kkjellquist Samba Member
Joined: June 04, 2013 Posts: 752 Location: Asheville, NC
Posted: Fri Jan 24, 2014 10:39 am Post subject: Eastwood No-Weld Panel Repair Kit - Thoughts |
I need to do both lower rear quarter panels and the battery tray on my bus. I was just talking myself into a low priced flux core welding setup when I stumbled across this product;
http://www.eastwood.com/ew-no-weld-panel-repair-kit.html
I did a bunch of searching and there are threads on the other Eastwood repair kits but nothing on this.
Anyone done a decent size repair w/ this product or seen the results? _________________ 1977 Sage Green Deluxe Campmobile - "Turtel"
(1978 2L FI, Pertronix, Hydraulic Lifters)
Turtel - http://www.thesamba.com/vw/forum/viewtopic.php?t=561195
Pisgah Bus Rally - New Year's Day
http://pisgahbusrally.blogspot.com/ |
djway3474 Samba Member
Joined: August 19, 2011 Posts: 2585 Location: The Real NDK So Cal
Posted: Fri Jan 24, 2014 11:40 am Post subject: |
You are just asking for future problems with that type of repair. But weld in the panels if replacing center sections or the plugs to replace the spot welds if changing out an entire panel.
Don't go flux. Save and get the gas. I got a little eastwood 135 and started welding about 8 months ago. Once you find the setting for the metal it is easy as pie with the gas.
Lots of spot welds in interval spacing, keep the panels cool. It is not hard at all.
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2392 Location: DEEK - U.S.A.
Posted: Fri Jan 24, 2014 3:41 pm Post subject: |
djway3474 wrote: |
Don't go flux. Save and get the gas. |
X2 on both of the above!
I almost gave up welding when I was using flux-core . . . the gas makes all the difference in the world for me . . . that and my auto-dimming helmet! _________________ Jesucristo es mi SeƱor y Salvador! |
Joined: May 17, 2003 Posts: 4876 Location: Harmony, PA
Posted: Wed Jan 29, 2014 6:37 pm Post subject: |
Not sure about the Eastwood Kit, but Wurth, 3M, and Lord all make two part panel bonding adhesives that work well. Panel adhesive is great when heat will damage a repair, or you aren't able to get on the back side of a repaired panel's weld to rust proof it like in a rocker panel. The areas you mention are all accessible on both sides of the repair, so you could just as easily weld it. |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16800 Location: State College, PA
Posted: Wed Jan 29, 2014 7:28 pm Post subject: |
Lots of manufactures have been gluing on body panels for years - Its a very valid method. When we did the VW woodie - we did quite a bit of glue on panels. We used the Lord system and it aint cheap, but it works great. No panel warpage and no tack - wait, tack - wait , tack - wait.
Read the reviews and talk to a couple body shops - bet they all use similar systems for a lot of their work. _________________ D-Dubya Manx clone 1914. Ex wifes car.
Maxine 61 Cal-look bug - Ex-wifes car.
themetalsurgeon Samba Member
Posted: Sun Feb 02, 2014 11:29 am Post subject: |
What specific way/area have you found the panel bonding not to be beneficial? |
CanadianBug Samba Member
Joined: September 05, 2008 Posts: 222 Location: South Western Ontario
Posted: Sun Feb 02, 2014 4:10 pm Post subject: |
[email protected] wrote: |
Every panel adhesive rep will tell you that the modern adhesives will work better than welding on older cars.
A few collision guys will say the same thing.
I've used it quite a bit on newer cars without any issues. It's fantastic for replacing pick-up truck box sides.
But there is no way I'd use it on an older ride, except for maybe a roof skin.
Simply for the fact that I know for sure that welding the old car properly will yield excellent results, while panel bonding is an unknown, at least in my mind.
If anyone has done it and it's withstood a few years and some miles, I'd love to hear about it.
Mike _________________
skills@eurocarsplus wrote: |
bodywork isn't a fucking race. |
Posted: Mon Feb 03, 2014 8:29 pm Post subject: |
I have an Acura Integra I center punched one of the older wooden post guardrail sections with, and heaved up the lower radiator support. I straightened what I could, and glued on a new piece of sheet metal on top of the bulkhead for the rad to sit on with the Lord Fusor. I've been doing some rust repair work on other areas of the car, and it hasn't been driven for the last 5-6 years. I did the support repair in the late 90's, and the section had not separated, or rusted in the 6+ years it was driven in Pennsylvania Winters.
Yes, it is true that the design of 30+ year old VW's isn't the same as a modern car, and you may not have that exact 1/4 inch flange around the panel for easy bonding like on a modern car, but I don't see why that would make panel bonding be any lesser of a solution for metal repair. I have two Beetles that need heater channels. I plan on using panel bonding adhesive to close off the final areas of the front bulkhead/firewall to allow priming/painting of the repaired cavities for rustproofing. I will probably weld in the channels to duplicate the weld seams visible in the door openings, but could just as easily bond the remaining areas of the channel. I had also thought of fully welding in the channel, then remove the lower plate to finish the inside of the channel for rustproofing, and bond the painted/finished bottom plate back on for the ultimate in durability. |
Posted: Tue Feb 04, 2014 12:45 pm Post subject: |
Just a word of caution:
The last time I talked to the 3M rep at work he said 3M was still recommending NOT using panel adhesives only in structural repair areas.
This was July or August of 2012, so maybe things have changed... ?
Keep us updated on what you do. The more feedback the better.
