CB Performance narrowed adjustible beam, How to adjust?
spudin
spudin is offline
PostPosted: Thu Jul 08, 2010 4:55 pm    Post subject: CB Performance narrowed adjustible beam, How to adjust? Reply with quote
I bought a brand new narrowed adjustible beam for my '74 standard bug and have installed it , but we cannot get the puma adjusters to go all the way up to the top. They will go all the way down but not up. I called CB Performance about this problem but they were of no help they said just turn the screws in and out to lower and raise the car. I have searched th internet and cannot find anything out on how to adjust the puma adjusters. I guess I am just dumb. Help please.
69 Jim
69 Jim is offline
PostPosted: Thu Jul 08, 2010 5:29 pm    Post subject: Reply with quote
Turning the screws in and out doesn't make much sense. Are the shocks limiting the travel? Are you trying to raise or lower the car?
spudin
spudin is offline
PostPosted: Thu Jul 08, 2010 6:23 pm    Post subject: Reply with quote
I know. I have the shocks out right now and it still won't move. I am trying to lower the car but it is too low and the adjusters won't move up. I'll try and post some pics of it tomorrow. Thanks for the reply.
bugninva
bugninva is offline
PostPosted: Fri Jul 09, 2010 6:24 am    Post subject: Reply with quote
put your jack under the front beam... take the jam nuts off both adjusters, then loosen the nut on the grub enough that the adjuster plate will move out of the grip grooves completely.... jack the car up and the grubs and adjusters should move upward get them to a higher point, tighten the nut. let jack down and bounce on the car or roll it around to settle the suspension... if it is good, install the jam nuts and tighten, if not high enough, repeat the procedure...
[email protected] wrote:
With a show of hands, who has built over 1000 engines in the last 25 years? Anyone?
GEX has. Just sayin
spudin
spudin is offline
PostPosted: Fri Jul 09, 2010 9:19 am    Post subject: Reply with quote
Thanks I'll definately try it.
ashman40
ashman40 is offline
PostPosted: Sun Jul 11, 2010 12:06 am    Post subject: Reply with quote
Are these the type of adjusters on your beam?
If so, you could remove the nuts that tighten the adjuster down and remove the top ribbed part of the adjuster. Lower and raise the front and see of the hex bolt is binding in the slot. The slot should allow the beam to move thru the full range of travel.
There is one other area that could be binding... the ball joints.
Consider that the ball joints can only move thru a certain angle connected to the spindle. When you reach that limit, the front end can't move up/down any further even if there is more adjustment available in the adjuster.
AshMan40
spudin
spudin is offline
PostPosted: Sun Jul 11, 2010 9:45 am    Post subject: Reply with quote
Yes that is my beam, I am going to try this tomorrow. I'll let you guys know what happens. Thanks.
Fred_m
Fred_m is offline
PostPosted: Sun Jul 11, 2010 10:46 am    Post subject: Reply with quote
Whe3n you slam a bug you need special ball joints.
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC-C10-4192
and
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC-C10-4193
They have a wider slot so they don't bind.
You also need caster shims.
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC-C10-4190
and a matching pair of longer bolts.
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC-C10-4028
I guess you fixed the tie rod length already?
69 Jim
69 Jim is offline
PostPosted: Sun Jul 11, 2010 10:51 am    Post subject: Reply with quote
and
Caster shims only if you have a rake. Not necessary if the beam angle isn't changed too much.
spudin
spudin is offline
PostPosted: Mon Jul 12, 2010 11:19 am    Post subject: Reply with quote
Allready bought all that stuff from CB Performance when I ordered the beam.
spudin
spudin is offline
PostPosted: Wed Jul 14, 2010 2:37 pm    Post subject: Reply with quote
Got it raised just enough to clear the tires, thanks guys.
Jerry Hundley
Jerry Hundley is offline
PostPosted: Wed Jul 14, 2010 7:51 pm    Post subject: Reply with quote
and
My car is slammed. I can go as low as 1/2 off the ground and have had no problems what so ever with balljoints binding and dont use caster shims at all.
Jerry Hundley (AKA Slammed 66)
Because Stock Sucks!!!!
70 baywindow deluxe
65 slammed bug
69 bug
64 drag buggy
ashman40
ashman40 is offline
PostPosted: Wed Jul 14, 2010 9:11 pm    Post subject: Reply with quote
So, where was the problem?
It's good to post what you did to fix it (or just what you found) so the next person can use this thread as a solution. Smile
AshMan40
spotco2
spotco2 is offline
PostPosted: Wed Jul 14, 2010 9:50 pm    Post subject: Reply with quote
Do you have any suspension travel?
I've had issues in the past adjusting these front ends out and retaining any travel in the suspension.
69 Beetle
VW's are not just a car, they're an adventure!
spudin
spudin is offline
PostPosted: Thu Jul 15, 2010 5:07 pm    Post subject: Reply with quote
It was binding in the ball joints. It still has 2 notches left to be fully raised, but I don't want it any higher. I think the ball joints are stock length and I need lowered ball joints. Longer length. I may have to change them later but I am going to drive it for a while to see what they do.
andk5591
andk5591 is offline
PostPosted: Thu Jul 15, 2010 6:46 pm    Post subject: Reply with quote
If you have the new springs - it is going to settle a little - mine dropped almost another inch after a month. I have the link pin version and love it.
D-Dubya Manx clone 1914. Ex wifes car.
Maxine 61 Cal-look bug - Ex-wifes car.
There's more, but not keeping them...
