Part ordering
Forum Index -> Water-cooled VW Share: Facebook Twitter
partwerks
partwerks is offline
PostPosted: Wed Jun 23, 2010 7:58 pm    Post subject: Part ordering Reply with quote
Where might be a good place to order a throttle positioning sensor other than the dealer? Seems a bit hard to find one for that year. It is a 7 pin for a 96 Jetta 2.0, stick shift.
ANSAracingb
ANSAracingb is offline
PostPosted: Thu Jun 24, 2010 10:59 am    Post subject: Reply with quote
Volkswagen only made the separate TPS available through 1995.
After that, to replace the TPS, you must buy the entire throttle body.
I would check with the guys in the MkIII forum on the Vortex to see if there's another option; or if an older TB with its separate TPS can be made to work with your manifold?
zuhaelter_82
zuhaelter_82 is offline
PostPosted: Thu Jun 24, 2010 11:20 am    Post subject: Reply with quote
Have you tried to align the sensor with vagcom yet? What is the reason for needing to replace it? Also, what is the part number?
64 Type II
MKI Jetta Coupe Diesel
MKI Jetta Sedan w/TD swap
B5 V6 GLS
B7 TDI Passat SE
partwerks
PostPosted: Thu Jun 24, 2010 9:07 pm    Post subject: Reply with quote
I'm not sure what Vagcom is.
My mechanic thinks it could be the tps.
Primarily it has intermittent cut outs on cold start and once in a while when warm.
I can't get the part to come off once i get the 2 screws loose it begins to pull off but it feels as though something is catching it and preventing it from pulling off. My mechanic says it should just pull off.
Till I can get it off, I can't get any part numbers.
I would think it would be a separate part, otherwise why would it be mounted with 2 screws.
I may just let my mechanic deal with it. I was just wanting to get one ordered.
ANSAracingb
PostPosted: Fri Jun 25, 2010 8:00 am    Post subject: Reply with quote
Unfortunately, that's not always the case. Just because you can remove the part from whatever it attaches to (the TB, in this example) does not mean it is available from the factory as a separate item.
You may be able to get a replacement from aftermarket sources (especially if it is a common problem and someone/some company has a remedy to solve it) whenever something like this arises, but in this case, the 1996 ABA TPS is sold only as part of the TB (from Volkswagen).
partwerks
PostPosted: Fri Jun 25, 2010 7:02 pm    Post subject: Reply with quote
I called the dealer this morning and he told me it is a separate part and that he actually had a returned one on the shelf for $134.00 which is why I was wanting to find one elsewhere.
Problem is that in trying to take it off after the 2 screws come out, it comes out part way and seems to catch on something. Not sure if I should try and pry it a bit or if that will break something and make matters worse.
If I could get it off, I would get the part number off of it.
Reply to topic    Forum Index -> Water-cooled VW All times are Mountain Standard Time/Pacific Daylight Savings Time
