candyflame73 Samba Member
Joined: September 03, 2005 Posts: 440 Location: Texas
Posted: Mon Mar 05, 2012 2:19 pm Post subject: Steel Pushrod Question |
Quick push rod question to double check. Was doing some reading using the search feature and came across some talk about chromoly pushrods and it was suggested to check the pushrods with a magnet. Next valve adjustment I checked mine with a telescoping magnetic pickup and to my suprise it does stick to all pushrods. Now I do not know if they are chromoly or simply steel. Would the rule simply be if the magnet sticks then adjust to a "loose zero" whether or not you know if they are specifically chromoly steel? |
It's a play thing Samba Member
Joined: November 19, 2009 Posts: 575 Location: Stagecoach, Nevada
Posted: Mon Mar 05, 2012 2:25 pm Post subject: |
If a magnet sticks to the pushrod use loose zero lash. must likely you have chromoly push rods, are they black in color ? _________________ It's not the size of your shop, it's what comes out of it that counts.
I've been playing with my thing ever since I got it... |
Posted: Mon Mar 05, 2012 2:31 pm Post subject: |
Thanks for the help.....I'm pretty sure they are black. |
kingkarmann Samba Member
Posted: Tue Mar 06, 2012 11:17 am Post subject: |
For the sake of clarity, the ends of all pushrods are Steel. Make sure to test the pushrod Shafts. It may seem obvious but you never know  |
mark tucker Samba Member
Joined: April 08, 2009 Posts: 23950 Location: SHALIMAR ,FLORIDA
Posted: Tue Mar 06, 2012 1:07 pm Post subject: |
kingkarmann wrote: |
gladd you added that,I dont use loose zero, is loose zero a .0005,.001? I use a snug no play zero.up to a minus lash when cold.and the color of the pushrod dont tell you squat,I have silver chromoly,black chromoly,silver aluminum,black steel(some awassom empi steel ones that have the ends ground to a point new in the package like that, there sweet. |
Posted: Tue Mar 06, 2012 5:13 pm Post subject: |
Great points guys! I did check the shafts with a magnet and it did in fact stick to the shafts.......that just doesnt sound right Thanks again for the help on this |
modok Samba Member
Joined: October 30, 2009 Posts: 27581 Location: Colorado Springs
Posted: Tue Mar 06, 2012 7:04 pm Post subject: |
chrome-moly is a type of steel, they are the same as far as your lash is concerned |
Posted: Tue Mar 06, 2012 8:46 pm Post subject: |
aloy of steel.I like the cr with the morealuminum in it,it tends to harden better when nitriding.& beter carratoristics (yup I cant spell that one at this moment by my self, tired&late) |
Cptn. Calzone Samba Member
Joined: June 27, 2007 Posts: 1872 Location: S>E>Alabama
Posted: Tue Mar 06, 2012 8:56 pm Post subject: pushrods |
characteristics is the word we are looking for. But youse gotta be a character to really appreciate those empi pushrods, they can double as arrows being so pointy. _________________ 71 westfalia
67 912 Porsche Quintilla
67 Single Cab aka my work horse |
notorious KGB Samba Member
Joined: April 17, 2011 Posts: 26 Location: southern OREGON
Posted: Thu Mar 15, 2012 11:53 pm Post subject: |
SO all you Chromoly Dudes are saying that the valve lash for an engine with chromoly pushrods will need to be set for lets say .002 or less?
I have these pushrods and I ran across some information about this from CB. I just gave birth to a 1776 and I noticed that the valves which were originally set to .006 were tight like .001 after I broke in the cam. I readjusted them to .006. I have only ran this baby for short trips.
I guess to how I understanded it, the pushrods will grow with the cylinders as the engine reaches operating temp. What about the possibilities of burning valves during sometime. Please someone convince me its going to be OK. |
KopfenJager Samba Member
Posted: Fri Mar 16, 2012 1:04 am Post subject: |
giving birth to a 1776! Your a trooper! |
