Crow seat belts
Page: 1, 2, 3  Next
clearsurf2001
Samba Vaccinator
clearsurf2001 is offline
PostPosted: Sat Feb 25, 2006 9:39 pm    Post subject: Crow seat belts Reply with quote
Last weekend (President's Day) there was a sand rail fatality at Glamis. One of the questions surrounding this accident was the performance of "sewn in" type belts.
These are the type that are Y yoke w/shoulder straps sewn in to the lap belt or true 4 point type w/shoulder straps sewn in to the lap belt. 5 point, lock and link, and cam lock do not use sewn in shoulder straps and benefit from a completely different interlocking attachment.
While the investigation continues around this issue ... several major buggy manufacturers and Crow themselves have stepped up. If you have "sewn in" shoulder straps (sewn directly to the lap belt without metal lock and link or camlock) regardless of manufacturer ... contact your seatbelt manufacturer and/or your builder. Crow is responding on this issue RIGHT NOW as are the buggy builders.
http://www.crowenterprizes.com/contact.asp
Get ready for the injection Smile
Make sure it is coherent. Rodney
mharney wrote:
I think Glenn has an EMPI crank in his engine.
Tacoma_Kyle
Tacoma_Kyle is offline
PostPosted: Sat Feb 25, 2006 10:47 pm    Post subject: Reply with quote
I am unclear as to what you are saying. So was there an issue with the sewn in sholder straps?
I am wondering how in proper functioning order hey would fail (if thats what your saying), I mean there are more then those two points on those straps that are sewn in.
clearsurf2001
Samba Vaccinator
PostPosted: Sat Feb 25, 2006 10:50 pm    Post subject: Reply with quote
The suspected failure was at the point where the shoulder straps were sewn in to the lap belt. No other attachments were compromised, and no other sewing was suspect.
dr. awsome
dr. awsome is offline
PostPosted: Sat Feb 25, 2006 11:59 pm    Post subject: Reply with quote
Safer type of belt
Not as safe but still much better than 3 points.
The problem is that the stitching may come loose or tear over time where the "link and lock" or " cam lock" belts don't rely on thread to hold the shoulder belts on. Is this what you are trying to say? I think I got it pretty clear but I just want to make sure.
is it time to get out of the dirt and switch to the street?
Skidmark
Skidmark is offline
PostPosted: Sun Feb 26, 2006 12:25 am    Post subject: Reply with quote
Yes... that is what he is saying. I don't run anything but 5 point myself.
Good post... thanks for the heads up.
"It's not complicated, it's just expensive!"
WARNING! This person has been consumed by the Dark Side.
www.socalbajas.com
http://i135.photobucket.com/albums/q148/bajaskidmark/SCBaja.jpg
bajaherbie
Samba Sooner
bajaherbie is offline
PostPosted: Sun Feb 26, 2006 6:10 am    Post subject: Reply with quote
was alcohol involved? can you drink beer at glamis while in the dunes?
blank
baja5
baja5 is offline
PostPosted: Sun Feb 26, 2006 7:17 am    Post subject: Reply with quote
Glamis is patrolled pretty good now.Coolers are inspected before you can get to Compitition hill or Olds.However, that doesn't seem to stop idiots from getting hammered and driving 500 Hp 2000 lb cars.And the rangers usually only check cars coming in on sand highway. All you need to do is go around through the dunes.
bajaherbie
Samba Sooner
PostPosted: Sun Feb 26, 2006 8:41 am    Post subject: Reply with quote
no alcohol is allowed in the dunes at little sahara state park here in oklahoma. the rangers check when you enter at the two gates. however, i've seen people walk a cooler in by cutting across the fence behind the campsites.
personally, i'd never drive off-road under the influence.
was the wreck a collision with another vehicle??
blank
jps1145
jps1145 is offline
PostPosted: Sun Feb 26, 2006 10:10 am    Post subject: Reply with quote
What is the difference in the stitching holding the shoulder strap to the lap belt and the stitching holding the shoulder strap to the metal bracket inserted into the buckle?
I would love to see more info on this particular crash. Not that I'm morbidly interested, I'm more interested in the actual failure. What was the impact, speed, etc. I'd like to know why it failed.
Tehachapi, CA
'69 Baja
Vintage Funco single seater
My Baja
jps1145
jps1145 is offline
PostPosted: Sun Feb 26, 2006 10:24 am    Post subject: Reply with quote
From my experience out there, most of the accedents are not always alchohol related. They are more from inexperienced drivers in the dunes. Many new duners are not taught to approach the top of a dune from an angle in order to see the other side before turning down. They will go balls out straight to it and drop off or hit someone coming up the other side.
When I lived out there, I would avoid the big weekends just because of that.
