1.4 rockers and stock cam 1915
Karl Allen
Karl Allen is offline
PostPosted: Fri Jan 19, 2007 7:31 pm    Post subject: 1.4 rockers and stock cam 1915 Reply with quote
Is there any reason why i can't run 1.4 rockers with my stock cam and heads, in my 1915? and will it free up some more hp?
Howard 111
Howard 111 is offline
PostPosted: Fri Jan 19, 2007 8:55 pm    Post subject: Reply with quote
Yes, a stock cam works with 1.4 rockers and gives a slight boost across the rpm range. You will need shorter pushrods.
RIS
RIS is offline
PostPosted: Fri Jan 19, 2007 9:20 pm    Post subject: Reply with quote
It's won't be a Hi-Revving engine, but it'll have incredible bottom end power.
Richard Sedoris - VW Performance & Machine - Youngstown, OH
http://rismachine.tumblr.com/
YouTube: https://m.youtube.com/channel/UCfTBCG4I61iVm_ROc8OAuOQ
Instagram: @rismachine
Karl Allen
PostPosted: Sat Jan 20, 2007 4:17 pm    Post subject: Reply with quote
I guess im wondering if it is worth it or not , and some people say shim the 1.4 rockers and some say shorten your pushrods? im looking for a little extra hp but mabey i should have gotten bigger heads or a more aggresive cam but this is the first ac motor ive built so i was alittle cautious ive got mabey 600 miles on it and am pretty pleased Smile
vwracerdave
vwracerdave is offline
PostPosted: Sat Jan 20, 2007 5:14 pm    Post subject: Reply with quote
I don't feel buying new $250 rockers and another $100 for new correct length push rods would be worth the small HP gain.
If you come across a good deal on a used set then I might go for it.
Karl Allen
PostPosted: Sat Jan 20, 2007 5:21 pm    Post subject: Reply with quote
So dave the best way to use 1.4 is with shorter pushrods instead of shimming correct
vwracerdave
PostPosted: Sat Jan 20, 2007 8:33 pm    Post subject: Reply with quote
Yes, the correct way is cut to length push rods.
However, there are so many variables between different brands of all parts used that every engine must be measured and set up accordingly.
Multi69s
Multi69s is online now
PostPosted: Wed Feb 14, 2007 3:29 pm    Post subject: Reply with quote
My dad and I both use this setup in our bajas, but we are running 2010s. Great low to mid range but peters out at about 5200. Yes, the correct way to setup is adjusting the pushrod length.
69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight=
