molded pieces (“fully-formed and shaped,” are these formed from plastic sheets, or covered, or…???).
Maybe there’d still be options for this ^ look if so… fire extinguisher mount option?
Per the OP, I wouldn’t want armrests. I find those a dangerous way to drive (not so much using the factory flip-downs, but even then…). Same with cup holders, regardless of popularity, personally we use wide-mouth Yeti cups on the floor between the seats. But regardless, we don’t want liquids hanging on our doors.
But design by proxy may still prove to suck for our OP.
Hope this gets more opinions! _________________ If ever twice as rich, we’re gettin’ a double-wide
The caveman’s first question to the headhunter: “Hey, you got any coffee?” |
MaineRich Samba Member
Posted: Sat Dec 06, 2025 4:33 pm Post subject: Re: Modern door panels for Vanagon |
Here is a picture of my door panel. |
metahacker Samba Member
Posted: Wed Dec 03, 2025 8:47 pm Post subject: Re: Modern door panels for Vanagon |
interesting
i really like the direction you are going with molded forms, multiple finishes (particularly with the ability to upholster in fabric), accommodating more storage and speaker mounts...etc
now, since you are essentially asking for critique,
i'll give my honest reaction, solely in the spirit of feedback
the "design" feels more like random "decoration" not something driven by design thinking as it does not appear to attempt to incorporate any of the original design philosophy of the vehicle in any way, it just feels like a random set of elements designed in a vacuum giving a 1996 concept car vibe
it does not feel "vanagon" in any way IMO, kind of like how throwing '98 Supra tail lights on a Vanagon rear end would feel.
i can see how a Westfalia interior could inspire the use of the radiused corners and such, that is logical, but the design as is just doesn't seem like the right direction. the ideas behind it are solid, though.
it doesn't latch on to any of the common design themes for modified Vanagons either... as in the techno architectural military industrial kinda looks...and is clearly not "vintage VW" either...
i could see it in a RAM ProMaster or something..maybe a Sprinter... but not a Vanagon..... |
Rusty84camper Samba Member
Joined: April 09, 2012 Posts: 21 Location: United States
Posted: Mon Nov 24, 2025 8:31 am Post subject: Re: Modern door panels for Vanagon |
Here is the sew fine door card I recently installed. It is WAY too thick in certain spots, required some real elbow grease to get it to all clip on and cranks and handles to sit properly. Still working on it. Get lots of compliments in real life about the door cards, some think it's stock. |
SCM Samba Member
Joined: January 26, 2011 Posts: 3483 Location: Bozeman MT
Posted: Thu Nov 20, 2025 10:36 am Post subject: Re: Modern door panels for Vanagon |
| E1 wrote: |
| how many vans even utilize a stereo… ... any design that trades valuable storage space for a mandatory speaker area ...to presume a single 6” round ...high speaker placement seems ideal to me, |
To chime in on E1's earlier comment about angling the speakers upwards and the more recent ones about stereos, placement etc...
My wife has a 92 Geo Tracker and I have an 87 Suzuki Samurai, essentially the same vehicles. Both trucks have the same model of round Kicker speakers - her's has 4" in the dashboard POINTED TOWARD the front seats and 6" speakers facing toward the middle of the vehicle in the rear. Mine has 2 pairs of 6" speakers facing toward the the middle of the vehicle front (down low) and rear. My wife's sound system sounds SOOOOO MUCH BETTER than mine. Definitely consider making the speaker mounts so that they angle toward the driver's and passenger's ears rather than their ankles.
I personally don't need or want any more storage space in my van, particularly not hanging off of the front doors and not at the expense of a less original look or leg room. That's all personal preference though.
My van uses a stereo but its really just a convenient adaptor to play my phone through. I tried using a bluetooth speaker tied directly to my phone but the soundstage was horrible. If I could easily fit 8" or 6x9" speakers in the front and rear of my van I think I would notice a real improvement.
To add to what I wrote above, I have this in my Westy.
