Licence plate light for Manx
langan
langan is offline
PostPosted: Sun Mar 09, 2014 8:32 am    Post subject: Licence plate light for Manx Reply with quote
The other day I posted for a wiper motor and was helped and bought it Thanks.
Now looking for a lincence plate light or cover. Back in the day my old Manx had a stock VW but I dont know the year. It was not the old little one and not the big flat one I think it was a 64 seemed just the rite size for the body.
Is there a correct old school one?
langan
langan is offline
PostPosted: Sun Mar 09, 2014 9:20 am    Post subject: Reply with quote
Guess I should add is my old Manx looked to be a dealer built car. All stock running gear 36hp stock seats with cut down tracks soft top lime green bolt on roll bar. Man I miss that car
Dale M.
Dale M. is offline
PostPosted: Sun Mar 09, 2014 9:55 am    Post subject: Reply with quote
Really "Old school"...
http://www.speedwaymotors.com/EMPI-9457-Chrome-License-Plate-Light-w-Bracket-Assembly,82851.html
Sexier... Cleaner, n ewer....
http://www.speedwaymotors.com/Billet-Aluminum-License-Plate-Holder-w-Light,2217.html
http://www.speedwaymotors.com/Lighted-Chrome-License-Plate-Frame,16718.html
I like one above best... (the chrome frame w/light)
Sexiest of all....
http://www.speedwaymotors.com/Stainless-License-Plate-Light,2248.html
Dale
langan
langan is offline
PostPosted: Sun Mar 09, 2014 10:06 am    Post subject: Reply with quote
Thanks-but looking for the correct stock vw light. Maybe a link to compairing all oil vw licince plate light covers?
nightmanx11
nightmanx11 is offline
PostPosted: Sun Mar 09, 2014 10:13 am    Post subject: Reply with quote
Anything built or made in the 60s or 70s would be period correct.
You could always use the search feature that is built into most internet sites, or even contact one of the VW graveyards to see what they have.
BL3Manx
BL3Manx is offline
PostPosted: Sun Mar 09, 2014 10:31 am    Post subject: Reply with quote
64-66 was the most common
http://www.thesamba.com/vw/forum/viewtopic.php?t=462802
langan
langan is offline
PostPosted: Sun Mar 09, 2014 10:40 am    Post subject: Reply with quote
Thanks guys 64-66 is what I will look for.
BL3Manx
BL3Manx is offline
PostPosted: Sun Mar 09, 2014 11:24 am    Post subject: Reply with quote
If that's what you get, replace the three mounting studs with longer ones which will reach through the fiberglass. I also use the studs for mounting my license plate mount and to secure the wiring harness above the engine.
langan
langan is offline
PostPosted: Sun Mar 09, 2014 11:38 am    Post subject: Reply with quote
Best forum
Any ideas were to get chrome ones and same year tail lights?
BL3Manx
BL3Manx is offline
PostPosted: Sun Mar 09, 2014 12:00 pm    Post subject: Reply with quote
Just find a good used pair of German Hella 62-67 tail lights. Have them chromed by a good plater. I'm sure there are several near you, on either side of the border.
http://www.electroshine.com/
Replace the studs on the tail lights with longer bolts. Here is a thread you need to read
http://www.thesamba.com/vw/forum/viewtopic.php?t=569035
langan
langan is offline
PostPosted: Sun Mar 09, 2014 7:19 pm    Post subject: Reply with quote
Great advice.
Any ideas were to get 5 3/5 headlight buckets?
BL3Manx
BL3Manx is offline
PostPosted: Sun Mar 09, 2014 7:44 pm    Post subject: Reply with quote
I always use old 7" Dietz buckets
This might be the best price on used tail lights right now. The chrome rings aren't very good. I'd make him an offer if I needed them. I usually pick up a couple good/cheap sets when I see them at Bugorama
http://www.thesamba.com/vw/classifieds/detail.php?id=1262610
If you want to make the tail lights much more visible
http://www.thesamba.com/vw/classifieds/detail.php?id=1267895
jsturtlebuggy
jsturtlebuggy is offline
PostPosted: Sun Mar 09, 2014 7:59 pm    Post subject: Reply with quote
I use Summit Racing Stainless Steel 6in off road lights housings.
6in lights are actually 5 3/4in in diameter. They are rubber mounted inside housing.
I became tired of replacing cheap chrome ones from rusting.
Some modifications need to be done. Cutting slots in rubber for pieces on back side of bulb that keep it from turning.
Drilling the bolts to run the wires through(if you already have lights you can use the bolts from them).
Joseph
Fair Oaks/Orangevale, CA
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960
langan
langan is offline
PostPosted: Sun Mar 09, 2014 8:27 pm    Post subject: Reply with quote
Those look great
jsturtlebuggy
PostPosted: Sun Mar 09, 2014 10:06 pm    Post subject: Reply with quote
Here are a few more pictures. The one picture show the differences in housing that came with my Meyers Manx kit and the stainless steel with rubber mount for bulb.
Joseph
Elrod Motorsports
langan
langan is offline
PostPosted: Mon Mar 10, 2014 7:15 am    Post subject: Reply with quote
I like the one to the right. Is that a 5 3/4" too? Were do I buy
jsturtlebuggy
PostPosted: Mon Mar 10, 2014 8:01 am    Post subject: Reply with quote
Yes the one on the right uses a 5 3/4in light.
To get them I had to buy a Meyers Manx Kick Out kit from Bruce and Winnie Meyers.
They are the cheap Chinese made ones that will rust right before your eyes.
Joseph
Elrod Motorsports
