135/80 R15 or 145/65 R15?
Forum Index -> Custom Wheel/Tire Share: Facebook Twitter
Notablecarrot3
Notablecarrot3 is offline
PostPosted: Sat Jan 08, 2011 7:43 am    Post subject: 135/80 R15 or 145/65 R15? Reply with quote
Hi Guys,
I've just had a new 2.5 inch narrowed beam and dropped spindles fitted to my bug. The front tires aren't allowing me to go low enough, they're just too tall (firestone f560 145/80 R15) even though they are very nice looking tires to benefit from my new beam I'm going to have to change tires.
They need to be small enough not to rub, but not too small to be comfortable. I have 5.5 inch porsche 2.0 replicas.
Thing is I just don't know what to go for...
Toyo 135/80 R15 or 145/65 R15
I like the skinny look and stretch of the 135s but I'm a little worried about the handling in the wet especially as this will be my daily driver! I don't really like the idea of the 145/65 R15s because they are too low profile.
Any ideas?
Your Donkey has a large head. I like your donkey.
Is it wrong to be jealous of their facial hair abilities?
luckystiff
luckystiff is offline
PostPosted: Sat Jan 08, 2011 1:14 pm    Post subject: Reply with quote
165/60/15 if you can get them in your area. otherwise it depends a bit on the car. 145/65/15s work pretty well on link pin based cars. not as much on ball joint. the 165/60/15 works great on either. so does the 175/55/15.
so two things to think about are if the car is link pin or ball joint based. and i like to know what rear tire size being run is to help create a good match.
but i believe the 165/60/15 is a euro market tire and if so should be available to you. it's actually a tiny bit smaller in overall diameter than the 135r15 and has a better footprint for more traction...ken....
ITMC
Secret Service
iaccy
iaccy is offline
PostPosted: Tue Mar 15, 2011 6:59 pm    Post subject: Reply with quote
when people refer to their tires as "145s" is there a certain sidewall dimension that everyone gets? I see a lot of people labeling their tires as 145s...that doesn't help when shopping for the right tire dimensions.
'67 Beetle (sold) http://www.thesamba.com/vw/forum/viewtopic.php?p=3289202#3289202
OG '63 Beetle http://www.thesamba.com/vw/forum/viewtopic.php?t=444566
luckystiff
PostPosted: Tue Mar 15, 2011 9:43 pm    Post subject: Reply with quote
usually when people speak of "145s" they are talking about 145R15 which relates most closely to 145/80/15. the aspect ratio is actually closest to like a 145/82/15 but you won't find it denoted like that so most round to 80....ken....
ITMC
Secret Service
VOLKSWAGNUT
Fastest VW Belt Changer
Location: Flippin' a Belt........ .... Off-n-On ... NC USA
VOLKSWAGNUT is offline
PostPosted: Wed Mar 16, 2011 10:46 am    Post subject: Reply with quote
You can use the 80 for aspect ratio on 125, 135, 145, 155, 165 tires To get you close for specs and comparison here: http://www.discounttire.com/dtcs/infoTireMath.dos
aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited
Notablecarrot3
PostPosted: Wed Mar 16, 2011 10:50 am    Post subject: Reply with quote
To sort of close this discussion, I went for 135/80r15s purely because I didn't expect to drive my car so low and so I thought a smaller sidewall would look terrible.
Anyway, so I'm driving quite low with the 135/80r15 and they rub the top of the wings over big bumps at speed and they rub the left headlight bowl on full lock right very lightly.
They look great though but the handling is dreadful in the wet! The ride is every bit as good as with 145/80r15.
Erik G
Erik G is offline
PostPosted: Wed Mar 16, 2011 12:17 pm    Post subject: Reply with quote
correct on the 82 series. + rep points for lucky
the 145/65's are bad ass. small and good grip
iaccy
iaccy is offline
PostPosted: Wed Mar 16, 2011 3:58 pm    Post subject: Reply with quote
alright thanks for the tips....I'm looking for somewhat of a low profile tire for the front end of a '63 beetle. I will be daily driving it and I was thinking about 145/80-15 but since the contact path is so narrow I might want something a little wider to handle the wet weather conditions. I have 155/60 on my other car, and they are pretty narrow too. Is there anything you suggest?
luckystiff
PostPosted: Wed Mar 16, 2011 4:56 pm    Post subject: Reply with quote
my first choice now that they are readily available is the 165/60/15. VERY close in overall diameter to the 135r15 but with a better footprint. they became readily available about 2 weeks after i bought my last set of 145/65/15s Sad and the real bitch is i asked the guy at tire rack if they were getting them. first he told me there was no such tire(even though i told him i'd gladly send him a link to them) then told me if they did it'd be months before they got them. 10 days later they listed them as IN STOCK Rolling Eyes gotta love a slack ass salesperson....ken....
ITMC
Secret Service
luckystiff
PostPosted: Wed Mar 16, 2011 5:01 pm    Post subject: Reply with quote
what PSI are you running in them? most people who complain about how bad they are have them way OVER inflated. 20PSI is a good starting point. i've ran fronts as low as 18psi and as high as 24-25psi.
if yours are inflated to 35-40psi like most shops inflate them to THAT is part of your problem. read vw recommened tire pressures. it's in the range of 20-24psi front and 24-28psi rear.
135r15s aren't "grippers" for sure but over inflated makes them MUCH worse than they actually are...ken....
ITMC
Secret Service
Reply to topic    Forum Index -> Custom Wheel/Tire All times are Mountain Standard Time/Pacific Daylight Savings Time