Tehachapi, CA
'69 Baja
My Baja
clearsurf2001
Samba Vaccinator
PostPosted: Sun Feb 26, 2006 10:47 am    Post subject: Reply with quote
The details of the accident are still under investigation. At this time ... no alcohol was involved, no collision with another vehicle. The vehicle was a high dollar, well built, long travel. Belts were installed correctly. There is debate as to the design of the adjustable seat mounting. The mounting of the seat was not unique and is employed widely in the industry. An alternate seat mounting with no seat adjustment (relying on adjustable pedal mounts) could have (possibly) mitigated the stresses involved in the accident. The buggy was traveling at a high rate of speed (actual speed unknown) in an area close to camped duners (onsite observations cite "too close to camped duners and way too fast"). The buggy hit a "kiddie track" (made by small riders, usually on small quads that create sand berms due to repeated runs in the same track). Buggy was launched "nose up" and initial impact was on the rear (tail stand) followed by end over (endo) cartwheels. Driver was a large male. Seat showed evidence of deformation near upper portion (including headrest), probably resulting from initial tail impact. Deformation of seat could have resulted in excessive slack in belt adjustment. Subsequent cartwheel motions forced driver forward. Belt sewing at point where shoulder strap is sewn to lap belt remains suspect. Failures of metal links or camlocks in this type of accident is unknown.
The larger point here is ... the sewn in type of belt arrangement is suspected. Again ... this is the type that has the shoulder straps sewn in to the lap belt. If you examine the pictures in one of the previous posts ... you can see that the stresses on the sewing would be far greater in this design than the 5 point system. The buggy manufacturers and the belt maker feel strongly enough that the "could be" factor in this accident warrants immediate action.
jps1145
jps1145 is offline
PostPosted: Sun Feb 26, 2006 11:03 am    Post subject: Reply with quote
I'm with you. I can't tell you how many times I've seen some guy hauling ass through the "camping" areas or close by and hit one of those kid tracks at high speed. This happens down at Gordon's a lot in the "Buggy Flats" area. What a bummer.
As you get more info on this will you share it?
Tehachapi, CA
'69 Baja
My Baja
clearsurf2001
Samba Vaccinator
PostPosted: Sun Feb 26, 2006 6:11 pm    Post subject: Reply with quote
Will do
Jowlz
The Anti-Purist
Jowlz is offline
PostPosted: Sun Feb 26, 2006 6:30 pm    Post subject: Reply with quote
NHRA banned Y harnesses last year. Alot of people blamed the Y belts for injuries...but most of the safety folks think the real culprit was harnesses not properly tightened. I wonder if this was the case in this accident.
What brand were the seats the failed? Were they steel framed seats? I wonder how much the seat failure contributed to the death.
The honey-do list put my project on hold.......
clearsurf2001
Samba Vaccinator
PostPosted: Sun Feb 26, 2006 6:46 pm    Post subject: Reply with quote
Jowlz ... refer to the lengthly post above. Seats were steel framed, name brand, suspension type. Much speculation about the mounting arrangement, the seat damage, and possible induced slack in the belt from the first tail end impact. Remember ... several manufacturers sell both Y harnesses and true 4 point harnesses with sewn in shoulder straps. If anyone has these sewn in harnesses ... I would contact the manufacturer and discuss this type of accident. I have a Corbeau 4 point harness (not installed) for a single seat MC powered mid-travel project. Their design incorporates the sewn in shoulder straps. I will cut it up and dispose of it. I haven't purchased my belts for my mid-travel 2 seater. This incident seals the deal for me. 5 points all the way.
Nicksan
Nicksan is offline
PostPosted: Sun Feb 26, 2006 6:59 pm    Post subject: Reply with quote
This might be the one that your reffering to, There was another fatality also but I think that was a quad.
http://www.glamisdunes.com/invision/index.php?showtopic=68634
clearsurf2001
Samba Vaccinator
PostPosted: Sun Feb 26, 2006 7:08 pm    Post subject: Reply with quote
That's the one Nik. This accident has started a firestorm with the Glamis faithful. So far the following have weighed in:
Due to the recent failure of a particular type of safety belt several Buggy Manufacturers have stepped up and offered a voluntary recall...
Please check the following announcements to see if your car is covered.
(it should be noted that this is voluntary and that there is no official claim of any kind of defect in the affected belts.)
Sand Cars Unlimited Seat Belt Upgrade
Funco Harness Replacement
All Extreme Performance Car Owners!, SEATBELT RECALL!!!
Fusion Off-road Harness Replacement, manditory
Cathi at Suspensions Unlimited says:
"We have been working with Crow ourselves.
Any Suspensions Unlimited Customers.. feel free to contact us regarding this matter.
Call our shop @ 909-230-9797"
Sand Car Services has graciously offered to perform the Crow upgrade for any one with any car free of charge!
As well as Crow ... the first of the belt manufacturers to step up.
http://www.glamisdunes.com/invision/index.php?showtopic=68923
HamburgerBrad
Je suis Napoléon!
HamburgerBrad is offline
PostPosted: Sun Feb 26, 2006 8:44 pm    Post subject: Reply with quote
stuck at the top for all to see
OGST | CU05 | OGJHC
1970 baja|1953 oval
Wanted: two beat up, ugly, curb rashed 6" phone dial wheels
clearsurf2001
Samba Vaccinator
Thanks Brad
el loco kingo
el loco kingo is offline
PostPosted: Tue Feb 28, 2006 12:49 am    Post subject: Reply with quote
was this the only death that heppend because of the belts?
how exactly are you supposed to fassen the belts?
is it, lap belts, then shoulder straps?
i know having the belts fassend improperly could result in injury or death, so i want to be clear on the RIGHT way to do it.
CUSTOM OFF ROAD FABRICATION FOR VW TYPE 1.. BOLT ON KITS. for more info, please go to: http://www.myspace.com/blackmetalworks
http://www.thesamba.com/vw/forum/viewtopic.php?t=143790
Page: 1, 2, 3  Next
