EL DUB Samba Member
Posted: Sun Jan 13, 2008 1:37 pm Post subject: What is this rear brake part called? |
The square block where the adjusters go opposite the wheel cylinders _________________ Castle Rock, Co
Eric and Laura's DUB "EL DUB"
1964 Deluxe Bus
1959 Single cab
1963 Double Cab{coming soon}
SBS #77 Cuarenta Seis Para Vida
*****WTB Circle Motors Long Beach,Ca Plate frame.****** |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Sun Jan 13, 2008 1:57 pm Post subject: |
That is just the adjuster mounting block.
It is not available as a spare part. It is welded to the backing plate.
You are going to need to find a complete backing plate.
What the heck happened?? That took some force to bend that. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
EL DUB Samba Member
Posted: Sun Jan 13, 2008 2:07 pm Post subject: |
those are not my plates usta pic for an example _________________ Castle Rock, Co
1964 Deluxe Bus
1959 Single cab
EL DUB Samba Member
Posted: Sun Jan 13, 2008 2:08 pm Post subject: |
also working on my rears and they are just pretty tight so i wanted to see if they were a replacable part or if they are able to be lubed or refurbished etc _________________ Castle Rock, Co
1964 Deluxe Bus
1959 Single cab
localboy Samba Longboarder
Joined: December 06, 2003 Posts: 5153 Location: "Mainland", PNW
Posted: Sun Jan 13, 2008 2:22 pm Post subject: |
The star adjusters should come out so they can be cleaned/lubed. _________________ One man's "patina" is another man's cancer...
Black '65 Resto-Custom S Notch 2110 cc powered
original paint Pearl White '66 Westy SO-42
Allstate single-wheel trailer project |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23504 Location: Kimball, Mi
Posted: Mon Jan 14, 2008 4:00 pm Post subject: |
localboy wrote: |
The star adjusters should come out so they can be cleaned/lubed. |
A little heat and a pair of pliers will get them out. Then just clean and use anti-seeze on them, when you go to put them back together. Just so you know, the star adjusters are available as replacements too, but the star portion is brass rather than steel. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Mon Jan 14, 2008 4:30 pm Post subject: |
Mine are steel Bob.
And they rust. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Posted: Mon Jan 14, 2008 4:57 pm Post subject: |
Yea, Bob. That's what I meant. On my bus they were stuck as the bus literally hadn't moved for 12 years. I got them out, cleaned 'em with a brass wire wheel and used silver anti-sieze when I rebuilt the brakes. And those were brass. _________________ One man's "patina" is another man's cancer...
Posted: Mon Jan 14, 2008 5:00 pm Post subject: |
Mine are steel too. And they rust too. I was just commenting that the replacements being sold are made of brass. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
