69mm crank vs 74 mm crank.
cmiller95
cmiller95 is offline
PostPosted: Wed Jul 27, 2011 1:43 pm    Post subject: 69mm crank vs 74 mm crank. Reply with quote
My sand rail's engine is 40 years old and has never been rebuilt. I plan on rebuilding it soon and was wondering if it would be worth my time to use a 74mm crank instead of a 69mm. Reasoning for a 74mm crank, its not a huge amount of gain, i don't have to do any clearancing on the case, and its costs just as much as a new 69mm crank (cb performance). I understand ill have to put more spacers between the head and the cylinder. But, if i have more spacer will i have to get longer push rods? And, Will there be a very big difference at all. Will i be able to feel the difference? I understand its only a 5mm stroke gain.
thanks, Colton
Swing axle: Eating tires since 1938
My Rail Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=427627
My Baja Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=466974
jsturtlebuggy
jsturtlebuggy is offline
PostPosted: Wed Jul 27, 2011 1:57 pm    Post subject: Reply with quote
More than likely you will have to do some case clearancing even with a 74mm crank. Inside case webbing has changed over the years so sometime even using a stock 69mm crank needs the case clearance.
You will have do some clearancing on the pistons to clear the crank and rod when it at the bottom of it stroke.
Depending on camshaft you may have to clearance center bearing surface and thrust surface of camshaft.
You will notice a difference in power. There will be more torque.
With so much available now then in the early years going to a 78 or 82mm stroke can cost you less in time and labor then it use to be.
What cylinder heads do you plan on using?
Joseph
Fair Oaks/Orangevale, CA
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960
krusher
krusher is offline
PostPosted: Wed Jul 27, 2011 2:06 pm    Post subject: Reply with quote
all your answers are probably in these old threads
http://www.thesamba.com/vw/forum/search.php?search..._chars=200
(06:31:07) RoachGhia: "i drink dick way too fast"
smitty24
smitty24 is offline
PostPosted: Wed Jul 27, 2011 2:41 pm    Post subject: Reply with quote
yep, I still had machining and some hand clearance work to make mine fit. Go 78-82 and call it good.
Wayne26
Wayne26 is offline
PostPosted: Wed Jul 27, 2011 3:29 pm    Post subject: Reply with quote
I just did one going from 69mm to 74, noticed a big difference in the low and mid rpm's.
the only thing that needed clearanced for me was the piston skirts because I went with the shorter 5.325 race rods. it ended up being easy, even though I was scared. but it turned out fine and runs great. http://www.thesamba.com/vw/forum/viewtopic.php?t=472324&highlight=clearanced+piston
my case was clearanced for a counterweighted crank in the past though.
[email protected]
john@aircooled.net is offline
PostPosted: Wed Jul 27, 2011 3:31 pm    Post subject: Reply with quote
if you go with a bigger bore the 74/76 and 5.325" rods works great. If you use 85.5s the skirts need extensive clearancing, which can be a pain.
It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net
jbbugs
jbbugs is offline
PostPosted: Thu Jul 28, 2011 5:34 am    Post subject: Reply with quote
http://www.thesamba.com/vw/classifieds/detail.php?id=1053124
These might be of some help.
Drag bus! http://www.youtube.com/watch?v=s2MOVmKdhX4
69 OG paint Transporter
73' Super Beetle Champcar Endurance Roadracer
Patina my ass, that's a Rust Bucket!
fivelugshortaxle
fivelugshortaxle is offline
PostPosted: Mon Aug 01, 2011 6:38 pm    Post subject: Reply with quote
Will the skirts on 94's need clearancing with a 74 mm crankshaft?
ralf
ralf is offline
PostPosted: Mon Aug 01, 2011 6:56 pm    Post subject: Reply with quote
i think he said. if u go with a bigger bore.. its fine
Flow Through a Curved Conduit
porting my SP head for my brother's project
https://youtu.be/OS_mVjQuqgk
fivelugshortaxle
PostPosted: Mon Aug 01, 2011 7:03 pm    Post subject: Reply with quote
oops.....so he did....gotta polish up on my reading skills Razz
ralf
ralf is offline
PostPosted: Mon Aug 01, 2011 7:21 pm    Post subject: Reply with quote
reading skills comes later..
just do a build thread now will you Smile
wonder wat u finally decided on !
