Another Day Under the Bus
spectre6000
spectre6000 is offline
PostPosted: Tue Sep 28, 2010 8:10 pm    Post subject: Another Day Under the Bus Reply with quote
I upgraded to an alternator today and it went more or less without a hitch until I put the engine back in. I fired it up and it wasn't firing on #3. Turned out to be a bad spark plug, so I replaced the spark plugs (only had maybe a thousand miles on a brand new set of Bosch spark plugs...). Now it's running great! Revs up as high as you want just like it should.
Until... I get going and get the RPM up to about the lowest end of the shift range in all gears. I.e., I get it up to around 13 mph and have to shift to second to keep it from squealing, and so on... It's not dependent on speed because I can run 4th gear at lower RPM and it won't squeal. It doesn't squeal if it's out of gear.
When the engine was out, the rear popped up like they do and it leaked a good amount of tranny fluid, so I topped it off when I got back to the house. Ran it again, and once I get up to RPM under load it starts squealing. It's loud enough to hear over a quiet pack muffler in a completely empty panel bus/resonator (the sort that's still too loud to break in or anything at night around here and can be heard coming from a few blocks away when inside). I checked the fan and it's clear (wouldn't be the fan anyway since I can rev it all day long as long as it's not in gear), I adjusted the belt tension (was right on the border between shims), and I phoned a friend. I give up. Ideas?
Jason Hopper
-'58 German Market Deluxe Beetle (in progress)
-'84 M1009 CUCV
-'81 K10
"Buy the best, cry once." -Gene Berg
"A cheap man will always buy the cheapest thing available, and then buys another one hoping for a better result, and then spends the rest of his life in misery complaining about it. A thrifty man will buy a good part once and never think about it again." -RockCrusher
"Don't feed the Shitty Parts Monster!" -Me
mharney
mharney is offline
PostPosted: Tue Sep 28, 2010 8:27 pm    Post subject: Reply with quote
When it starts squealing, push lightly on the clutch. If it stops, it's probably your throwout bearing. The leak from the transmission isn't a good thing.
marklee
marklee is offline
PostPosted: Wed Sep 29, 2010 12:53 pm    Post subject: Reply with quote
squealing with new alternator, check fan belt tension, correct pulley, broken pulley etc
CGLI qualified body repair and refinish tech
CGLI qualified motor repair tech
Qualified automotive Glass installer
Motor Insurance Repair and Research Centre,Thatcham, Advanced Vehicle Damage Estimator.
Police qualified vehicle examiner
Police Class 1 High performance, pursuit trained Advanced driver
