Rebuild Hardware Kit
KILLERWATT
KILLERWATT is offline
PostPosted: Thu Jul 07, 2016 1:07 pm    Post subject: Rebuild Hardware Kit Reply with quote
Is there another company that makes a complete hardware kit besides Empi? Using a tourque wrench and even after chasing threads I've stripped out nuts on a couple of builds.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Thu Jul 07, 2016 2:45 pm    Post subject: Re: Rebuild Hardware Kit Reply with quote
Ac.net has hardware kits.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
KILLERWATT
PostPosted: Thu Jul 07, 2016 2:51 pm    Post subject: Re: Rebuild Hardware Kit Reply with quote
Thanks Glenn!
jfats808
jfats808 is offline
PostPosted: Thu Jul 07, 2016 3:16 pm    Post subject: Re: Rebuild Hardware Kit Reply with quote
I've probably used 12 sets from empi in 10mm and 8mm. How the he'll did you strip them out? 15-18 lbs on the 8mm, 23 lbs on the 10mm. Center mains 24-28 lbs. Never once stripped a set out. Are u using g the right torque tables?
2276 IDA's 86C 11-1 DD
Rockstar Suzuki wrote:
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick
You can always learn something new, even from a fool.
Check your oil levels routinely!
KTPhil Premium Member
KTPhil is offline
PostPosted: Thu Jul 07, 2016 3:40 pm    Post subject: Re: Rebuild Hardware Kit Reply with quote
Muffler clamps are notoriously easy to break. Poor quality and the overstressing of the little 10mm nuts and bolts don't help. Make sure everything fits well before torqueing... no burrs or bent parts to have to force.
I use the smaller copper exhaust manifold nuts. Same caution applies-- make sure you aren't using nut torque to deform parts into fitting... file/bend flanges flat and square first.
Main and head nuts are special types and should not be overtorqued, despite the common temptation.
KILLERWATT
PostPosted: Thu Jul 07, 2016 7:12 pm    Post subject: Re: Rebuild Hardware Kit Reply with quote
Case and head nuts aren't the problem; it's the chrome 13mm head 8M nylock. Getting ready to do another engine and was wondering if there was an alternative.
modok
modok is offline
PostPosted: Thu Jul 07, 2016 7:57 pm    Post subject: Re: Rebuild Hardware Kit Reply with quote
Why use a locknut? It's an engine not a roof rack
I would recommend flanged nuts, which are far stronger, no washer needed.
https://www.belmetric.com/flat-bottom-flange-nut-c-3_48_59_1294/?zenid=7o5dk026uct80vqa0j5mqd16v1
jfats808
jfats808 is offline
PostPosted: Thu Jul 07, 2016 8:55 pm    Post subject: Re: Rebuild Hardware Kit Reply with quote
You can continue buying the empi kit and replace nylon locknuts with std 8.8 hex nuts found at most hardware stores or supply shops. Simple. Maybe someone will have an alternative kit available. But I tell you I have yet to see one stripped nylon locknut happen to me on those kits with std torque applied. I guess they can go either way. Chinese metal..
Brian71
Brian71 is offline
PostPosted: Fri Jul 08, 2016 7:28 am    Post subject: Re: Rebuild Hardware Kit Reply with quote
A little bit of anti-seize goes a long way in preventing galling.
esde
esde is offline
PostPosted: Fri Jul 08, 2016 11:58 am    Post subject: Re: Rebuild Hardware Kit Reply with quote
A few 100 count boxes of m8 and m10 nuts and bolts don't cost much and go a very long way. You quickly see that the hardware "kits" aren't really a deal.
Like Modok mentioned, flange nuts are great, and many places carry the small wrench size brass m8 for exhaust studs and such.
modok wrote:
modok
modok is offline
PostPosted: Fri Jul 08, 2016 4:25 pm    Post subject: Re: Rebuild Hardware Kit Reply with quote
Bell Metric also sells the thick 8mm washers for head studs, which can be used for other things too. You can get flanged nuts for 6 main the case studs.
Zundfolge1432 Premium Member
Zundfolge1432 is offline
PostPosted: Fri Jul 08, 2016 4:34 pm    Post subject: Re: Rebuild Hardware Kit Reply with quote
That's a good question what people never ask or think about is the drag or interference caused by a self locking fastener which will alter torque settings.. You don't need special fasteners you need to use green loctite on stock hardware. Oh I'm sorry that doesn't have a cool factor does it.
modok
modok is offline
PostPosted: Fri Jul 08, 2016 4:56 pm    Post subject: Re: Rebuild Hardware Kit Reply with quote
The purpose of a locknut is so that it cam be loose and not vibrate off entirely.
If your case bolts are loose, or fall off entirely, it makes no difference, both=fail. So what's the point? there is none. As far as the case is concerned loose is loose, and as far as oil and air leaks are concerned finger tight is not any different than it fell off. Locktite is also no needed, what would it do? nothing.
Now, for some things locknuts are good. For the one nut inside the case that holds the oil pickup, THAT is the right place for a locknut, because it would prevent the nut falling off and getting sucked into the oil pump should it become loose. It does have a high chance of coming loose too. Or, just use a bolt instead of a stud. For the engine mounts inside the bellhousing, good idea. Seatbelts should have locknuts/lockwashers, any single shear joint probably should have a locknut/lockwasher. The cooling tinshould have locknuts/lockwasehrs, ect. Right nut for the right job.
If you have any questions about hardware or the precise fitting of things in holes just ask this nut Wink
PostPosted: Fri Jul 08, 2016 6:25 pm    Post subject: Re: Rebuild Hardware Kit Reply with quote
Factory hardware always worked for me along with the green loctite. The drag created by self locking fasteners alters torque readings that's a fact.
modok
modok is offline
PostPosted: Fri Jul 08, 2016 7:09 pm    Post subject: Re: Rebuild Hardware Kit Reply with quote
the bright zinc plating is actually a larger factor, way more difference than the nylon drag.
New bright plated may have 25%less friction than bare steel at first, but after a few uses, it wears off and can be ignored.
If you use brand new bright plated locknuts on the rocker stud, and try 20 ft-lb, I bet it will strip out. The torque it takes to turn a locknut is very small. It's easy to test.....because you have a torque wrench
KILLERWATT
PostPosted: Sun Jul 10, 2016 4:42 pm    Post subject: Re: Rebuild Hardware Kit Reply with quote
KILLERWATT wrote:
Thanks Glenn!
The pic on aircooled.net is the same one I've seen for the Empi kit on other sites.
The flange nuts are a good idea. Thanks!
CSEBug
CSEBug is offline
PostPosted: Sun Jul 10, 2016 9:00 pm    Post subject: Re: Rebuild Hardware Kit Reply with quote
http://www.ebay.com/itm/VW-Beetle-Cylinder-Head-An...43c74acfa0
Also sells one for the 8mm.
Best one out there IMO, has the thick head + case washers
AlteWagen
Troll
AlteWagen is offline
PostPosted: Sun Jul 10, 2016 10:07 pm    Post subject: Re: Rebuild Hardware Kit Reply with quote
I agree. That is the kit sold by Century Distributors (wholesale), if you know someone who orders from them its worth every penny.
Official Dual Carb Thread
KILLERWATT
PostPosted: Tue Aug 30, 2016 4:23 pm    Post subject: Re: Rebuild Hardware Kit Reply with quote
Our local shop turned me on to this source. All hardware for the entire car including the engine.
