FL-Frank Samba Member
Joined: August 08, 2015 Posts: 823 Location: Jupiter, Florida
Posted: Fri Jul 29, 2016 7:08 pm Post subject: Brake Light Gremlin |
All tail, brake, and turn signal lights were operating correctly...until I brought the car in for left rear fender repair. The shop removed the left rear fender, left tail light housing, and bumper for body work and paint, and then reassembled everything. The fender looks great, however, here's what the rear lights are doing now...
With headlights off:
Brake pedal depressed...
Both right and left brake lights light at same brightness
With headlights on:
Left tail light is much brighter than right tail light
Right brake light lights to match brightness of left side
Brake pedal released...
Right side returns to just tail light but left side brake light remains lit
Turn signals operate normally on both sides, lights on and lights off.
I thought maybe they wired the left side incorrectly during reassembly, but I checked the connections and they are the same as the right side.
Any suggestions? |
j.goodspeed Samba Member
Posted: Fri Jul 29, 2016 8:36 pm Post subject: Re: Brake Light Gremlin |
Just a thought. swap the brake light and tail light wires on the left tail light assembly. Brake light filament is on when headlamps are on. The brake light filament is brighter and may have been swapped.
Otherwise, they may have jammed the tail / brake light bulb 180 degrees out. Causing the brake light to illuminate instead of the taillight and vice a versa. _________________ Jeremy Goodspeed
www.goodspeedmotoring.com
www.goodspeedmotoring.net |
flyboy161 Samba Member
Joined: December 26, 2009 Posts: 2137 Location: Perry, GA
Posted: Sat Jul 30, 2016 4:59 am Post subject: Re: Brake Light Gremlin |
The black and gray wires were reversed on the left side. Connected them per the wiring diagram, and problem solved  |
