Powder Coating Rims
Forum Index -> Custom Wheel/Tire Share: Facebook Twitter
gwol
gwol is offline
PostPosted: Fri Mar 16, 2007 6:53 am    Post subject: Powder Coating Rims Reply with quote
I’m looking to have my rims powder coated to match the body.
The shop is having a hard time matching the body color L380.
Is it a hit or miss type process or are there color formulas for powder coating?
Second how do I take care of this rust on my brake drums?
I was thinking of wire brushing them, then just painting them.
Thanks Gus
Check out this these youtube videos videos
https://www.youtube.com/channel/UC9hP9luWy0gYZBnv2-_248A/videos
Kubel Nick
Kubel Nick is offline
PostPosted: Fri Mar 16, 2007 9:09 am    Post subject: Reply with quote
There isn't a much color available for poweder coat then regular paint. You can easily mix paint to change the shade a couple degrees up or down. I don't think you can mix powder coat
wheel607
wheel607 is offline
PostPosted: Fri Mar 16, 2007 11:28 am    Post subject: Reply with quote
Go to a powder coater that does alot of work. BIG SHOP! They have tons of places they can order powder from. Most little operations want to use the powder on hand because they do not want to buy a new box of color to use on one job only. You can get the color you want if you are willing to buy a full box of powder. I just looked at over 300 samples to get Reed Green....spot on! Also, having 5 wheels powdered with the (right) special ordered powder and beadblasting will cost you about $100.00 each wheel. I have paid as little as $40 per wheel in black only.
VWsArent4Hippies
VWsArent4Hippies is offline
PostPosted: Fri Mar 16, 2007 11:45 am    Post subject: Reply with quote
Do those prices include stripping the wheels too, or did you do that yourself?
aeromech wrote:
in my opinion you don't know shit
wheel607
wheel607 is offline
PostPosted: Fri Mar 16, 2007 11:56 am    Post subject: Reply with quote
The included in the price"beadblasting" is the stripping.
VWsArent4Hippies
PostPosted: Fri Mar 16, 2007 12:16 pm    Post subject: Reply with quote
Sorry, I guess I should of read that slower, I see where you said that now, thanks
blankmange
Type 3 Darksider
blankmange is offline
PostPosted: Fri Mar 16, 2007 12:25 pm    Post subject: Reply with quote
I just recently had a set of turtlebacks done at $50 per wheel, including beadblasting and taping off of the rim for polishing...
póg mo thóin
Certified DHS Technician
Samba Member # 24517
gwol
gwol is offline
PostPosted: Mon Mar 26, 2007 7:01 am    Post subject: Reply with quote
Well I got the rims back, the color is way off.
According to the Samba color chart, the wheel disc should be L381
Sea Green but I wanted them to be L380 Turquoise to match the body.
I’m not happy with them, but I will live with them over the summer.
I painted the inner ring silver beige, mounted the new tires and I’m good to ride.
Maybe once I get the wide white-walls mounted it may look ok.
What do you think, is this something you could live with?
Am I being to picky? Gus
dubtype1
Vdubn' Till I Die
dubtype1 is offline
PostPosted: Mon Mar 26, 2007 10:47 am    Post subject: Reply with quote
the white walls should help, but it doesn't look bad. my .02 cents
MIAMI V-DUBS
Caleb
'65 Beetle project
dlxcoupe
dlxcoupe is offline
PostPosted: Mon Mar 26, 2007 5:15 pm    Post subject: Reply with quote
I epoxy primered the outer sides... I am going tp POR15 the rest.
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Mon Mar 26, 2007 9:28 pm    Post subject: Reply with quote
Honestly, they do look way off. Just a thought, you can paint over the powder coat after you sand it down good and then primer. I would take a small part off your car that has the correct color on it and take it to an automotive paint supply house. They can match it spot on and even put it in spray cans for you. Then, sand, primer and repaint the correct color on them.
The Samba member since 2004.
Reply to topic    Forum Index -> Custom Wheel/Tire All times are Mountain Standard Time/Pacific Daylight Savings Time
