fonz15 Samba Member
Joined: April 15, 2004 Posts: 107 Location: los angeles, CA
Posted: Wed Nov 04, 2009 2:44 pm Post subject: timing with a 009 distributor |
| so my stock distributor messed up after 39 years so i got a 009. But my timing is still off. I heard that its hard to get the timing right and i should get a degree pulley or a 009 with a vacuum advance and that either of those should fix the problem. I have a 70 beetle std. stock 1600 engine. thanks for the help guys but what should i do? can i time it right with out the other stuff? will that timing stick? advice?? |
mjenner Samba Member
Joined: November 29, 2008 Posts: 268 Location: essex,on,canada
Posted: Wed Nov 04, 2009 2:47 pm Post subject: |
| 9 Degrees - and -009's don't work well with the 34 pict carb |
Paul Windisch Samba Member
Joined: September 02, 2009 Posts: 2546 Location: Clinton Township, Michigan
Posted: Wed Nov 04, 2009 2:49 pm Post subject: |
In my opinion, you would be better off getting the stock distributor fixed, or getting a replacement of your stock distributor. If you MUST use a 009, get a degreed pulley or a timing light with an advance dial so you can adjust the gun to read advance with the stock pulley, then set it for 32 degrees max advance with engine rpm at 3000+. _________________ *ASE Recertified Master Automotive Tech*
1984 Mexican Beetle
-1914cc
-L3 Heads 35x32 valves 52cc chambers
-0.040" deck for about 9.1:1 Compression
-Engle W110 cam
-CB Super Stock 1.1:1 Rockers
-Stock Heat Exchangers w/ Tri-Mil Muffler
-Dual Weber IDF 40s w/ 26mm venturis
-034 SVDA Distributor
2013 Chevrolet Volt DD
2005 Pontiac Montana SV6
MAHLE Service Solutions
Applications Engineer |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80450 Location: Sneaking up behind you
You time a OO9 to 30 degrees BTDC @ 3500rpm... you should not time it at idle.
They don't make a OO9 with vacuum advance. (and don't say the 0 231 137 009 that's not what he's asking) _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Randy in Maine Samba Member
Posted: Wed Nov 04, 2009 4:20 pm Post subject: |
Here is how to mark a stock pulley....from www.type2.com
Timing the Bosch OO9
by Ken Hooper
The thing about timing is that what matters most is what happens at cruising speed, maximum advance--that's where you can burn up an engine quickly if your timing is too far advanced.
But: The Bosch 009 does not have a predictable advance curve--the German ones are different from the Brazilian ones and the worn ones are different from the new ones and on it goes. The natural result of this is that just because you've timed the 009 properly at idle does not mean you have any way of knowing what's going on at highway speeds.
So while the stock vacuum advance distributors can safely be timed at idle (or even timed statically per Muir, although this is never optimal), the 009 has GOT to be timed to about 30 degrees TOTAL ADVANCE with a timing light. Which means you have to rev it up until the distributor stops advancing before you can dial it in.
It takes three hands and if the process isn't painful, you aren't doing it right. =^ ) It's okay to time it statically at around zero degrees in order to get the engine started, but you have to finish the process dynamically by making lotsa noise.
It is very easy to find 30 degrees without a degree wheel as long as you know where top dead center is. From TDC, measure an inch and three quarters (1 3/4") to the right around the diameter of a stock pulley. That's about 28 degrees, go a tinch further and mark it with fingernail polish or something.
If you don't know where TDC is, then you have to pull the #1 spark plug and push the eraser end of a pencil in the hole and rotate the engine and feel the piston until you figure it out.
A basic timing gun is ~$20, get one and carry it with you, it's an irreplacable tool. |
ibjames Samba Member
Joined: October 15, 2009 Posts: 197 Location: San Diego
Posted: Wed Nov 04, 2009 4:29 pm Post subject: |
| when you talk about the degreed pully you are talking about the big one with all the little marks on it right? Don't those run like $30 or so? I'd just get one |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 11142 Location: Black Forest, CO
Glenn  Mr. 010
Posted: Wed Nov 04, 2009 4:52 pm Post subject: |
Or just print this.
Member #1009
#BlueSquare
bookoojoe Samba Member
Joined: October 02, 2008 Posts: 273 Location: Pensacola, Florida
Posted: Wed Nov 04, 2009 5:24 pm Post subject: |
| Glenn wrote: |
Or just print this.
THAT IS BAD ASS! _________________ 1991 Cabriolet. Black with white top. Sexy.
Why is abbreviation such a long word?... Did you know that the fear of long words is called hippopotomonstrosesquippedaliophobia? its true! look it up!
"We learn from history that we don't learn from history." |
Glenn  Mr. 010
Posted: Wed Nov 04, 2009 6:05 pm Post subject: |
| Max Welton wrote: |
Oh, come on!
Isn't a steel ruler on a Berg pulley is a least a little bad-ass?
Yes it is.... but it's better on a red car. _________________ Glenn
Member #1009
#BlueSquare
Posted: Wed Nov 04, 2009 6:51 pm Post subject: |
| we should have that picture stickied? |
Christofur Samba Member
Joined: April 08, 2009 Posts: 155 Location: Auburn, Washington
Posted: Thu Nov 05, 2009 1:25 am Post subject: |
| Glenn wrote: |
They don't make a OO9 with vacuum advance. (and don't say the 0 231 137 009 that's not what he's asking) |
wait wait wait.... i timed my 009 at idle.......should i go retime it at 3500 RPMS? |
Posted: Thu Nov 05, 2009 5:07 am Post subject: |
| Christofur wrote: |
| Glenn wrote: |
What part of this did you miss? |
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Thu Nov 05, 2009 9:09 am Post subject: |
| Randy in Maine wrote: |
| Christofur wrote: |
| Glenn wrote: |
mmhh i timed my bug to 28 or so at idle not at 3500 RPMS better go do that and that would explain the high rpm back fire. |
Glenn  Mr. 010
Posted: Thu Nov 05, 2009 9:15 am Post subject: |
| Christofur wrote: |
| Christofur wrote: |
| Glenn wrote: |
28 at idle will result in 50 degrees advance when driving.... _________________ Glenn
Member #1009
#BlueSquare
