Brianfromutah Samba Member
Joined: May 30, 2012 Posts: 150 Location: Utah, Heber City
Posted: Sun Apr 14, 2013 2:05 pm Post subject: Subaru engine dies/searches for idle when coming to a stop |
So i've put about 1,000 miles on my van since i did the Small Car based 2.5 conversion. Wire harness and computer were both supplied by Small Car. It's a 2009 drive by wire system.
Here's my problem:
Occasionally when i release the clutch to either slow down or come to a stop the engine dies. Other times it comes close to dieing (revs just go way low) then it recovers and idles fine. Most of the time it idles down nicely and settles into a 7 or 800 rpm idle (im not sure how accurate my Tach is) Also sometimes it seems to search a bit before it settles into an idle.
My first inclination would be to check/ clean the idle air control valve, but now i'm not sure it has one since the throttle is controlled by an electric motor...
Any thoughts? The engine runs great other than this little issue. _________________ '89 Westy Syncro w/ '09 Subaru 2.5 |
Mick Ord Samba Member
Joined: April 26, 2008 Posts: 203 Location: Vancouver, BC
Posted: Sun Apr 14, 2013 2:31 pm Post subject: |
I had exact same problem with mine...turned out is was a faulty speed sensor _________________ 1991 Syncro Westy- 2.5 Suby
1989 Syncro Tristar ( sold)
1988 2wd Tristar- about to start resto/rebuild !! |
dobryan Samba Member
Joined: March 24, 2006 Posts: 17158 Location: Brookeville, MD
Posted: Sun Apr 14, 2013 4:06 pm Post subject: |
thanks guys i will look into it. Also, i haven't checked for codes yet, did your issue throw a code? _________________ '89 Westy Syncro w/ '09 Subaru 2.5 |
Crankey Samba Member
Posted: Sun Apr 14, 2013 6:54 pm Post subject: |
I have a similar thing happen with my 3.0 + aftermarket ECU
I replaced the fuel pump relay, and the fuel pump is only a few months old
now I am looking at this info from Link who made the ECU
Quote: |
When the throttle is abruptly closed the engine generates more vacuum than under normal conditions (such as idle and light cruising). This condition is known as overrun. During overrun the ECU performs a fuel cut by switching off all injectors. This helps minimize the possibility of backfires occurring and reduces fuel consumption and emissions.
In Link ECUs, the fuel cut is only triggered if the engine RPM exceeds that specified by the user for the current engine temperature in the 'Fuel Cut Activation RPM Table'.
The activation RPM must be set above the engine's idle speed so that fuel is not cut when the engine is sitting at idle with the throttle closed. In practice the activation RPM should be set around 500rpm above idle so that as the engine speed falls during overrun the fuel is turned back on early enough to stop the engine from stalling. A typical Activation RPM for a fully warm engine (80-100 degrees C) is 1500 RPM.
When the engine is cold the idle speed control system will typically be setup to raise the idle speed. As a result, it is necessary to raise the activation RPM at lower engine temperatures. Even if the idle speed is not increased during cold running it is still advisable to use larger activation RPM numbers at lower engine temperatures. This is because cold engines generally do not tolerate the use of a fuel cut especially at low RPM.
Note: This function may only be used if a throttle position sensor (TPS) is fitted and correctly set up. |
http://www.linkecu.com/link-help-centre/glossary/over-run-def
not sure if I want to dig into the ECU programing myself, but this info could be a clue to my issue. it was also suggested that my crank position sensor could be over heating...from a random PepBoys counter guy...
defiantly seems to happen when the clutch is out and I'm slowing to a stop of about to downshift for slower traffic ahead. the engine is so quiet I don't notice it till it's already happened. but one time it seemed to be near dying and I revved it and it it came back.
I have no tach yet and no speed sensor. I was about to buy the RMW speed sensor kit and they told me I didn't really need it cause the TPS should provide that info/signal to the ECU.
after it dies and I roll off to the side, it takes about 5-10 minuets before it'll start again. but I think during that time when I turn the key I don't hear the FP werrrr just before I turn the key to turn on the starter motor.
