Drag racing alternator
samotorsport
samotorsport is offline
PostPosted: Fri Sep 22, 2017 10:43 am    Post subject: Drag racing alternator Reply with quote
Hey guys , i wanna add an alternator to my dragster.
After couple runs it starts getting weak and heavy to start. Due to no electricity available at the airfield i wanna put a one wire mini race alternator on .
Would love to get one from Jaycee , but:
599$ & approx 100 shipping to Luxembourg & 7% import tax & 17 % vat would bring me to 875 $ which is a bit expensive Sad
Therefore I am looking for an alternative to build myself, maybe somebody can help me with a p/n from denso so I can see to get an alt over here.
And if someone has a drawing with measurements for the bracket ?
Or even the cnc program ? Very Happy
Thanks for any advise , help or picture from your setup
Greets
Sam
1958 Dragster 1835cc Topchop
1962 Split Panelvan Camper
1967 Herbie the love Bug
1970 Karmann Ghia 14
FreeBug
FreeBug is offline
PostPosted: Fri Sep 22, 2017 11:22 am    Post subject: Re: Drag racing alternator Reply with quote
I don't know what your cooling setup is, if you have a fan, etc..
But you can add an alternator :
Just thin hollow steel tube, well triangulated, and an extra pulley, stock mounting points (1 coil thread, 1 upper exhaust stud, 1 front engine stud) I'm using an old inner valve spring as a tensioner. The alternator puts out 90 Amps, with a completely separate circuit.
not sure how that helps, but it gets the topic flowing.
Lo Cash John
Lo Cash John is offline
PostPosted: Fri Sep 22, 2017 1:17 pm    Post subject: Re: Drag racing alternator Reply with quote
Any small, "one wire" type alternator can be made to work. I've often heard of an alternator from a Toyota forklift (lift truck) as being the best bang for the buck. Unfortunately I don't have any detailed info.
Oh, it's assumed you'll have to do your own fabrication to mount it. With that said, alternators will put out power no matter which direction they rotate, so if you had to you could mount it "backwards".
www.LoCashRacing.org
Lo' Cash Racing Team on Facebook
More brains than bucks...Believe it or not!!
My boss told me I need to work on my mutli-tasking. So now when I use the bathroom at work I surf The Samba on my iPhone.
UK Luke 72
UK Luke 72 is offline
PostPosted: Fri Sep 22, 2017 2:28 pm    Post subject: Re: Drag racing alternator Reply with quote
Danny makes alternator kits for drag cars, here's his website http://www.reichspeed.com/main.htm
2276 Beetle build https://www.thesamba.com/vw/forum/viewtopic.php?t=670744&highlight=2276+beetle+daily
2276 EFI Conversion https://www.thesamba.com/vw/forum/viewtopic.php?t=689172
neil68
neil68 is offline
PostPosted: Fri Sep 22, 2017 6:28 pm    Post subject: Re: Drag racing alternator Reply with quote
Also, JPM in Sweden:
http://m.jpmotorsports.se/ms/ms/j-p-motorsport-pro...Kit%20Race
Neil.
Der Kleiner Rennwagens
‘68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 108 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo
samotorsport
PostPosted: Sat Sep 23, 2017 12:15 am    Post subject: Re: Drag racing alternator Reply with quote
Thanks a lot , the JPM looks like a good one for me . The price is ok , and due to Sweden is in the EU i dont have to pay import and VAT taxes .
I think i give it a try Wink
calvinater
calvinater is offline
PostPosted: Sat Sep 23, 2017 2:46 am    Post subject: Re: Drag racing alternator Reply with quote
Or maybe a spare battery to swap out when the charge gets low?
"Albatross"!
Dale M.
Dale M. is offline
PostPosted: Sat Sep 23, 2017 7:11 am    Post subject: Re: Drag racing alternator Reply with quote
Small generator and battery charger to run while in pit or in start line up....
Dale
mark tucker
mark tucker is offline
PostPosted: Sat Sep 23, 2017 10:07 am    Post subject: Re: Drag racing alternator Reply with quote
most racers charge between rounds. other than that you can just get a small alt from whatever and put it on.I dont care if they have 1,2 or 3 wires going to them. and you can wire up a full throttell cut off switch so it isant deawing more power going down the track. also the size of the drive pully can be alturd to get the rpm of the alt down and engine power draw down too.
there are some realy small alts out there nowdays.
