SPI epoxy primer and filler question
67 Sunroof
67 Sunroof is offline
PostPosted: Mon Mar 09, 2015 11:32 am    Post subject: SPI epoxy primer and filler question Reply with quote
Whole car, doors, hood, decklid, etc was sprayed 2 months ago and is fully cured.
I "believe" I need to scotchbrite red the area to be filled and then use my filler. (Should I call it filler or bondo?)
Anyway, I went by my paint store today and he sold me Evercoat Rage Ultra body filler and said its great stuff.
Am I headed in the right direction?
Question
Stuart Maingot
Stuart Maingot is offline
PostPosted: Mon Mar 09, 2015 3:22 pm    Post subject: Reply with quote
I am familiar with 220 grade sandpaper to abrade epoxy for application of filler, build primer, seal coat etc after 24hrs plus cure time have elapsed.
so i would say you are on the right track but not certain of the abrasion of scotchbrite red for this purpose.
marklaken
marklaken is offline
PostPosted: Mon Mar 09, 2015 3:33 pm    Post subject: Reply with quote
You need to seriously scuff before using rage on cured epoxy primer. Scothbrite red pads won't do the trick.
Epoxy primer needs to be filler'd and topcoasted within a short window (2-5 days depending on epoxy brand). Once that window closes, you have to do a lot of prep work before you topcoat epoxy.
Putting filler on scuff sanded cured epoxy doesn't make much sense to me. I would sand to bare metal with 36 grit on a DA sander wherever you are going to apply filler, then apply filler, then sand the remaining cured epoxy with 220 followed by 320 before applying high build primer.
Re-read the manufacturers directions SPI has good info online. It iwll tell you what you need to do. If you are still unsure, contact them for more clarification.
Be careful - you really don't want to do this wrong or it will show up in your final paint job.
Wish List:
1967 Wesfalia SO-42 Parts Needed: Kitchenette, Cot Poles
'65 rear left beetle fender
15" Bus Wheels in fair condition
Mark Laken
Fort Collins, CO
marklaken
PostPosted: Mon Mar 09, 2015 3:56 pm    Post subject: Reply with quote
from SPI website prior to topcoating with your high build primer:
"This epoxy does not need to be sanded if it’s primed over within 7 days. Always prime over the epoxy within 7 days. After 7 days the epoxy should be sanded with 180 and re-coated with epoxy for best adhesion. "
Wish List:
Mark Laken
Fort Collins, CO
theKbStockpiler
theKbStockpiler is offline
PostPosted: Tue Mar 10, 2015 4:44 pm    Post subject: Reply with quote
If the filler goes directly on the metal ,there will be no anti-corrosion protection from the primer if it has it.
Unless you need to fill a huge dent ,why not use glazing putty with hardener? Confused
My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask.Smile
67 Sunroof
PostPosted: Tue Mar 10, 2015 9:36 pm    Post subject: Reply with quote
Correct, SPI forums say to da lightly with 180 grit to take the shine off but not to bare metal and the apply my filler.
Started on a rear fender today!!! Yeahhhhhh!! Finally the bodywork! Can't wait!
