hiho Samba Member
Joined: August 18, 2005 Posts: 34 Location: Beaverton, Ontario
Posted: Mon Jan 07, 2019 8:57 am Post subject: Removing rear skirt Ghia |
I want to make the rear skirt and valance to make motor work even easier.
Anyone able to give me the Coles notes for removing these 2 pieces? Am I drilling out spot welds from where?
Read some discussion on choosing the right spot welds. |
Joined: August 31, 2013 Posts: 13326 Location: North Carolina
Posted: Mon Jan 07, 2019 9:31 am Post subject: Re: Removing rear skirt Ghia |
A Ghia is already pretty flexible structurally, I wouldn't go out of my way to weaken it any more.
Unless you're yanking the engine every or every other weekend, the time spent drilling & hacking the rear apron off is sure to waste more time than what you'd spend working around it. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
crazy tarzan Samba Member
Posted: Mon Jan 07, 2019 9:57 am Post subject: Re: Removing rear skirt Ghia |
Of course if you're planning on a subie swap , it makes a little more sense. . .  |
slalombuggy Samba Member
Posted: Mon Jan 07, 2019 12:44 pm Post subject: Re: Removing rear skirt Ghia |
You just have to look at the panel seams to see where the spot welds will be. each panel has a stiffening fold and flange and the welds are underneath along those flanges. You have to drill out all the welds on the flanges from underneath. But I agree, the back end is going to be pretty floppy without that panel in there solid, If you were racing, ya, make it removable but on a street car it will be way easier to remove the rear engine tin and drop it out.
brad |