I love the factory look but can't figure out why I haven't removed the storage pocket yet. The only things I keep in there is a tire pressure gage and MAYBE an ice scraper. I hate feeling it against my calf when I'm sprawled out for a relaxing drive - and for that reason I think the hard metal edges of the VC/RMW speaker mount pockets would drive me out of my mind - especially if the speaker sound quality wasn't signicantly better than stock. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
Posted: Thu Nov 20, 2025 10:20 am Post subject: Re: Modern door panels for Vanagon |
Let's address a couple of things. One is design and the other is manufacturing.
Design. Lending or leaning toward a more factory look is a desirable feature we totally get it. Making panels that feel like they're at home, agreed. At the same time incorporating more modern features and addressing the short comings of the factory.
Manufacturing. Currently the options for door panels are aftermarket flat cnc cut, from a single sheet. Basic, boring, but fills a purpose and affordability.
Option 2 is a factory style replacement made exactly the way they were made originally, chip board, glued on vinyl, pressed accents. although the exact materials are not available but close enough for a stock look.
What we propose is a formed solution, because that's what we do. We have the ability to Thermoform the shape we want, add the details and make a more modern version. With the constraints of manufacturing we can only do so much, but a balance of new and old is where we are heading. It's hard to please everyone, and we accept that, but at the same time we are investing in making products for our hobby cars. Having choices is nice, modernizing is definitely a bonus in an older car. Follow along, we love the comments so far.
Here's a two factory door panels, one is a GL with roll ups, the other a Caravelle Carat with power.
On the topic of cloth inserts: Yes this is our intention, a drop in insert panel that can either accommodate roll up windows or power windows. You wrap it in the choice of materials you want. _________________ Vanagon/Transporter flares here: www.terrawagen.com
[email protected] |
E1 Samba Member
Posted: Thu Nov 20, 2025 9:26 am Post subject: Re: Modern door panels for Vanagon |
I don’t know about Yous Guys (I’m still a Packer fan), but am curious just how many vans even utilize a stereo… probably “most” have a stereo (we don’t yet), meaning, any design that trades valuable storage space for a mandatory speaker area that serves no other purpose may not apply to many potential buyers — and/or those not using a 6” round, but using another size or shape, and/or a tweeter, Yada Yada Yada. Too many potential variations to presume a single 6” round — and designing in commitment of that.
VW’s solution of high speaker placement seems ideal to me, as does having as much storage as possible.
I added a second, stock cubby and use every single inch of both. Invaluable space.
Tristar, as a Creative for fifty years (and five months), I am sympathetic to hearing critiques from the masses. I get it. So hope you don’t mind the candor… but that said, threads like this can be equal parts productive and maddening, and why any creations thrown out there like this is like choosing a logo via a roundtable of viewers.
That almost never works, but hopefully the thread helps you anyway. In this case, the more input the better in finding what the majority wants, but the pitfalls can be deep indeed.
It's always a challenge to blend modern and retro. But it can be done, and I do it all the time in my own work. _________________ If ever twice as rich, we’re gettin’ a double-wide
pointillist Samba Member
Joined: November 16, 2022 Posts: 94 Location: Portland, OR
Posted: Thu Nov 20, 2025 9:10 am Post subject: Re: Modern door panels for Vanagon |
Not the best picture, but my Doka came with very basic vinyl door cards- no cutouts at all. I added 6” speakers at the bottom, and made a fabric panel (fabric over thin luan) to make the panels match the rest of the van and soften things up a bit. Had to add a spacer for the window crank to clear, and a spacer for the arm rest, but was pretty easy and I’m happy with it. I think adding some sort of fabric insert to the proposed panels would soften the look a lot and make it fit better. You could even just have some sort of insert that people could cover in their own fabric too.
_________________ 89 VW Cabriolet
91 VW Doka
Doka Build Notes
Social Links |
MsTaboo  Samba Member
Joined: June 02, 2006 Posts: 4634 Location: East Kootenay, British Columbia
Posted: Wed Nov 19, 2025 8:06 pm Post subject: Re: Modern door panels for Vanagon |
Not linear enough. The radiuses are too large. Any way to add the pressed indentations similar to stock (and cloth inserts to match seats)?
The speaker/pocket looks ok (ish).
What type of materials do you plan to make the panels out of?
The biggest problem I have with the ABS type panels is the hard surface. A soft padded vinyl type panel will help absorb sound.