I'd really like to get this issue nailed down. it's annoying ! I have alot of hills on my commute that don't require the accelerator pedal and I just roll down them...the throttle body is shut and that's often when it seems most likely to happen.
Brian, I don't mean to jack your thread, my situation is probably apples and oranges to yours...but maybe not. hope you don't mind. |
Posted: Sun Apr 14, 2013 8:46 pm Post subject: |
No worries.
What year is your 3.0? your not starting for 5-10 minutes is probably key in diagnosing your issue. Use that 5-10 minutes to check for spark, fuel, etc... also check and see if you have any codes.
Speed sensor seems to be a logical culprit for my problems, but i think you've got something else going on... _________________ '89 Westy Syncro w/ '09 Subaru 2.5 |
Posted: Sun Apr 14, 2013 9:06 pm Post subject: |
My problem was exactly as you first described, slowing down, clutch down engine would either die or "hunt" at very low rpm ( nearly die). Engine would restart first turn of key- every time, or if still rolling by dropping clutch- then no further problems for a day, a week- very intermittent.
A check of the speed sensor ( vanaru model that fits behind speedo) revealed no signal, new sensor and no further issues...simple as that  _________________ 1991 Syncro Westy- 2.5 Suby
Posted: Sun Apr 14, 2013 9:41 pm Post subject: |
Brianfromutah wrote: |
No worries.
Speed sensor seems to be a logical culprit for my problems, but i think you've got something else going on... |
I thought it was an 06 but found a wire bundle with a blue tape label that said 05. but it's a JDM EZ30r with the black plastic manifold, 6 exhaust ports and variable valve timing and lift I think.
codes...heh, I do have a thing to read codes and stuff but haven't taken time to wire it in yet. I need to run a heavy protective conduit to protect the 3-4 $50ea. can-bus cables to the dash pod.
honestly I'm not smart enough to check for anything but how many people I'm pissing off in traffic when this happens.
once I get my display installed I can data log for 30 minuets of driving, that should help. or at least help a mechanic/tuner guy help me. |
Posted: Tue May 07, 2013 7:19 pm Post subject: |
I have another question about the speed sensor fix... Does it always throw a check engine code? I had mine checked at autozone today. It had a bunch about the evap system, fuel level, neutral switch, but no speed sensor codes. I wonder if i have a different problem? _________________ '89 Westy Syncro w/ '09 Subaru 2.5 |
david2676 Samba Member
Joined: September 06, 2008 Posts: 452 Location: san jose, ca
Posted: Sun Mar 27, 2016 12:59 pm Post subject: Re: Subaru engine dies/searches for idle when coming to a stop |
How do you check to see if you have a good speed sensor .. I am using the Gowesty Speed sensor with my Subie conversion and having problems at allow idle. I am going to recheck the wiring to see if maybe I have a bad connection. I am not sure who to verify if the speed sensor it working..
I am not sure this would really be the issue since my engine is hunting for idle even at start up. _________________ 64 bug
91 Vanagon/ Subaru swap Westfalia |
Forthwithtx Samba Member
Joined: July 14, 2014 Posts: 717 Location: Fort Worth
Posted: Sun Mar 27, 2016 1:40 pm Post subject: Re: Subaru engine dies/searches for idle when coming to a stop |
I have the same issue. Usually after warmup. Push in the clutch, coming down from speed, and red dash lights come on. Stall. If I push in the clutch and keep my foot lightly on the gas pedal, even briefly, I can keep it from stalling, but it's a tricky operation.
I have the GW VSS installed. I'm thinking about using another means for the VSS, like the bracket and sensor near the CV bolts. _________________ Cheers!
