lupian20 Samba Member
Posted: Thu Dec 13, 2012 6:56 pm Post subject: Headlights were working fine but now no more headlights |
I am a new bus owner and I did not have any problems before but now the headlights of my bus don't work. I am new to working on cars and I think this might be easy issue to fix but the headlights on the bus were working fine but one day after work and when I was ready to go home the headlights did not turn on. I can see that everything else worked (blinkers, break lights, and the little lights that go around) but no headlights. I know the first thing to do is to check the fuses, so I did and everything is ok. Now the next step??? what would it be? replace the headlight switch, relay, or even the headlights. But is there any way I can check what the problem is before I start changing all this staff. If there are any threads that have this please let me know. any troubleshooting advise? Thanks
1972 VW Bus |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53231 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Dec 13, 2012 7:07 pm Post subject: |
Welcome,
The place to start is by turning the ignition key back and forth slightly/slowly in the run position while watching for the headlights, I suspect your ignition switch is worn out. The next step is find the black/yellow wire that goes to the headlight switch from the ignition switch (it also powers the wipers but through the fuse box), if it's dead (key on) the ignition switch is toast, if it has power start tracing past the headlight switch, maybe the relay has failed (very unlikely neither high or low beam work).
This may help too: http://www.thesamba.com/vw/archives/info/wiring/bus_8_71_1700.jpg _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Dec 13, 2012 7:14 pm Post subject: |
| thanks for welcoming. let me go try that right now. but Im sorry I very new to all of this, how would I know if the black/yellow wire is dead? |
CoastalAirCooledVW Samba Member
Joined: September 02, 2012 Posts: 1882 Location: Mckinleyville, CA (Humboldt County)
Posted: Thu Dec 13, 2012 7:54 pm Post subject: |
Get yourself a test light or a volt meter. I prefer the test light for this sort of thing but it is up to you. If you do not have a Bentley manual I would (and so will everyone else) recommend that you buy one. The new ones have color wiring diagrams and are about $40 on amazon.com. Here is my thread on electrical issues involving headlights that has some useful information http://www.thesamba.com/vw/forum/viewtopic.php?t=532837&highlight=
Also go to the top of the forum and use the "search". Many people have had this problem before. Enjoy your bus and post a picture or two  _________________ 1966 Velvet Green Standard |
Bala Samba Member
Joined: December 04, 2003 Posts: 2637 Location: Austin, TX
Posted: Fri Dec 14, 2012 9:25 am Post subject: |
You didn't really say, do your high beams work?
If so, I'd say it's the relay.
Welcome to the world of busses! A little patience and you'll figure it out.  _________________ 1976 Westy
1966 Beetle |
aeromech Samba Member
Joined: January 24, 2006 Posts: 17774 Location: San Diego, California
Posted: Fri Dec 14, 2012 12:58 pm Post subject: |
Once you have the tester you just poke the sharp end through the wire insulation to get to the conductor. Make sure the other end of you tester is grounded. You might try practicing on a known good wire first. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Fri Dec 14, 2012 5:19 pm Post subject: |
Yea i bought the tester and i think there is no power coming to the headlights. I think i did it right. I pocked the 3 cables (white, yellow, and red) and there was no power. What would be the next step. How can i check what wrong now the headlight switch or relay.
Neither the high or low beams work.
I do have the bentley.
Where would the dimmer delay be?
Thanks everyone for your responses[/img] |
Posted: Fri Dec 14, 2012 5:25 pm Post subject: |
I believe your problem is your ignition switch like bus daddy said. Have you tried wiggling the key while the headlights are on. That's with the key turned on of course _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Fri Dec 14, 2012 6:00 pm Post subject: |
The dimmer relay is a big box attached to the bottom of your fuse box. To get to it you have to pull the fuse box up and out. Disconnect the battery before you do this because you will be dealing with a lot of wires. _________________ 1966 Velvet Green Standard |
Posted: Fri Dec 14, 2012 6:23 pm Post subject: |
| Yea i tried wiggling the key with headlight switch on and nothing happened |
Posted: Fri Dec 14, 2012 7:30 pm Post subject: |
| lupian20 wrote: |
| I used the tester on the yellow and black cable that comes to the headlight switch and with the key on and there is power in that place. What would that mean? |
That means the next wire to probe is #56 (white/black) coming from the headlight switch to the relay under the fuse box. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Dec 14, 2012 7:31 pm Post subject: |
Busdaddy? Oops, you beat me to it _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Fri Dec 14, 2012 8:46 pm Post subject: |
| ok i checked black/white and that one does not give me a light in the tester. so that a bad relay?[/quote] |
Posted: Fri Dec 14, 2012 9:59 pm Post subject: |
That indicates a bad switch or something disconnected/not making good contact. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3631 Location: San Diego (Encinitas)
Posted: Sat Dec 15, 2012 1:46 pm Post subject: |
For reference:
_________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
Posted: Sat Dec 15, 2012 8:33 pm Post subject: |
Good to hear it _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Ramonalejandro Samba Member
Joined: March 08, 2013 Posts: 1 Location: PUERTO RICO
Posted: Fri Mar 08, 2013 12:52 pm Post subject: headlights |
| Hi, I'm having the same problem with mine. I already tested for power from the black/white cable from the switch to the relay and it is ok but the yellow calble coming out of the relay doesn't have power. It's is the problenm on the relay? Because I got a new relay and it's not working. I jumped the black/white with the yellow and the lights work. May be I got a default relay? Thanks |
Posted: Fri Mar 08, 2013 1:32 pm Post subject: |
If you have power to 56 but none coming out of either 56a or 56b the relay is faulty, one or the other should have power when 56 is powered. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
