LED lights for Syncro locker panel?
tjet
tjet is offline
PostPosted: Fri Oct 21, 2016 11:48 am    Post subject: LED lights for Syncro locker panel? Reply with quote
Has anyone replaced the standard indicator bulbs in the locker panel with LEDs?
Cheers
ajdenette
ajdenette is offline
PostPosted: Fri Oct 21, 2016 12:05 pm    Post subject: Re: LED lights for Syncro locker panel? Reply with quote
yes, the bulbs are identical to the ones used in the cluster I used on for general illumination as the incandescent had done some damage to the panel but left the incandescent and filled all of the spots for the indicator lights.
1985 2wd Westy with 2000 Subaru 2.2 current driver
https://www.thesamba.com/vw/forum/viewtopic.php?t=685635
1986 Syncro Doka Project next in line
https://www.thesamba.com/vw/forum/viewtopic.php?t=732777
1990 Vanagon Syncro Base awaiting body work
T3 Pilot
T3 Pilot is offline
PostPosted: Fri Oct 21, 2016 1:36 pm    Post subject: Re: LED lights for Syncro locker panel? Reply with quote
Use these:
https://www.superbrightleds.com/moreinfo/instrumen.../223/2029/
1988 Vanagon
The most important part in every vehicle is the nut behind the wheel......
squeegee_boy
squeegee_boy is offline
PostPosted: Fri Oct 21, 2016 3:52 pm    Post subject: Re: LED lights for Syncro locker panel? Reply with quote
I did, using the bulbs that T3Pilot linked to.
Totally worth it, especially if you're already in there replacing one. I just did them all at once and never looked back Smile
Robyn
1984 FrankenSyncro Westy. EJ25 RMW kit
syncrodoka
syncrodoka is offline
PostPosted: Fri Oct 21, 2016 4:41 pm    Post subject: Re: LED lights for Syncro locker panel? Reply with quote
If you are just using them for the general locker illumination that comes on with the headlights then they are the exact same as the instrument cluster LEDs.
If you are using them for the locker illumination make sure that you get the green ones, they are pretty bright though.