-Karl
'84 GL with 2001/2004 Subaru 2.5L |
davevickery Samba Member
Joined: July 16, 2005 Posts: 2887 Location: Fort Collins, CO
Posted: Sun Mar 27, 2016 4:05 pm Post subject: Re: Subaru engine dies/searches for idle when coming to a stop |
david2676 wrote: |
I am not sure this would really be the issue since my engine is hunting for idle even at start up. |
You should have some sort of OBDII reader. I use the Torque App on an android tablet. It is fun even when you don't have any issues, but great for seeing whatever the computer is.
If it is not the speed sensor, does your year have an adjustable throttle position sensor on the left side of the intake. Messing around with that affects idle. You could also try adjusting the throttle stop. |
msewalson Samba Member
Joined: September 14, 2009 Posts: 544 Location: Grand Junction, Colorado
Posted: Sun Mar 27, 2016 5:18 pm Post subject: Re: Subaru engine dies/searches for idle when coming to a stop |
I had the same issue and it was related to neutral position switch. I believe I had to ground one of the wires. My engine is 98 EJ 22 and the donor had an automatic transmission.
Matt _________________ 87 Syncro w/EJ22 |
kbeefy Samba Member
Joined: March 10, 2006 Posts: 600 Location: Central Oregon
Posted: Sun Mar 27, 2016 7:37 pm Post subject: Re: Subaru engine dies/searches for idle when coming to a stop |
I had this exact issue (08 2.5 DBW) that didn't have a VSS. Installing a VSS cured the problem.
I also use Torque, really easy way to check your VSS output if you don't have a real scanner.
Also, my van would loose power (cut to idle) if the throttle didn't move for 5 minutes. Lifting and pressing on the pedal would clear it. VSS instalation also fixed that issue. I could replicate it parked in neutral with a stick on the accelerator to keep it above idle for 5 minutes, helped with troubleshooting. _________________ 86 syncro CHC, NorthWesty subbie 2.5, decoupler, locker, custom interior, 225/75r16 Duratrack's on CLK's, Toyo cabin heater, ARB fridge, 300w Zamp Solar, Gowesty bumpers/skid/rails, Fiama awning
'86 Syncro Westy. Stock for now.
2000 F350 7.3 CC LB 11' Northland Cabover
2006 Subbie OBXT
2002 Tacoma DoubleCab 4x4
1969 Mustang Basket Case 351c/FMX/9
http://kbeefy.blogspot.com/ |
vanagonjon Samba Member
Posted: Mon Mar 28, 2016 4:40 am Post subject: Re: Subaru engine dies/searches for idle when coming to a stop |
I would use some throttle body cleaner if your throttle body is not completely gunk free. That can cause a poor idle/stall issue. |
Posted: Mon Mar 28, 2016 3:29 pm Post subject: Re: Subaru engine dies/searches for idle when coming to a stop |
turned out all it was needed was a adjust meant to the idea screw. I was told never to tough this it was set by the factory. This engine is not the same as the factory its a frankin motor.. so I guess it needed just a touch more idle stop. _________________ 64 bug
Posted: Thu Apr 07, 2016 10:18 am Post subject: Re: Subaru engine dies/searches for idle when coming to a stop |
I had this problem, as I mentioned previously. Cleaned my IAC solenoid, swapped it for another, cleaned the TB thoroughly, had VSS installed. No joy.
Last week, I installed a 130 amp alternator from a 2010+ Tribeca, and the problem is gone. I don't know if the two are connected. The previous alternator was showing 14+ volts, as is the latest one.
Go figure. _________________ Cheers!
-Karl
luVWagn Samba Member
Joined: February 21, 2008 Posts: 1342 Location: Snoqualmie (WA)
Posted: Wed Jan 09, 2019 2:50 pm Post subject: Re: Subaru engine dies/searches for idle when coming to a stop |
Forthwithtx wrote: |
Go figure. |
Forthwithtx - did your problem permanently go away with the alternator change, which is either getting more amperage to places that needed it, or which wiggled some wires to make things happy? Anything to report after another 2+ years? _________________ '91 Double Door Transporter |
