Jacks and Jack Stand
Page: 1, 2, 3  Next
woliver
woliver is offline
PostPosted: Sun Jun 21, 2009 2:50 pm    Post subject: Jacks and Jack Stand Reply with quote
Hey-
I have a 1973 Super, and I think it's time to get going on those brakes. I just (like, hours ago) had the stock jack finally break on me, so I ran out and got one of those 2.5 ton floor jacks and a pair of jack stands. Then I got home a realized that I have no idea where to put the pressure of a floor jack to get it off the ground!
I would love to know if anyone has some good structurally sound jack points, preferably one in the front and one in the back. I assume that the beetle is jsut like any other car, and I can just stick the two stands under the axle once I get it up there?
Here is a link to a similar jack to the one I just bought, if anyone needs to look at it: http://shop.oreillyauto.com/ProductDetail.aspx?Mfr...yCode=3397
where would I jack the beetle up with this?
thanks!!!
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun Jun 21, 2009 3:00 pm    Post subject: Reply with quote
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
redrum71
redrum71 is offline
PostPosted: Sun Jun 21, 2009 3:02 pm    Post subject: Reply with quote
i've jacked my 72 up in th rear off the lower shock mount and put the stands on the torsion housing tubes, the front, I put it unber the frame head, and same for the stands
VW Logo 72 FAT chick Blue Bug
VW Logo 71 baywindow Red Bay Bus -
VW Logo 67 Baja Green Bug
jamesdagg
jamesdagg is offline
PostPosted: Sun Jun 21, 2009 3:03 pm    Post subject: Reply with quote
Glenn has posted that pic tirelessly for years! I keep a copy in my trunk for the mechanic when I get tires changed etc.
jim
'72 FI Westy
'71 Super rear inside defrost vents no longer available
redrum71
redrum71 is offline
PostPosted: Sun Jun 21, 2009 3:04 pm    Post subject: Reply with quote
Glenn wrote:
Damn it Glenn, you beat me to it Cool Laughing
Mr. 010
Glenn is offline
PostPosted: Sun Jun 21, 2009 3:05 pm    Post subject: Reply with quote
Giggity
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
redrum71
redrum71 is offline
PostPosted: Sun Jun 21, 2009 3:08 pm    Post subject: Reply with quote
Glenn wrote:
Giggity
LMAO!!!! Laughing
woliver
woliver is offline
PostPosted: Sun Jun 21, 2009 3:16 pm    Post subject: Reply with quote
hahaha, thanks all, especially quagmire over there Very Happy
66foot
66foot is offline
PostPosted: Sun Jun 21, 2009 9:29 pm    Post subject: Reply with quote
REAR
ALTERNATIVE TO JACK STANDS IF YOU ONLY NEED AN EXTRA 3-4 INCHES
Pat (66foot)
"The perfect race car crosses the finish line in first place and then falls to pieces."
Ferdinand Porsche
unknown force
unknown force is offline
PostPosted: Sun Jun 21, 2009 10:38 pm    Post subject: Reply with quote
thats where i jack up the rear as well, except that my stupid jack keeps breaking my pieces of wood Mad dumbster diving is failing me
1973 Super
http://www.cardomain.com/ride/3252228
mikepickard
mikepickard is offline
PostPosted: Wed Sep 23, 2009 5:28 pm    Post subject: Reply with quote
66foot wrote:
REAR
Awesome. Exactly what I've been looking for.
A bit confused that you've jacked it at points different to the diagram though...
I don't suppose anyone has images of where to jack the front do they ?
(sorry, like the OP - I need it all jargon free!)
askinsb
askinsb is offline
PostPosted: Sat Sep 26, 2009 11:13 am    Post subject: Reply with quote
I'd also like to see a picture of where to put the floor jack in the front, but for a 69 Ghia.
vw_hank
vw_hank is offline
PostPosted: Tue Mar 09, 2010 12:59 am    Post subject: Reply with quote
And for A super, The back is the same. I also yous my floor jack under the stock jacking point just go back as far on it as you can (if you do it at the end it well bend )... And for the front, If I'm just changing A wheel/tire I go to the front sway bar mount, I have also put the floor jack under the "A pillar" in front of the door, if your going to be putting it on jack stands then I'd jack it up on the pan head, and place the jack stands under the sway bar mounts..
66foot
66foot is offline
PostPosted: Tue Mar 09, 2010 5:45 am    Post subject: Reply with quote
mikepickard -
For the front see Jack and Jack Stand Points - SB Front
Pat (66foot)
Ferdinand Porsche
Molly1973
Molly1973 is offline
PostPosted: Thu Jan 23, 2014 10:44 am    Post subject: Reply with quote
Great post here! I haven't been doing this correctly...but will for sure now!
RedBug99
RedBug99 is offline
PostPosted: Mon Jan 30, 2017 6:03 am    Post subject: Reply with quote
Glenn wrote:
Appreciate the info here, but just so I'm clear, would you place the jack stands under these points (rather than the rear axle), or just use these points to raise the car?
GArBa
GArBa is offline
PostPosted: Mon Jan 30, 2017 9:40 am    Post subject: Re: Jacks and Jack Stand Reply with quote
for the rear axle I used a trolley jack under the end torsion tube castings (there is a flat spot at the bottom) to lift each side of the car and then placed the stands under the tubes where shown in the picture.
for the front axle I used a chock of wood and lifted it from the center with the trolley jack , then placed the stands at its ends like shown in the picture
cars:
'97 type 1 1600i
'14 type AA Seat Mii (sadly dead after 270.000 km)
'22 type C1 T-Cross
'23 type AC3 Hyundai I10 (VW no longer makes small cars!)
moped:
'82 Benelli Magnum 3v
Longmont1302
Longmont1302 is offline
PostPosted: Tue Oct 24, 2017 8:50 am    Post subject: Re: Jacks and Jack Stand Reply with quote
I'd like to make sure I've interpreted Glenn's image correctly before I relax the jack on our 71 Super. If I'm reading the following chart correctly I've placed the jack stands under the track control arms: https://www.thesamba.com/vw/gallery/pix/663882.jpg
Once the weight is off the axle these arms drop down and it's tough to get the jack stand out very far from the center of the car.
Here's where I have the jack and have placed the jack stands:
...and a second view:
It just doesn't feel right, but this looks to me like where the red Xs are in Glenn's diagram. Thanks in advance for any help you can offer.
Mr. 010
Glenn is offline
PostPosted: Tue Oct 24, 2017 9:01 am    Post subject: Re: Jacks and Jack Stand Reply with quote
You have a Super Beetle and the diagram is for a Standard Beetle with torsion bar beam.
Don't put them there.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Longmont1302
PostPosted: Tue Oct 24, 2017 9:06 am    Post subject: Re: Jacks and Jack Stand Reply with quote
Thanks, Glenn. I feel silly for missing "on Standard Beetle" written in large letters, but feel a little better that it somehow didn't feel right and I didn't release the jack.
Anyone have a suggestion of where I should put the jack and stands on the 71 Super?
Scott
Page: 1, 2, 3  Next
