Rod length and availability for a 74/76/78 x 90.5 bus engine
dryenko
dryenko is offline
PostPosted: Tue Sep 30, 2014 3:22 pm    Post subject: Rod length and availability for a 74/76/78 x 90.5 bus engine Reply with quote
Building a upgraded engine for a early bus, based on a1974 Super Beetle engine. Current ideas / specs for review :
90.5 B series TW pistons for a longer rod and less clearance issues.
74 /76 /78 new forged CW crank w/ VW journals. Displacement open.
New H beam rods with "reversed" bolts, for clearance. Probably CB's.
New 40/ 35 as cast heads with single high rev springs.
Mild cam for mid range torque with stock 1 : 1.1 ratio rockers [new]
Thinking Dual single throat carbs. OR ? Engine balanced ,CC'd etc , etc
Questions :
1. Is there a rod length available so as to have near stock deck height and engine width with one of the above stroke cranks?
2. Is a new bubble case already machined for the cyls the way to go, and which stud size [8 vs 10] should be used and why? I assume the new case means minimum clearance work is needed.
Comments and recommendations [cam, carbs,rod length, sources] please.
modok
modok is offline
PostPosted: Tue Sep 30, 2014 5:05 pm    Post subject: Reply with quote
Yes. The AA pistons are 35mm pin height, so 78 stroke is stock width with stock length rods.
A new case from CB seems like a good bet, tho all are a roll of the dice.
Clearance work?? mag cuts 2x easier than aluminum
luckystiff
luckystiff is offline
PostPosted: Tue Sep 30, 2014 6:57 pm    Post subject: Reply with quote
go with 92mm thickwall pistons/cylinders..............
i did a 76x92b(2021), 5.5" rods, web 163 in my square and am very happy.
ITMC
Secret Service
bugguy1967
bugguy1967 is offline
PostPosted: Tue Sep 30, 2014 7:15 pm    Post subject: Reply with quote
I believe the general consensus for rod lengths with each stroke to get close to stock length is:
74 crank - 5.3" if you can find it, or 5.325" with A height pistons
76 crank - 5.5" with B height pistons
78 crank - 5.395(Porsche lgth), 5.4", and sometimes 5.5". 5.4 might actually be a bit narrower. This is with B height pistons.
82 crank - 5.325, 5.359(Porsche lgth) with B pistons
dryenko
dryenko is offline
PostPosted: Tue Sep 30, 2014 7:50 pm    Post subject: slightly confused ...more questions.. Reply with quote
Thanks for the posts with answers.
If a 76 stroke and B CH pistons is correct with a 5.5 rod, how can a 5.5 rod also work with a 78 stroke and a B piston? Maybe with shims?
Doesn't a B piston need the shorter 5.4 rod to cope with the longer throw of the 78 crank?
Another question :
If a 78 stroke and 90.5 B piston is selected, what combustion chamber size
[ assuming near zero deck and a .050" copper head gasket ] will give close to a 8.5 : 1 CR? I am also assuming the spigot height on the block is at stock dimension from the crank centerline.
Is there a online chart that has this info, to get me close?
Any cam ideas for mid range torque ?
Thanks Again,
BC
[email protected]
john@aircooled.net is offline
PostPosted: Tue Sep 30, 2014 9:39 pm    Post subject: Re: slightly confused ...more questions.. Reply with quote
a 78 is only .040" higher than a 76 at TDC. I recommend 5.5" rods and B pistons for 76 and 78mm cranks. I recommend 5.4" rods and B pistons for 82mm cranks.
It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net
bugguy1967
PostPosted: Tue Sep 30, 2014 10:08 pm    Post subject: Reply with quote
I don't know of a chart. Take people's recommendations, and learn from the experience after you assemble. You CAN measure where things will end up if you have all of the parts' dimensions, but that may be hard to come by.
As for mid-range cams, there are a ton. Figure out how many CCs you're going to go with, then buy a cam. The bigger the engine, the bigger the cam you can get and still feel the same mid-range pulling power.
Oh, and for the 78 crank, I didn't mean to add "Porsche length" VW stock rods are 5.394", which is basically a 5.4" rod. 5.359" is Porsche.
mark tucker
mark tucker is offline
PostPosted: Wed Oct 01, 2014 3:12 pm    Post subject: Reply with quote
78 with 5.5 rods. or 82 with 5.4 or 5.5with .090 shim. or 76 with 5.5. but shim will depend on the assy.
c21darrel
c21darrel is offline
PostPosted: Wed Oct 01, 2014 3:22 pm    Post subject: Reply with quote
I used 5.4 rods w/ a demello 78 crank. After mock up, choose to trim the cylinders so i had zero deck. Added .040 copper spacers for deck height. Engle 120 cam and Tims stage 1 heads. 40 dellortos. I had a little extra machine work but it is very fun to drive (in a ghia). I plan to build a 2110 for my heavier DC.
GhiaBuild
1967 DC build
modok
modok is offline
PostPosted: Wed Oct 01, 2014 6:07 pm    Post subject: Reply with quote
The answers vary because nobody measures anything. Mahle pistons are a half mm shorter but who cares if you use AA.
35mm pin height is all you need to know.
although if your AA cylinders are 94 length you may think it is wider but it isn't. the first AA TW 92 are the longer style cylinder, but you won't know if your machinist decked the case according to usual procedure for 94 cylinders.
Not sure about the ones with smaller bottoms, I asked.........but I think the guy I asked used a ruler to measure Laughing
