MarkWard Samba Member
Joined: February 09, 2005 Posts: 19093 Location: Retired South Florida
Posted: Tue Dec 09, 2025 5:20 am Post subject: Re: Pedal release for cruise control |
| A result. Thank you. |
Red Ryder Samba Member
Joined: June 26, 2021 Posts: 1226 Location: PNW — Washington
Posted: Mon Dec 08, 2025 3:16 pm Post subject: Re: Pedal release for cruise control |
| MarkWard wrote: |
| Glad you sorted it. If the adhesive doesn’t hold up, I’m pretty sure the pedal is mild steel and fairly easy to drill. Do an 1/8” pilot hole with a sharp bit and follow up with the bit that matches your fastener. Thanks for reporting back. As time goes on, we need to get more innovative when parts are NLA. Maybe post up a picture of your fix for others. |
_________________ “Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
“Scarlett” — 1990 Vanagon Carat Wolfsburg Edition (Tornado Red)
“Nigel” — 1999 Jaguar XK8 convertible (Alpine Green Metallic) |
Posted: Mon Dec 08, 2025 7:17 am Post subject: Re: Pedal release for cruise control |
Posted: Sat Dec 06, 2025 11:17 pm Post subject: Re: Pedal release for cruise control |
Successfully created a replacement right-angled tab from another (non-Vanagon) project. Used a 3M double-sided pad to adhere the L-shaped part to side of the brake pedal arm. Then added a large spring clip on the bottom side of the arm for additional strength. Trying to drill into the cast arm seemed a fool’s errand. _________________ “Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
Posted: Fri Dec 05, 2025 9:36 am Post subject: Re: Pedal release for cruise control |
| latelogan wrote: |
FWIW:
My brake switch vacuum section failed. I just plugged the tube that runs up front at the tee in the engine bay near the vacuum pump.
Electrical part remains working fine for me |
Dumping the cruise vacuum at the clutch or brake pedal was a quicker way to release the throttle and a fail safe if the electronics failed to slow the engine.
Seems a simple tab could be added to the pedal above to operate the switch. It could be bolted or welded. |
latelogan Samba Member
Joined: July 13, 2023 Posts: 85 Location: Parksville british columbia canada
Posted: Thu Dec 04, 2025 6:50 pm Post subject: Re: Pedal release for cruise control |
FWIW:
Electrical part remains working fine for me _________________ 1991 Westy stock 2.1 auto transmission
1978 Westy (Sold)
1971 Westy (Sold) |
Posted: Thu Dec 04, 2025 6:39 pm Post subject: Re: Pedal release for cruise control |
Duplicate. _________________ “Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
Posted: Thu Dec 04, 2025 6:36 pm Post subject: Re: Pedal release for cruise control |
This “H-shaped” part sits over the brake pedal arm like a saddle. One leg broke off but I might be able to effect a repair. _________________ “Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
kamzcab86 Samba Moderator
Posted: Thu Dec 04, 2025 4:55 pm Post subject: Re: Pedal release for cruise control |
| Red Ryder wrote: |
| Part 29 in the diagram below. |
Dropped from the VW parts bin in 2007... not available new unfortunately.
I can't find a picture of it, but perhaps you could fabricate something similar? Kind of like what's shown on this page (albeit for a Subaru conversion): http://subaruvanagon.com/tom/Cruise%20Control.htm (just realized, it's Tom Shiels' site!). _________________ 1986 Cabriolet: www.Cabby-Info.com
2016 Golf GTI S
Chootrain470 Samba Member
Joined: March 01, 2023 Posts: 209 Location: Simi Valley, CA
Posted: Thu Dec 04, 2025 3:49 pm Post subject: Re: Pedal release for cruise control |
| The Gowesty kit eliminates the vacuum line the goes to the front of the van completely. I kept the original switch in a spare parts bin just in case, but it didn't function anyways. On the diagram, the hose #21 just goes from the pump directly to the diaphragm now (#23, 20, 25 eliminated) |
Posted: Thu Dec 04, 2025 3:21 pm Post subject: Re: Pedal release for cruise control |
| Chootrain470 wrote: |
| FYI, I know you are not interested, but I replaced mine with the Gowesty switch. It took less than an hour and I am slow at such things. Works perfectly. |
Thanks! Glad it worked well for you. I know it replaces the electric operation of the original factory switch. What did you do with the associated vacuum tubing? Also, a functioning original switch is almost unobtainium. Did you sell yours? _________________ “Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
Posted: Thu Dec 04, 2025 2:46 pm Post subject: Re: Pedal release for cruise control |
Posted: Thu Dec 04, 2025 1:00 pm Post subject: Pedal release for cruise control |
I am pleased to report that Scarlett still has a working factory cruise control! Well, until yesterday. The small clip on the brake (or clutch) pedal arm that pushes against the plunger of the CC switch broke. Anyone have one in their parts bin they are willing to share? Not looking to replace the whole switch with the GoWesty offering (at least not yet). Part 29 in the diagram below.
