ANY ideas on keeping my gas tank off my front end
kings31
kings31 is offline
PostPosted: Sat Feb 28, 2004 8:35 pm    Post subject: ANY ideas on keeping my gas tank off my front end Reply with quote
I would like to know if you have ideas on how to brace the front end on my buggy to keep my gas tank off my front end. i put a hole in it from it hitting my front end . Crying or Very sad
chris
62ragman
62ragman is offline
PostPosted: Sun Feb 29, 2004 12:29 am    Post subject: Reply with quote
What type of car do you have, is it a sand rail or baja bug? Maybe you have some pictures, for a better understanding of what it is you are looking for. Thanks, Randy
volksaddict
volksaddict is offline
PostPosted: Sun Feb 29, 2004 7:13 am    Post subject: Reply with quote
Bet it was fun when the gas sprayed up in your face Very Happy Guess you weren't smoking when it happened since you are still here to write about it!
kings31
kings31 is offline
PostPosted: Sun Feb 29, 2004 8:11 am    Post subject: Reply with quote
sorry i forgot to say it is a manx style buggy. i'm looking for some kind of support in the front . under the fiber glass body to lift the tank up.
thank you Razz
blueone
blueone is offline
PostPosted: Thu Jun 11, 2009 10:15 am    Post subject: Reply with quote
Any ideas? I have the same problem.
jspbtown
jspbtown is offline
PostPosted: Thu Jun 11, 2009 10:24 am    Post subject: Reply with quote
The original manxs had simple brackets that were bolted to the two body attachment points which are on top of the front beam. They attached to the front of the buggy near the tank.
You can see the two holes here:
You can just see them in this pic. They are silver and just beyond the lower u-joint. Sorry I don't have a better picture.
Dinubadave
Dinubadave is offline
PostPosted: Thu Jun 11, 2009 11:00 am    Post subject: Reply with quote
I installed a home made support, you can see it below:
donmac
donmac is offline
PostPosted: Thu Jun 11, 2009 11:05 am    Post subject: Reply with quote
I bent a "Z" shaped bracket out of flat bar. Bolted it to the two existing holes on top of the front beam and the underside of the body.
Don
67 Dune Buggy aka Shrek
74 Baja Junk Pile aka Wild Thing
BL3Manx
BL3Manx is offline
PostPosted: Thu Jun 11, 2009 12:50 pm    Post subject: Reply with quote
There are rubber squares that sandwich the bottom of the Z bracket which allow some movement between the suspension and the body, which are good to use.
The bolt that goes through the top of the Z bracket and the body, should also go through the tab that holds down the front of the tank.
blueone
blueone is offline
PostPosted: Thu Jun 11, 2009 11:18 pm    Post subject: Reply with quote
Very nice. Thanx for the quick responses I will try and fab something up this weekend.
Baja68
Baja68 is offline
PostPosted: Fri Jun 12, 2009 5:32 am    Post subject: Reply with quote
Just a thought when I bought my gas tank they had 2 sizes. I cant remember the exact gallons but I got the smaller one in fear of having the problem you are having with the larger one.
I think it was 13 galon what I got and 18 gallon for the bigger one some thing like that .
Goood luck
BL3Manx
BL3Manx is offline
PostPosted: Fri Jun 12, 2009 8:38 am    Post subject: Reply with quote
Original 58-67 tanks have the best chance of fitting under the hood.
c.davis419
c.davis419 is offline
PostPosted: Fri Jun 12, 2009 3:15 pm    Post subject: Reply with quote
61 to 67 tanks actually. 61 tanks don't have the hole in the top of the tank for the fuel sending unit, but are identical in every other way. 56-60 tanks are called the humpback tanks and won't fit at all.
1967 beetle
1974 Thing