The ABS panels remind me of the birch wood panels I used in my Baywindow bus, made the inside of the cabin really loud.
If you're thinking molded plastic it might make more sense to just make the speaker/pocket portion so owners can add to existing door panels.
Similar to what RMW is doing but lighter than the steel they use and closer to what VW used.
https://vancafe.com/door-pocket-pair-with-speaker-mount/ _________________ Currently:
Resist Kleptocratic Oligarchy (and Idiocracy)! |
16CVs Samba Member
Posted: Wed Nov 19, 2025 5:35 pm Post subject: Re: Modern door panels for Vanagon |
Maybe dump the vent at the back of door. 88 and newer they are blocked off and I’ve never seen anyone move the door anyway!
Someone could cut it out if they wanted it.
Stacy _________________ 1987 Syncro Westfalia Triple knob (bastard)
Xevin  Samba Member
Posted: Wed Nov 19, 2025 4:42 pm Post subject: Re: Modern door panels for Vanagon |
| Tristar Eric wrote: |
Version 1
Version 2
I want these but faced with tan corduroy and brown pleather accents . I generally like a stock look but these would be nice and not permanent should someday the “Stock look” comes into fashion on Vanagons.
Love the idea and creativity of these door panels regardless of style. Most Vanagon's I know have all kinds of holes drilled in them and modifications. Why would a snap in door panel be any different. As mentioned above perhaps a retro looking door panel option might be nice. _________________ Keep on Busin'
| 67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
| Clatter wrote: |
Damn that Xevin...  |
| skills@eurocarsplus wrote: |
| SGKent wrote: |
E1 Samba Member
Posted: Wed Nov 19, 2025 4:03 pm Post subject: Re: Modern door panels for Vanagon |
Honest input…
Looks great, design-wise… but waaay too modern-looking for vans averaging forty years old. Maybe offer a second, stock-appearing style like Metahacker suggested?
On a Tesla or other new car, they’d fit right in.
On a classic car, originality fits a broader market — as history has long proven by nearly all classic car aftermarket part sellers. Your second design fits the simplicity and era of VW design much better.
Know, too that in public formats like this, people tend to only comment if they love it. Those who don’t tend to say nothing, and that skews if not invalidates the entire process — to the presenter’s disadvantage in finding actual mass approval or disapproval.
Will add that the lower a speaker is, the less it’s heard. Perhaps angling it up towards the driver and passengers would avert some of this. _________________ If ever twice as rich, we’re gettin’ a double-wide
Posted: Wed Nov 19, 2025 3:55 pm Post subject: Re: Modern door panels for Vanagon |
Here's a few renders so you can see the direction we're heading:
Nothing in stone yet, but we really like the idea of a cloth insert. Looks like there will be 2 versions, one for roll up windows and the other for power.
We really need to talk about speakers though. Is a 6" even what folks want? maybe a tweeter next to it?
Version 1
Version 2
[email protected] |
Posted: Sat Nov 15, 2025 5:44 pm Post subject: Re: Modern door panels for Vanagon |
a nice appearance with a way to have a real finish - not just urethane/ABS.
an area that can be optionally upholstered e.g. in seat fabric, would be nice
something that looks like it could have possibly came stock would be nice, although some may want the "tactical" (e.g. blacked out, textured, CNC, industrial/military, whatever) sort of look too, im sure.
the obvious bits are what everyone universally wants - generous pockets (perhaps with a divider to make pencils/pens not get lost), cupholder, speaker accommodation ..
many also enjoy elasticated net/ "molly" style stuff
good ergonomics with regards to arm rest integration (some people may not care as that's handled by the seats) ..
door pulls ...
again, it should do all that and not look like a big ugly utility obsessed POS that has no even the least some modicum of respecting the original VW/period design philosophy .. :) did i mention it should actually look good? :)
as for more, off the wall, out of the box stuff......
an optional easily reversable external power window motor that simply goes over the window crank shaft splines, like the old hitachi kits :)
also some perfectly matched umbrellas and inserts to hold them inside the opening in the door everyone jams them into would be a nice accessory too :)
people are already doing it...might as well make it as nice as a rolls royce ;-)