Very Happy
DarthWeber
DarthWeber is offline
PostPosted: Mon Aug 01, 2011 7:45 pm    Post subject: Reply with quote
Come on Ralphee, read!! Laughing
From the Non-stroker motors thread:
I've learned that quite a bit of what I hear on this forum is not worth the time it took to read.....STROKER....gotta build a STROKER.....Lol! .....whatever......1915cc is the way I'm going and I'll be paying special attention to matching everything up with my combo....that's right....it's in the combo..........1915cc....ported 40x35 heads with dual springs....match ported manifolds with Weber 44's...Engle 120 with 1.25 rockers...chromoly pushrods.....balanced rotating assembly and pistons......1 and a half inch merged header with single phat boy muffler to keep good back pressure for the bottom end....Bosch 019 distributor and yes it will have an electronic ignition conversion..(points and condenser will be in the glove box just in case) 12.lb flywheel balanced with the crank and a Kennedy sage 1 pressure plate with stock disc to keep it smooth and not harsh....
Mitey62 wrote:
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on.
RockCrusher wrote:
JB weld the case halves....that'll keep the fretting to a minimum. Laughing
ralf
ralf is offline
PostPosted: Mon Aug 01, 2011 8:38 pm    Post subject: Reply with quote
ralpheeee ? wrong spelling darthy beibery hahaha
Smile yes saw that thread
but also he wonders of a 74 stroke a 78 an 82 i think and alot Smile
saw ur sad face on the 1807 build bfor.. i guess i should do that LOL to make u smile? hahahaha
fivelugshortaxle
PostPosted: Tue Aug 02, 2011 2:32 am    Post subject: Reply with quote
yes......I'm guilty of waffling........think I should have bought motor parts first instead of the beam, wiring harness, body work...blah blah blah.....too many choices for the motor.....cash for moor partrs will be availale next week so we'll see...gonna be a crap shoot...
fivelugshortaxle
PostPosted: Tue Aug 02, 2011 2:35 am    Post subject: Reply with quote
justreally like the old school stuff.......not set in stones but it's probably oing to be a 2054 cc motor......if I remember correcty the 74 crank was one of the first "stroked" hi po motors...reground stock stroke crank....give me about 100 grand and I'll build one of each
AlteWagen
Troll
AlteWagen is offline
PostPosted: Tue Aug 02, 2011 2:03 pm    Post subject: Reply with quote
If you use the Mahle FORGED 85.5 pistons you do not need to clearance the skirt. Any big bore Mahle (90.5, 92, 94) already have the short skirt design.
I love my mini stroker but would put 90.5s if I were to do it again.
fivelugshortaxle
PostPosted: Tue Aug 02, 2011 2:26 pm    Post subject: Reply with quote
And what about the AA pistons?
ralf
ralf is offline
PostPosted: Tue Aug 02, 2011 3:13 pm    Post subject: Reply with quote
as stated by derluft ,
the forged 85.5s have shorter skirts = clearancing not needed
which was already answered by a dashing fellow by the name of John Connoly
90.5s up has shorter skirts, and the B stroke pistons are even shorter..
but the problem with the cast 85.5mm isnt the skirt being long.. its the bore being small so it hits the cheeks of the crank
ever wonder why90.5 A pistons dont hit the crank like a small bore?
the dashing fellow by the name of john connoly also did answer this a few postststs back
HTH
fivelugshortaxle
PostPosted: Tue Aug 02, 2011 6:22 pm    Post subject: Reply with quote
HTH
So.....74 x 94 2054cc won't have piston clearancing problems?......I think that's what I got out of it....soryy, but I'm quite ignorant when it comes to anything other than stock 69mm stroke motors......
which motor, in your opinion, would be easier to build? 74 x94 or 78 x 94 or 82 x 94?
ralf
ralf is offline
PostPosted: Tue Aug 02, 2011 6:25 pm    Post subject: Reply with quote
74x94 on B pin height
use 5.5 rods
and ud have about 0.060" deck.. u can turn the barrels on a lathe
to get ur desired deck.. or turn the barrels enough that it would let u use a 0.040" copper headgasket
call it a day..
74x90.5 works too..
ofcourse like most would say. it would make sense to run
78.4-82 strokes its easier..
example
78.4 stroke and using 5.5 rods on B pin height pistons,
ud need maybe 0.050" to 0.060" shims to get to ideal deckheight
so getting a set of copperhead gaskets of that thickness.. would let u have ur deck nice..
ofcourse mocking it up will have the final say on where ur stuff fals.. as far as deckheights go
