Humanure Samba Member
Posted: Tue Nov 11, 2008 8:29 am Post subject: 67 wiper disassembley |
From the picture below, can the plastic gear inside the housing be removed without major effort? I want to remove any old grease the may be underneath, but I can't do a nice job with it installed. Do I need to remove the pivot arm that is underneath on which it is attached to? Or should I just leave it be, blast it with brake cleaner and then repack?
_________________ It is difficult to free fools from the chains they revere. |
Clara  Samba Member
Posted: Tue Nov 11, 2008 9:36 am Post subject: |
You have to wiggle the arm off, then the wiper gear slides out.
BEFORE wiggling the arm off, make sure you know which way exactly on the splines it is installed, as that determines where the wipers park, and og they park on the right. Perhaps a dab of nail polish so you can line it up later?
You don't want them to park in the middle.
I have re-installed the splined arm by trial and error to fix the parking location. It is easier to do before installation in the bus.
Also make sure you don't lose the little cone piece of metal that the adjustment for the wiper motors sets on, or the wipers will be louder. It gets lost in the old grease. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
xavi_242 Samba Member
Joined: May 06, 2005 Posts: 1672 Location: Barcelona (SPAIN)
Posted: Tue Nov 11, 2008 9:44 am Post subject: |
Clara wrote: |
ouch!
mine park in the left (looking from inside..) _________________ 1967 Split SO-42 Dormobile |
Ollie W Samba Member
Joined: May 20, 2004 Posts: 844 Location: Portland, OR
Posted: Tue Nov 11, 2008 9:57 am Post subject: |
Parking wiper blades...must be nice. |
Posted: Tue Nov 11, 2008 11:53 am Post subject: |
Clara wrote: |
Also make sure you don't lose the little cone piece of metal that the adjustment for the wiper motors sets on, or the wipers will be louder. It gets lost in the old grease. |
Whew, I'm glad you said that. From an earlier search before I posted this thread, somebody (I think it was you) else mentioned that cone piece. I went back and looked on the napkin where I smeared the removed grease and on the floor where I disassembled the wiper assembly, no luck. I then took a peek into where the plastic gear is and noticed a blob of grease and found it there. I posted some photos for future reference. I'm guessing that cone piece is placed on the end of the armature shaft. Is that correct? Thanks for the help!
Clara  Samba Member
Posted: Tue Nov 11, 2008 12:26 pm Post subject: |
Ya, that's it. you fit it in the housing before sliding the armature in.
The armature slops around w/o it and so the motor is noisier.
Guess how I know?  _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Culito 11010101
Joined: December 07, 2006 Posts: 5878 Location: Columbia Missourah
Posted: Tue Nov 11, 2008 5:14 pm Post subject: |
Ollie W wrote: |
X2. _________________ © CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote: |
...dont pay no attention to Culito,he's a cornhole.. |
iamdonquixote Samba Member
Joined: January 28, 2003 Posts: 2079 Location: M*ssholia
Posted: Sat Nov 30, 2019 2:17 pm Post subject: |
Clara wrote: |
can't you just reindex the wiper arms on the wiper shafts to do this? |
Clara  Samba Member
Posted: Sun Dec 01, 2019 2:38 pm Post subject: |
iamdonquixote wrote: |
Clara wrote: |
try it and let us know how that works for you. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Posted: Sun Dec 01, 2019 6:40 pm Post subject: |
Clara wrote: |
Clara wrote: |
try it and let us know how that works for you. |
i can't tell if thats sarcasm. |
coolerthanelvis Samba Member
Joined: June 30, 2003 Posts: 924 Location: San Diego, CA
Posted: Sun Dec 01, 2019 8:46 pm Post subject: |
Yes. Yes it is. Moving just the wipers would change the arc of sweep. _________________ Shawn
SV2s member #420
'68 Westy
"Do or do not, there is no try."
-Silent Bob |
Posted: Tue Dec 03, 2019 9:26 am Post subject: Re: 67 wiper disassembley |
I found this thread looking for wiper info. I too removed the mechanism from the motor without marking it.
I cleaned out old grease and reassembled motor. Motor works well at high and low and then I switch to self parking pin 54d to let the motor park. I am going to check the position of the assembly on my other 67' and attempt to line up the splines in the same way. |
